Question about Samsung Digimax S500 Digital Camera
Camera will not stay on.....
When you turn on the camera the green light comes on, display screen lights up, then it beeps three times and shuts off even after new batteries have been installed.
  • 1 more comment
  • oleander1001 Dec 06, 2007
    My camera comes on showing Polaroid then beeps 3 times shuts right off. So i think i need to reset it to factory settings.
  • SHEDY Jan 14, 2008
    My sumsung digimax when powed it produces 3 beep sound then shuts down
    I have tried solving it by placing the batteries bt still invain
    what I`m i gonna do now?
  • Anonymous Jan 14, 2008
    When you turn on the camera the green light comes on, display screen lights up, then it beeps three times and shuts off even after new batteries have been installed.When you turn on the camera the green light comes on, display screen lights up, then it beeps three times and shuts off even after new batteries have been installed.
  • 24 Answers
The 3 beeping sound means that the camera has low battery capacity. the lens is stuck out because there is incorrect battery connection. there is an option on the camera setting for the battery type. try this one:
-turn the camera on
-click on Menu button
-select options using left/right, up/down button
-select Set up 2
-Select Battery type
-Select Alkaline for non-rechargable
or Ni-MH for rechargable
-click OK button
this setting should be done when using camera for the first time and whenever you are switching battery types, from rechargable to non-rechargable and vice versa.
Posted on Jan 11, 2008
Posted on Jan 14, 2008
SOURCE:
My Olympus Camedia C-750 will not turn on. When I start it, the screen looks normal but then goes blank. it stays lighted and then beeps several times then makes a noise like a picture has been taken,...
If those batteries are definitely good then the electronics of unit have gone haywire. Contact Olympus to see if there is some sort of hidden code to reset electronics to factory defaults.
Sep 05, 2017 | Olympus Camedia C-750 Ultra Zoom Digital...
Not turning on, light blinks once that's it
hi try to reset ur camera...To do such reset, turn on the camera and hold the menu button down for longer than 5 seconds. A message should hopefully come up on your LCD asking if you want to reset the camera. Select Yes...thank u!!!
rate me!!
May 29, 2009 | Polaroid I533P Digital Camera
Won't stay on
I just posted a few minutes ago with the same problem. I fixed it myself with no one telling me what I needed to do. What I did was as soon as it starts turning on smack it on your hand a couple times. Make sure you use a bit of pressure. It showed a camera view for 3 seconds then shut off so I did it a couple more times and now It's working again just fine. If you have any questions feel free to email me. Yes it can be a crappy camera. But hit it against your hand a few times and it'll work. Let me know if it does for you.
[email protected]
May 12, 2009 | DCS Norcent Technologies XIAS DCS-1050...
The lens is not retracting
i have a samsung s730 and when that happens to me i put new batteries in it and it works
Apr 02, 2009 | Polaroid i830 Digital Camera
Camera beeps and shuts off
sorry to hear you are having this issue. well the problem is your lens. the len motors have locked up and are stuck the lens needs replacement. repair run any where from 75.00 and up in most cases.i repair these all of the time.let me know if i can help out any further.
Nov 02, 2008 | Casio EXILIM ZOOM EX-Z60 Digital Camera
It dont turn on
dont buy this c*#p again thats the best solution i can give
Jun 23, 2008 | Samsung Digimax S700 Digital Camera
Camera not turning on
my camera just wont turn on period and just used it like half an hour ago
May 31, 2008 | Samsung Digimax D53 Digital Camera
My batteries died in my pink i733 and when it shut down the "zoom lense" did not recede. i put fresh batteries in it but all that happens is that the green light flashes. it wont come on or...
This can sometimes be fixed if you remove the batteries over night and allow the camera to sit and discharge it should correct this problem. hope this helps.
Mar 28, 2008 | Polaroid i733LP Digital Camera
Digimax l60
I don't know, it's not powering up......
Jan 03, 2008 | Samsung Digimax L60 Digital Camera
It dont turn on
I had the same problem. Try to turn it on, 3 beeps and then it would shut down. Screen would come on for that time. Also, the lens was stuck open. It wouldn't close.
I twisted the lens (gently) and it appeared stuck. A gentle screw motioned seemed to free it. I hit the power button and it come on, but this time no 3 beeps and shut down. I then turned it off and this time the lens retracted and closed.
So, it appears that if the lens gets stuck open, it has a shut down feature that doesn't allow the camera to go further into its operation modes. I believe this stuck open problem occured on our camera when the batteries went low.
Again, a second of gentle twisting seemed to unstick it and with fresh batteries in, it was able to operate and shut down properly.
As far as batteries, I use the rechargeable Ni-Cad 2500 mA. They last a while.
Blessings to you!
Jun 02, 2007 | Samsung Digimax S500 Digital Camera
Samsung Digimax S500 Digital Camera Logo
480 people viewed this question
Top Samsung Cameras Experts
FIKRET UNALIR
FIKRET UNALIR
Level 1 Expert
Anthony Ward
Anthony Ward
Are you a Samsung Camera Expert? Answer questions, earn points and help others
