Question about Harley Davidson Harley-Davidson Motorcycle Desktop Telephone
No spark my 86 fxr has no spark when you press the start button but when you release the botton it has spark
Right off hand, i would do an amp draw test on the starter. if the starter draws too many amps, the voltage will pull down and some modules will not produce spark until you release the button. the voltage will surge upward allowing the module to fire. points will fire but will be extremely weak.
Posted on Sep 07, 2008
On the EP-4PCIA, when pressing the on/off button the pc does not start. What is wrong?
are you holding down the on/off button? momentarily press one time and release. if nothing unplug the pc from the wall and verify everything is plugged in securely and then plug everything back in and try again
If you need further help, reach me via phone at https://www.6ya.com/expert/joel_63c670a84e9f6a97
Jun 11, 2012 | Computers & Internet
Ti-86 screen turned black after replacing the batteries
Turn the calculator on. Press and release the 2nd key. Press and hold the down-arrow key until the screen lightens. If you go too far, press and release the 2nd key and then press and hold the up-arrow key.
Sep 13, 2010 | Texas Instruments TI-86 Calculator
Give me nokia 5800 master code
I was also looking for that, but i couldn't find it. But i got one solution to format Nokia 5800 it doesn't work for security code.
To format or hard reset nokia 5800 press 'green key, red key and camera botton. After pressing these three botton, press the power which is located at the top. When it shake release only the power botton not the green, red and camera botton. It will start up your phone and after sometime it will display country botton and now you can release the keys. Thats it. This is call Hard Reset.
Jul 22, 2010 | Nokia 5800 XpressMusic Smartphone
Harley has compression but won start
For any engine to run, you must have three things. Compression, spark, and fuel. If you have compression, it must be something else. On your '93 FXR, take the plugs out of the heads, put them back into the spark plug wires and ground them well to the engine. Turn the switch on and press the starter button. Watch for the spark plugs to spark. If you don't have spark, you have an ignition problem. Check your ignition coil, your "Run/Stop" button, and power to the coil.
If you do have spark, then the problem is probably a fuel problem. Take your air cleaner cover and the filter element out of your air cleaner assembly. Make sure your fuel petcock is in the "ON" position. With the engine "OFF", crank your throttle grip wide open. As you twist the throttle to wide open, you should see a stream of gasoline shooting into the throat of your carb. If not, your problem is a fuel related problem.
Good Luck
Steve
Jun 30, 2010 | 1993 Harley Davidson FXR Super Glide
The oven does not start
One of the interlock switches is defective or out of adjustment. By pressing the door release you were causing the switches to make or break briefly enough to allow the oven to turn on.
Jun 20, 2010 | Welbilt MR96TW Microwave Oven
Zebra prints one page then light turns red.
TRY HOLDING THE BUTTON DOWN AND LET IT FLASH 5 TIMES. RELEASE. WHEN THE DIMENSIONS ARE AT THE CORRECT NUMBER PRESS THE BUTTON AGAIN.
Aug 19, 2009 | Zebra LP 2844 Thermal Printer
My TI-86 calculator doesn't have a cursor. I can turn it on and adjust the contrast from dark to light but no cursor appears and nothing comes up when I punch any of the buttons!
Press [EXIT] or [2nd][QUIT] to terminate the program that may be hung in memory. Press [2nd] MEM[F3][F1][F4].
You may have to reset contrast.
1.Press and release [2nd] key.
2. Press and hold [UpArrow] to darken or press and hold [DownArrow] to lighten it.
Hope it helps.
Aug 15, 2009 | Texas Instruments TI-86 Calculator
X5 -alarm system can't be activated
I press the remote control middle (BMW) botton, one time to set up the alarm, when I release the alarm, I press the one above the
BMW botton one time, this botton control driver side door too, if I want to open other three doors, I have to repress the same botton one more time.
Hope this can help .
May 17, 2008 | 2002 BMW 5 Series
Code Search
First try this method as it is the quickest way,
To program a component using the Automatic Code Search method, perform the following steps:
1. Turn on the component you want the remote control to operate. 2. Press and release the component button that corresponds to the component you want the remote control to operate. info.gif The illuminated ON-OFF button turns on and remains on.
aud_remote_on-off.gif 3. Press and hold both the component and ON-OFF buttons. info.gif The illuminated ON-OFF button turns off. 4. After the illuminated ON-OFF button turns back on, release both buttons. info.gif The illuminated ON-OFF button remains on. If you press an invalid button during Auto Code Search, the illuminated ON-OFF button blinks four times and turns off. The last programmed code under that component button is retained. 5. Press and release the PLAY button.
aud_remote_play.gif 6. If, after five seconds, the component does not respond, continue to press the PLAY button every five seconds until the component turns off. info.gif Each time the PLAY button is pressed, the illuminated ON-OFF button blinks ten times while a block of 10 codes is sent to your component. This process continues until all of the codes in the Code Lists have been searched. If the component has not turned off after all codes have been searched, the illuminated ON-OFF button blinks four times, turns off, and the Auto Code Search Entry method is exited. 7. When the component turns off, press and release the REVERSE button, then wait two seconds to see if the component turns on again. info.gif If the component does not respond, continue to press the REVERSE button every two seconds until the component turns on again. This will isolate the correct code in the last block of codes sent. Each time the REVERSE button is pressed, the illuminated ON-OFF button blinks.
aud_remote_reverse.gif info.gif If the REVERSE button is accidentally pressed after the component responds, press and release the FORWARD button. Wait two seconds to see if the component turns off again. 8. To save the new code, when the illuminated ON-OFF button turns off, press and release the STOP button.
aud_remote_stop.gif info.gif If some of the features of your component do not work, different codes in the list can be tried until you find the code that allows the remote to control the majority of your component’s functions.
Only use the codes below if the auto code search dosen't work. Codes program a zenith tv are below
Zenith 1000, 1001, 1004, 1051, 1083, 1151, 1152,
1154, 1217
You can click the link below you will be able download the manual.
http://support.rcaaccessories.com/main.html?topicid=216&Referring%20DeviceDocID%20List%20Index=1&navtypeid=16&pagetypeid=35&prevPageIndex=13&selectedmodel=RCR450&selectedFamily=generic
Mar 15, 2008 | RCA RCR450 Remote Control
Touch screen not responding correctly
have the avh 5700 should be close to the same unit. try holding the two center buttons on deck [boost and arrow button] i think then without releasing them push the reset button with a pen ,the screen will close then reopen now let go of buttons should be in the right menu on the first item dont trace the extreme edge come in a little then the second item on the menu screen is the touch section just touch the little plus button on screen if still off try tracing first screen little further from edge. this should fix problem
Mar 13, 2008 | Pioneer AVH-P5700DVD Car DVD Player
Lands Phones Logo
241 people viewed this question
Top Harley Davidson Lands Phones Experts
Gar
Gar
Ronny Bennett Sr.
Ronny Bennett Sr.
ted dux
Are you a Harley Davidson Lands Phone Expert? Answer questions, earn points and help others
