Cars & Trucks Logo
Anonymous Posted on Aug 24, 2009
86 Dodge ram D - 50 - Fuel Pump
Can anyone Please tell me where the Fuel Pump is located at on a 1986 Dodge Ram D - 50 Pickup , Thank you M
Anonymous
Level 3:
Brigadier General:
  • Master 4,088 Answers
  • Posted on Aug 24, 2009
Anonymous
Master
Level 3:
Brigadier General:
Answers
4088
Questions
0
Helped
1512650
Points
12435
A carburetor type engine has the pump on the engine near the front on the side--trace the fuel line down. Fuel injected engines have the pump located in the fuel tank.
Testimonial: "THANK YOU "
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Dec 30, 2009
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
Helped
977
Points
It can also be a in line
Have a dodge ram 50 pickup.. Hard to start.. Once started it will idle... Try to pull out and it hesitates and wants to die.. Back off on the gas and sometimes it will idle or dies..
Dodge Ram 50 Pickup Questions - Page 5 - CarGurus
www.cargurus.com > Questions > Dodge
CarGurusGet fast answers to your Dodge Ram 50 Pickup questions from experts in the ... 1986 Dodge Pick Up 5.9 Wont Start I Put New Distributor Set The Timing, New.
Dodge Ram 50 Pickup Questions - Carburetor - CarGurus
www.cargurus.com > Questions > Dodge > Ram 50 Pickup
CarGurusCarburetor - I recently bought a 1989 2.6L Ram50 for my son. ... Asked by redoverfarm Apr 13, 2010 at 03:36 PM about the 1989 Dodge Ram 50 Pickup ... check your fuel injector...may be clogged dirty, get a fuel injector cleaner or carburator ... Also gets poor gas mileage and is hard to start when the engine is warm !
Dodge Ram 50 Pickup Questions - 87 d 50 2.0 runs ok ...
89 Ram50 wont start.. - DodgeTalk : Dodge Car Forums, Dodge Truck ...
www.dodgetalk.com > ... > Dodge Ram Truck 1st Gen (88 - 93) Forum
Sep 22, 2011 - Hey guys i got a 1989 Ram 50 and im hoping i can get some help here. She drives like a champ but she only starts when i push start it, once i ...
1helpful
Where is the starter solenoid located on a 1986 Dodge Power RAM 50 sport 2.6 standard four wheel drive
I looked at 86 power ram 50 starter in partsbook. The solenoid is on top of starter.
How do you replace a fuel pump on a ram 50
well its located in the middle of the intake it should be two 12mm bolts i found it to be easyer to take the intake off cause of the spacer that has to be replaced as well it should of come with the pump along with like four gaskets
1986 Ram 50: Engin and carburator sputter and lose power when g...
i have an 86 dodge ram 50 that sputters when i step on gas going up hill after it warms up ive changed the gasket twice with no luck solving problem it runs fine in neutral but in gear under a load it sputters
2answers
Where is the EGR valve on 1986 Dodge Ram D50 pickup 2.0cc 4 cyl
if there pipes or tubes on top of your exhaust manifold that is where your EGR valve should be. if you want diagrams or text to help fix this problem i suggest the book from Chilton. they tend to explain thing pretty well.
1helpful
Whereis my fuel filter located for 1989 D-50 2000cc, 5-speed,2 wheel drive pickup?
Hi I 86 Ram has a fuel filter right above the drivers side rear tire .
Diesel Fuel leak of of large nut in backside of injector pump
do yourself a favor and take the truck to a fuel diesel injection shop the larger nut is just a cover but the smaller one is an adjustment if you remove either on you could damage the pump
1986 DODGE RAM 1500
it sounds like a timeing issue but in the distributor itself. check your weights inside your distributor they could possibly be stuck
Top Dodge Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
Arnie Burke
Arnie Burke
Are you a Dodge Expert? Answer questions, earn points and help others
