Samsung 32inch tv screen blackout
i own a 32inch samsung lcd tv, only 18months old.
i was tonight playing on my xbox360 when teh screen suddenly went black, and no picture was present.
the sound carried on fine, the tv was still on, but no picture.
so i tried to unplug and leave for 30minutes to see if it had just overheated and that didnt work when i retried it, so now i am confused as to the problem.
thank you
  • 6 more comments
  • Anonymous Jun 13, 2008
    Same problem but with different Tv.
  • cdavisje Oct 06, 2008
    Same problem here, same tv.
  • Anonymous Oct 26, 2008
    40" samsung same problem
  • emmars Dec 15, 2008
    32 in Samsung LCD tv.
    Screen Goes black randomly when playing any source -DVD or cable.
    Any fixes?
  • Anonymous Dec 23, 2008
    40" samsung, same here
  • Anonymous Jan 04, 2009
    New samsung 5 series tv.  After watching tv for some time, the monitor will go blank while the sound continues.  Is it a cable box issue or a monitor problem
    32" Samsung LCD 6 month onld. same problem when watching my setop freeview or DVD player. momentary blackout.
  • Anonymous Apr 21, 2009
    same problem different television
SOURCE: no picture on samsung lcd tv
I have the same problem. I brought a Samsung 46" in July 07 and on Jan 8, 2008, video went blue.
I called Samsung and sent out technician and they replaced the motherboard.
Two hours later, same problem occured. I called today and Electronic Company thinks I have a bad LCD panel.
Posted on Feb 16, 2008
moto34
  • 155 Answers
SOURCE: Samsung LCD Tv
Try this:
Access menu service by press on your command, with your TV OFF:
INFO + MENU + MUTE + POWER ON
Then you should get access to Service Menu.
The last item says: RESET
This will do a reset to the TV.
Make no harm.
WARNING: If when on service menu you feel tempted to "screw" on anything FIRST take note on ALL you change! You can compromise the TV ...
Posted on May 03, 2008
  • 124 Answers
SOURCE: Samsung plasma all black screen
Black Screen come from three areas. 1- Power Supply Board 2- Inverter Board 3- Processing Board on the LCD. Since the Power Supply Board was replace, it easy to troubleshoot where the problem. lies If you cannot get the backlight, then its the inverter board. If you can use a flash light on the TV screen and can barely see the images, then the problem is indeed the inverter board. If you cannot see any images when using a flash light, then the problem comes from the LCD processing board. Let me know if you have any success. Mike
Posted on Feb 21, 2009
stonephoenix
  • 563 Answers
SOURCE: Samsung Plasma TV have sound but no picture
G'Day!
Unfortunately, what you're describing is a repair issue. You won't be able to address the problem with troubleshooting. There is a part inside the TV that needs to be replaced. If you're under warranty, this will cost you nothing. If you're not under warranty the cost will likely be a minimum of $200 parts and labor. However, be warned that the cost could be considerably higher.
I hope I've provided you useful assistance and that this information allows you to make an informed decision as to how to proceed from here. Please be sure to vote on my response. I hope I've earned a good rating from you today.
Please post a comment if you need additional assistance so that I can help you further
Posted on Jul 22, 2009
SOURCE: samsung lcd tv no picture just sound
While this is not a permanent solution, we've fond it helps... We have a Samsung LCD that does not turn on when there is too much humidity in the room. This only happens in the summer when it gets really humid. We moved our dehumidifier next to it, let it run for around 15 minutes and the TV turned on again, no problem. Lately, it's been raining alot so it's very humid. We've gotten into the habit of leaving our dehumidifier on through the night on low and we've had not issues turning on the tv since then. This is a hastle but it's either that or buying a new tv.
Posted on Jul 25, 2009
Problems with colors and display on my Samsung LN37A550P3FXZA flat LCD.
Replace all busted capacitors in power supply board inside.
Jan 10, 2014 | Televison & Video
Lines down screen
We have a Samsung LE32A457, whilst we were watching T.V tonight the top halve of the screen suddenly appeared with green lines halfway down the screen and that half of the picture was unwatchable, T.V is 2 years old. We have removed all scart leads but this did not help and the problem still exists, when shutting down a white horizontal line across the centre of the screen appears from this line upwards the picture is faulty. Any help or advice would be grateful.
Jul 08, 2010 | Samsung LE32A457 32 in. LCD TV
My xbox360 wont play movies my ps3 blank screen
you need to configure both to hdmi or not to hdmi in order to get any picture out whatsoever on the xbox its a switch on the video and for ps3 it needs to be done in the settings but they both need to be done before changing tvs otherwise
Robb
Apr 28, 2010 | Samsung DLP HL-P5663W 56" TV
Screen marks on my samsung lcd tv.
Sorry not a solution just confirmation of similar fault on a Samsung 32" . I to have this problem which appears to be getting worse . started with 1 mark and has now spread to about 20% of the screen albiet numerous marks. It appeared after 18months to 2 years after purchase in 2006 so now 4 years old. I've accepted there's nothing to be done and out of warranty. Problem is purchase a new set Samsung or another. But will I have the same problem 2 years after??
Oct 30, 2009 | Televison & Video
My plasma tv power supply is knackered. Samsung PS42q96HDX
Not sure but mine is doing the same. and also about 18months old? did you get a solution to this?
Jun 17, 2009 | Samsung Televison & Video
Samsung lcd tv 18months old
i had the same problem and it turned out being the panel
Feb 28, 2009 | Samsung LN-T4665F 46 in. LCD Television
Duraband 32inch, FTV7601
the problem is the power supply, check and replace regulator ic or even check the zener diode that trigger the regulator it maybe open or shorted......
Feb 16, 2008 | Durabrand DWT1905 TV
LCD TV SCREEN PROBLEM RED HORIZONTAL LINES OF DOTS ALL OVER SCREEN PLEASE HELP
This should be repairable. It may be the LVDS Cable or the Main board problem. The only other problem is the T-Con Board.
Dec 13, 2007 | Samsung LN-S4051D 40 in. LCD Television
Televison & Video Logo
1,000 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
