Question about Sharp UX P100 Plain Paper Thermal transfer Fax
Film won't feed to front roller
I've installed new film and when I close the cover, the film does not feed to the front roller. It comes off the back roller and gets jammed up to the top of the machine.
    An user who is expert in 3 categories / brands.
  • Sharp Master
  • 1,362 Answers
The gear that moves the roller is probably broken.
look in the manual for the gear location
Posted on Jan 30, 2008
Film count reading problem
I am not familiar with that model.. However ant time you open the compartment or unlatch it THE CAMERA think you are installing NEW FILM so camera goes back to the "Beginning". is this your first time use??, look for the instructions or google it.
Jun 02, 2015 | Fujifilm Instax Mini 25
How do I feed New laminating film through straight? Top roll of new film is wrapping around bottom heat roller
go to youtube and watch the video on GBC ultima65 film loading. sounds like you are not using a threading card to load laminator. Manila File folders work great to load laminators Westco Laminating Svcs 405-324-6092
Aug 30, 2014 | Gbc HeatSeal Ultima 65 Laminating System
Print smears on right edge of paper only
It is possible that the fuser film is damaged. The fuser film covers the heating element. Open the back panel, and examine the area where the paper exits. The grey film should cover the same area as the lower black roller. If not, you will either need to replace the fuser or obtain a replacement fuser film and install it. Is the printer noisier than it used to be? The fuser bushings on these printers are notorious for wearing out and causing the film to fail. If the bushings are worn then likely a replacement fuser will be the solution for you.
May 22, 2014 | HP LaserJet P3005n Printer
Film-advance warning won't go away on a RB67 Pro SD 120 film back?
Mamiya RB67 Pro SD that is new to me. loaded the film correctly took the first shot. But, the film won't advance. What am I doing wrong?
Feb 18, 2012 | Mamiya RB67 Pro SD Medium Format Camera
Paper rolled on heater roller. How do I remove?
I fix roll laminators for a living. Its best with GBC machines to remove wraps where the film is stuck to the roller hot. trying to remove ilm adhered to the roller cold can not jusst remove the film but the rubber roller surface. Do note GBC heat rollers espically the red ones are over 500 bucks each:( Its easy to damage those rollers making the machine junk....
This question is old but I answered it for the benefit f others coming here bob haller service and sales 412 366 4906 pittsburgh pa. I answer all phone questions for FREE, and in the pittsburgh area offer free no cost no obligation estimates
Oct 04, 2011 | Gbc HeatSeal Ultima 65 Laminating System
Service error 6000
error code 6000
Condition:an error occurred in the lf encoder signal
problem and solutions:
-clean the LF/EJ **** film. -remove foriegn material. -if other solution fail,replace the following *lf/ej **** film *lf/ej timing sensor unit *paper feed roller unit *logic board *paper feed motor
May 25, 2011 | Canon PIXMA MP190 All-In-One InkJet...
Check Film and Cover Open: KX-FPC95
Check for slack in film between supply and take-up rollers. Manually advance take-up roller to remove slack before closing cover.
Dec 18, 2009 | Panasonic KX-FPC95 Plain Paper Thermal...
Diana F+ 35mm back wont load film.....
possibly you have a friction padded roller instead of spikes place enough film on roller to overlap and then close camera
Dec 09, 2017 | Lomo Photography
Disney princess camera
bottom of camera open battery cover with a pen point, insert one AA battery close cover.
film door is opened with pen point left side of film door. load film & bring film leader to take up spool, close film door. rotate advance to # 1 counter on bottom.
turn camera on with sliding switch on front of camera, this opens lens cover and turns on flash .( if wanted ) second click.
at end of film roll pull rewind lever up and rotate clock-wise to rewind film.
open film door and remove film.
remember to turn camera off when not using.
Aug 05, 2008 | Photography
Canon c122 copier code EO 07
EOO7 error means: fusing film damaged or out of position. This means that an error has occurred with the fixing unit. This is the hot bit the paper goes through just before it comes out of the machine. It consists of a lower roller and above that a thin loop film of thermal plastic with a ceramic heater inside it. It is almost certain that this film has become displaced or damaged. E007 means that this film is not rotating correctly or jogging back and forth over the sensor. It will need a new fixing film. Did you run the adjustment for installing a new fuser film when you installed the fuser? Other than that, just check to make sure the film isn't broken or missing a piece.
May 03, 2008 | Office Equipment & Supplies
Sharp UX P100 Plain Paper Thermal transfer Fax Logo
123 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
