posted by raiders1 on Dec 04, 2007
i have the jensen 300 watt xa2150 hooked up to my factory hu, so for the remote wire im putting it in with a fuse, but i cant seem to find a fuse that only comes on with the ignition, even the ignition fuse puts power to the amp without the key on any suggestions?
Solution #1
posted on Dec 05, 2007
you must use same cable used to power sound unit.
also check if the sound may have a remote connector.
Was this solution helpful? Show your Appreciation by rating it:
Suggest a new solution for this problem
Post a New problem for Jensen XA2150 Car Audio Amplifier
Email this problem
Email this problem
Can you Help with these Car Amplifiers problems?
Sound comes on, goes away
It is definately NOT temp... Answer This...
Repair Service
Find Car Amplifier Repairman Near You:
