Question about Sony Personal Entertainment SDM-V72W (Dark Pearl Blue, Metallic Silver) 17.1 in. Flat Panel LCD Monitor
What do i do
Screen is nothing but lines vertically laid on full screen is it junk
  • jojoeric Feb 22, 2008
    sharp 37in montor has like a coloured bar code thru entire screen but picture in background, this happened after a power surge any ideas
  • 180 Answers
This is due to the defective lcd panel. It will be expensive to replace .
Posted on Apr 08, 2008
How do I remove three vertical colored lines from my Television. One vertical line is green another is red and the final one is blue.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
May 24, 2015 | Panasonic Viera Tc-p50u50 Hd Plasma Full...
Why vertical lines on half of screen after moving Proscan 39" LED TV?
Sep 14, 2014 | Proscan 32LB30QD 32 in. LCD TV
Vertical lines on screen
Hold one side of the screen need top and flex slightly (Not twist, FLEX) if the full screen appears and lines are gone, you may need to have this fixed by a shop or replaced totally.
May 02, 2010 | E-Machines M6810 Notebook
I turned it on and just one line accross the screen appears. the audio is fine.Everything is normal except theres just a line on the screen.
You have a vertical problem. You may need to resolder the vertical IC, and check each cpacitor that is near the vertical IC. Your TV will be restored to full screen!
Mar 27, 2010 | Televison & Video
LCD monitor have Vertical lines and black colour become greenish
normally the 19" resolution can support up to 1280*1024, but if it comes with vertical lines in full screen, it might indicate the panel is no longer to work and probably it's time to replace new one.
Aug 12, 2009 | Neovo S 19 19 in. Flat Panel LCD Monitor
Black colour displaying become greenish and narrow vertical lines
Most LCD monitors have a default refresh rate of 60 Hz. Older monitors also have limited resolution. Please check your display settings and ensure you're not using a refresh rate higher than 60, or a resolution higher than what it supports. If either one is the case, you're lucky the LCD still works.
Aug 12, 2009 | Computers & Internet
Zenith P42W46X - no picture
if the lines covered the entiire screen, fist I would check to see if the TV's menu can be seen. If not then check the buffer boards. Next I would check the logic board
Jan 09, 2009 | Zenith P42W46X 42 in. Plasma EDTV
Yamaha YPG625 screen shows only vertical lines
I brought the keyboard into a local service technician. He told me that he had to remove about 50 screws but the solution was simple. He unplugged and reconnected the ribbon connector. It apparently was not making good contact.
Oct 02, 2008 | Yamaha Full-Size Keyboard
Flickers and Lines
you have the vertical circuit "closed" you have to repair it checking
transistors and capacitors . if you can  it this work may be at low cost - few dollars
Mar 21, 2008 | Dell UltraSharp 2000FP 20.1" Flat Panel...
Sony Personal Entertainment SDM-V72W (Dark Pearl Blue, Metallic Silver) 17.1 in. Flat Panel LCD Monitor Logo
35 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
