Question about Gateway M250 Notebook
No display I only get a gray screen on my laptop display, when I plug in an external monitor, I get the display to show perfectly. Do I need a new display for my laptop?
    Champion:
  • 238 Answers
Hi, probably yes, but u can give it a try by removing the LCD cover and check it the connectors/contacts r not dirty or loose.. let me know..
Posted on Jan 10, 2008
Technika white screen lcd
Hi
to test if the lcd screen is faulty or if its the inverter
plug in another monitor to the external monitor plug
when you turn on the laptop if the 2nd monitor displays the desktop your lcd needs to be replaced
if the 2nd monitor is also black your inverter needs to be repalced
aries
Oct 19, 2013 | Computers & Internet
Toshiba m60-104 screen dark new screen new iverter
Have you tried an external monitor?
Plug in an external monitor and see if the display shows up on it. It can be any kind of monitor even the old big fat crt monitors as long as it has a vga cable to connect to your computer's vga port. If the display shows on the external monitor that proves your video card is ok and your lcd screen is the issue. The video will show on most systems when you reboot without you having to do anything. Some systems will require you to hit the FN (Function key) + F1 thru F12. Hold down the FN key then hit the correct key for displaying on the monitor (F1 thru F12). The correct key will normally have CRT/LCD on it or it will have the icon of a display.
If is shows on the external monitor, then you would have to question if the new screen and lcd inverter is bad. Just because they are new don't mean they work. Are you sure you purchased the lcd screen and inverter that is for your model?
May 23, 2012 | Toshiba Satellite M60 Notebook
Screen is rolling constantly
. Sounds like its time for a new lcd screen. Try plugging an external monitor to the laptop and see if it behaves the same way. If the external monitor scrolls, then you more than likely have a Video Card problem. If the external monitor displays without scrolling then your lcd screen is bad.
Plug in an external monitor and see if the display shows up on it. It can be any kind of monitor even the old big fat crt monitors as long as it has a vga cable to connect to your computer's vga port. If so that proves your video card is ok. The video will show on most systems when you reboot without you having to do anything. Some systems will require you to hit the FN (Function key) + F1 thru F12. Hold down the FN key then hit the correct key for displaying on the monitor (F1 thru F12). The correct key will normally have CRT/LCD on it or it will have the icon of a display
May 01, 2012 | Dell Inspiron 9300 Notebook
Screen is rolling
May 01, 2012 | Dell Latitude D530 Notebook
I have an HP dv6707us laptop. The display started getting fuzzy and turning redish and would fail to display anything after a few minutes. I plugged in an external monitor and it works fine. I disassembled...
The screen replacement is defective or the part number is wrong, check the part number on the back of the original screen and compare it against the the one you replaced, it should match.
Jun 15, 2011 | HP Pavilion Dv6707us Entertainment...
I have a R51 that when it boots up it only shows a white to gray shade screen
If it is at all possible, connect an external monitor to the computer. All laptops should have a port for an external monitor. If the external monitor works then you screen is most likely bad and needs to be replaced. If the external monitor does not work then your motherboard is probably bad.
May 06, 2011 | IBM ThinkPad R51 Notebook
Why are there green and red lines on my mac lcd
Them monitor is starting to fail. You will need to purchase a new one unless you are still under warranty.
Nov 16, 2009 | Compaq Presario M2000 Notebook
My laptop is on and plugged to the monitor, but the monitor says no signal
You have to switch your laptop to a different display mode. Usually it's done by pressing Fn key and F8 - look for a description near this key showing rectangle / rounded rectangle, or text "CRT / LCD".
Usually there are 3 modes:
LCD (internal laptop display) only
LCD + CRT - the picture shows on both displays
CRT - the picture shows only on the external display, allowing you to set a different screen resolution, equivalent to the external monitor's optimum resolution.
Oct 29, 2009 | Acer AL1916W 19" LCD Monitor
My screen wont turn on
Hiya, have you tried plugging in an external monitor to the Blue VGA port of the laptop ?
If so, do you get any display then ?
Hint : you need to plug in the external display 1st, then turn on the laptop. If the External monitor doesn't come on, then you may need to press the Function key on the laptop & the F4 key (Or whichever shows a monitor logo) to get the laptop to switch to external monitor.
If you CAN get display on the external monitor then the problem could either be that the Invertor for your laptop screen has blown, or, the backlight for your Laptop Screen has broken, or the Laptop screen itself has gone faulty. In rare cases, the cable from the Laptop Motherboard to the screen may be faulty or have come away form the connector on either end.
Hope this helps.
Mar 19, 2009 | HP Compaq Presario F750US
Gateway M250 Notebook Logo
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
