Ice collects in the bottom of the freezer
Place a large clear bowl on top of the fridge. Have the bowl about half full of water. This is a quick way to see if the fridge is level on both axis points. If it is not and is leaning forward you can make the adjusments to the front leveling pads while someone else watches the level of the water. Good luck! Dana
Most probably defrost thermostat is defective. Unit never goes into defrost, ice forms on coil and in floor of freezer. After defrosting may work OK for a week or two but gradually gets warmer because ice is blocking ports where cool air gets to refrig. May also have water in refrig box. Can also be caused by defective defrost timer. This can also be caused by the drain hole being blocked by ice. You MUST remove all ice in drain under freezer coil. Use turkey baster to squirt hot water into hole and use hairdryer to defrost.
