Question about Toshiba Satellite M35X-S349 Notebook
HD isnt running
Hi, my m35x power light is on but the fan nor the hd is running. It was running fine five minutes before this happened then for some reason decided to stop. I took it in a few months ago to the get the motherboard replaced and the discharge repaired. Any idea what is goin on?
Sounds like your motherboard just died. This is a known issue with Toshiba. They extended the warranty until Nov 7th of 2007, but now it is out of warranty. :-\ You could try phoning Toshiba (good luck getting someone who speaks English) and see if they have any other solutions. Repair is in the neighbourhood of $500 or less, so it seems.
Posted on Dec 10, 2007
Same fan failure issue on 7200
do the fans work? they may need to speed up at certain times for cooling reasons (different signals may need more power. more power, more heat). if the fans aren't working up to par, you may need to clean them or replace them. use canned air.
Oct 04, 2009 | InFocus ScreenPlay 4805 Multimedia...
I was watching my vizio tv for 5 mins and it turned off. will not turn on and no lights even come on.
Might be the switchmode power supply board, mine did something similar and when I disasselbled it I noticed five capacitors were bulging and when I replaced them, the TV turned on and everything was fine again.
These TVs tend to overheat I hear, I am going to install two small 12v brushless DC fans inside so this never happens again.
Aug 10, 2009 | Vizio P4 46 in. HD-Ready Plasma Television
Iomega Minimax HD, no power but lead light is on. Working fine, then I turned it on today & nothing, no fan, no light but the power lead green light comes on. How do I know if its the HD or the power lead...
In your situation I would :
open the minimax enclosure, and take the hd out, (just open the enclosure, not the hd itself), and then open your desktop and connect this hd as slave (I am guessing you have a desktop with IDE hd and that the minimax has an IDE hard drive in it.... or both your desktop and the minimax has SATA hard drives) and then when you turn on your computer you should be able to see your second hd as a partition and be able to see the info in there, yet if windows does not recognize it, that means your hd is useless., yet remember you have to change the pin on your external hd to be slave or auto detect, if you let it as master your computer won't boot, bout do not worry, after you unpluges the hd from your desktop everything will be normal
p.d.
shutdown and unpluged the power cord from your desktop when adding/removing the hd.
Apr 18, 2009 | Iomega MiniMax Desktop - Hard drive - 500...
Picture blurry on my Westing house LTV-32w3 HD Television
hi possably is the fan in the back make shour it is working all the time that there is no dust bild up on it stops it from spining it may need a cleen ,or it is a transister heeting up and cooling down the transister is on its way out it will be a hard fix for a tech to fined thay will fined it but it will cost you a heep ,its best to whate till its gon completly .cheers peter
Apr 05, 2009 | Westinghouse LTV-32w3 HD Television
Not booting but RAM,processor,SMPS ,HD are fine.
Check without Video Card, Processor , Memory and beeps are coming
If no then this is motherboar issue, I had the similar problem. So went to the local repair shop and got the power capacitors replaced,
Jan 29, 2009 | Asrock P4i65GV Motherboard
Shuttle X PC - HD + Power LEDs briefly illuminate, no boot.
It sounds like you have a bad power supply. It will store up a very small amount of energy (enough to run some LED lights) but not enough to power up the system. That's where I would look. If that is not the problem, then I would look to the capacitors on your motherboard. Good Luck!
Dec 02, 2008 | Shuttle Computers & Internet
Toshiba M35X-S349 (Freezes Periodically)
Update: I looked at the plug connecting the HD to the PC and pulled it about 1/2 way back off and reinserted into machine. I then pulled the HD back out and noticed that it was not all the way pushed back on and it wasnt parallel to the HD. Basically I am thinking that the HD is not sitting properly in the bay for some reason or another, but I have been running 10+ hours with no problems as of yet. I did reformat the HD so I am going down that road of reloading and letting run awhile, reboot, repeat. Not sure if solution, but looking real good at this point.
Aug 11, 2008 | Toshiba Satellite M35X-S349 Notebook
M35X Screen went black and will not come back on after shut down, reset and power up
Try to connect to external monitor and see if you see anything. Of course when you do that you have to hold at the same time fn key and the key that has a blue picture of computer screen.
Jan 17, 2008 | Toshiba Satellite M35X-S149 Notebook
Monitor shuts off after a few minutes
Can you see the whats on the display but just seems the background lighting is off?
Nov 13, 2007 | Dell Inspiron 1100 Notebook
Toshiba M35X-S109 Doesnt Start
you may have a faulty motherboard connection, but try connecting the power adapter in without the battery and see if it runs, then replace the battery back in the compartment.
Oct 15, 2007 | Toshiba Satellite M35X-S109 Notebook
Open Questions:
See all Toshiba Satellite M35X-S349 Notebook Questions
Toshiba Satellite M35X-S349 Notebook Logo
69 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
