Question about Kenmore 98702 Stacked Washer/Dryer
Flame won't stay on, Kenmore Mod 417.9386220
Igniter comes on, then gas, and flame, but only stays on for a few minutes before it goes out. It appears to be valve related, as I am still getting 120VAC to the coil pack (from the orange wire only, checking N back to grey wire at the timer). Sometimes there is more gas and a larger and hotter flame, like it should work, but this is intermitant too, and will eventually quit and then flame goes out altogether. Also, will not light again unless I unplug and wait several minutes, and sometimes it won't relight for several hours... what gives?
  • flameout Dec 07, 2007
    what do the coils read? ohms.
  • flameout Dec 26, 2007
    Same problem with the all of the panels on... no difference.
  • 641 Answers
SOURCE: kenmore elite he3 - door lock
If sound like a lid switch issue. Open the top of the washer to get an access to the lid switch(located near the doorframe). Look for a loose wire or a broken switch. In case there is no loose wire or broken switch, you should replace the switch. Good luck!
Posted on Sep 05, 2007
TheMobilian
  • 8220 Answers
SOURCE: hi, i have a kenmore
Drop front panel
open pump sump
clear objects.
Retry
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on Jan 08, 2009
  • 20 Answers
SOURCE: Machine powers itself on-off / Error code F-01
I would try to find out what the "F-01" means but if you need to replace circuit board they normal are easy to "unplug and replug" wires. But SEARS tech's would be best to repair. If can't find a source to tell you what F code stands for , call SEARS service and when he diagnoses problem you could see or ask him how to replace my tech is helpful that way, then it only cost the "service casll" rate and not hte return part replacement cost also
Posted on May 22, 2009
philbran
  • 242 Answers
SOURCE: Gas Dryer model 110-77974110
the coils on your gas valve are going out , this is why it will work at first and stop , the coils heat up and wont open the valve again after they are heated.
I thought they were some what cheaper than they are now but still not too bad. you can try this part number search on ebay for the best price I can find.
279137 coil kit
Phil
Posted on Jun 11, 2009
jsrock516
  • 5911 Answers
SOURCE: My kenmore Elite HE3t Giving a code F 06
"F06" is a Motor Speed error code. This is an indication that there is a problem with the Drive Motor, Tachometer, Motor Control Unit (MCU), Central Control Unit (CCU) and/or interconnecting wiring between the all these components. The following link explains:
http://www.fixya.com/support/r714929-f06_error_whirlpool_duet_kenmore_elite
I would begin by checking all the connector plugs between the CCU, MCU and Drive Motor to ensure none of them are loose or have corroded contacts.
Read through the link and follow the steps provided. If you have questions, please let me know. I hope this helps.
NOTE: The majority of the time this failure is attributed to a bad tachometer which is located on the MCU. If defective, the MCU must be replaced. There is a technical data sheet that comes with the washer. It is located inside the washer behind the lower toe panel directly below the door. The panel comes off by removing the screws located under bottom front edge of the panel. With the screws removed, the panel will drop down, then come off. If the tech sheet is not located directly behind the panel, it will be affixed to one of the interior cabinet walls. Included are all the diagnostics and troubleshooting advice for your washer, including diagrams to show test points. HINT: For better access to the screws you can prop the two front feet of the washer up using a 2 x 4.
Posted on Sep 14, 2009
Gas dryer does not heat igniter glows red gas valve clicks but no flame
Since the igniter glows i am wondering if within 1 minutes does it go off??or does the igniter just stay on??
If the igniter just stays on and doesnt go off the problem is going to the FLAME SENSOR
if the igniter goes off but no flame the problem will be the GAS VALVE COILS
GENE
Oct 12, 2011 | Dryers
Ignitor is lighting but silinoid is not opening to let gas through.Roper model # RGS7646KQ3
Your have one of two problem causing the gas to not come on on your dryer.
1) the flame sensor is bad...if the igniter comes on and stays on and doesn't go off...usually within 1 minute the flame sensor isn't working as its supposed to
2) the coils on the gas valve could be the problem...if the igniter does indeed go off within 1 minutes and as soon as the igniter goes off if their is no flame the coils on the gas valve is what would need to be replaced
here is what each part looks like
I hope i have been able to help you fix your dryer,
GENE
Sep 17, 2011 | Dryers
Igniter comes on will not let the gas in. The gas burner does not come on Maytag model dg882s
FLAME SENSOR
Sep 14, 2011 | Maytag Dryers
I have a Maytag Model PGR5710BDW gas range. The bake igniter lights up and the gas ignites after 2 minutes or so. Then the flame goes out after a few seconds and then reignites and this cycle repeats ...
Yes it is the igniter its weak and can not stay within normal range to stay on allowing the flame to stay on.
The part number for that igniter is 74007498 it can be purchased at your local appliance parts store on online at
searspartsdirect.com
repairclinic.com
apwagner.com
apdepot.com
partselect.com
GENE
Aug 27, 2011 | Maytag PGR5710 Performa Gas Kitchen Range
80 series kenmore gas dryer. Won't dry clothes. Igniter glows, gas valve opens, flame lights. Stays on for about 45 seconds then flame shuts off. About 1 minute later it lights again but it doesn't stay on...
Did you get a solution yet? - our dryer is doing the same exact thing....last time it was not lighting at all and we found out it was the thermal fuse - very cheap fix...this time the symptoms are exactly as you described.
Aug 03, 2010 | Kenmore Dryers
My gas dryer starts fine than the flame goes out
replace the coils. i promise you. and here is a guide to most gas dryer problems that even a kid can see.
starts fine, cycles off, igniter comes on, hear a click, and no flame.-coils.
(can also be intermintent)
igniter stays on, no flame.-flame sensor
no glow from igniter.-igniter
remember, always allow about one minute for ignition.
Oct 06, 2009 | Frigidaire GLGR331A Gas Dryer
Kenmore Gas Dryer ignites then stops heating after ten minutes.
If the glow bar comes back on and the gas does not light,replace the gas valve coils. If the ignitor does not come back on,replace the flame sensor.
Sep 01, 2009 | Kenmore Dryers
Gas dryer mod.# MDG6000BWW, Igniter lights but no flame
Replace the flame sensor on the side of the heat canister. You may also have to replace the gas valve coils.
Aug 27, 2009 | Dryers
KENMORE gas dryer
Hi .No The Solenoids Are Turning The Gas On . I would Check The Venting . Remove The Venting Clean All Venting. Thanks The Appliance Doc
Oct 03, 2008 | Kenmore 73952 Gas Dryer
Gas dryer
hi. no not now. i would check the venting. clean the venting. thanks the appliance doc
Oct 03, 2008 | Kenmore 73932 Gas Dryer
Kenmore 98702 Stacked Washer/Dryer Logo
53 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
