GE Advantium SCA1000H 900 Watts Convection / Microwave Oven
Problem for GE Advantium SCA1000H 900 Watts Convection / Microwave...
Non-Stop Noise from Inner Ceiling of the Microwaveoven
By nancyjen2003 on Aug 24, 2009
I just purchased a GE Advandium SCA1000HBB microwave oven. I noticed there is a metal piece in the inner upper ceiling of the microwave by looking through the holes. This metal piece continuous to move up and down. I thought it is a vent and should stop once the inner temperature cools down. However, it just went on and on and strange noises were coming from the upper parts of the microwave. I ended up just unplugging the microwave. Does anybody know what this is about?
Best Solution
posted on Aug 24, 2009
Very Helpful)
drallim
Rank: Guru  GE Expert
Rating: 87%, 764 votes
It sounds like the 'stirrer' which is a metal fan-like device with a plastic bearing that is mounted in the wave guide above the cavity. Pull the plug, then the case. Remove the waveguide above the cavity which should expose the stirrer. Spin it and check for any up and down motion--straighten the axle part so that it turns true. The blower system turns the stirrer--no extra motor. If this part was bent, someone may have handled it roughly. Reassemble the waveguide and test without the case on, but a cup of water in the cavity.
Was this helpful?
Yes
No
1 person thought this was helpful
Asker's Testimonial
" Thank you so much for the helpful information. Your information confirms that this is a defective merchandise and I should return it immediately! " - nancyjen2003
Popular Solutions for GE Advantium SCA1000H 900
Questions and Unsolved Problems for GE Advantium SCA1000H 900
Do you recommend GE Advantium SCA1000H 900 Watts Convection / Microwave Oven?
Answer
Answer
How can I check the thermal switch on my GE Profile Microwave?. Where is it located and how can I... (More)
Answer
surface lights won't work. Got new bulbs, but still does not work. Suggestions?
Answer
The surface light on my GE microwave oven has a high and low setting. The low setting no longer... (More)
Answer
tray doesn't always rotate. sometimes yes, sometimes no .GE advantium model sca2000fww03 If we take... (More)
Answer
Hi, I picked up a used 2000 Chevy blazer for my daughter, 4 door and it needs speakers bad. I... (More)
Describe your Microwave Ovens problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Microwave Oven Experts
Top Small Appliance Repairmen
(316) 283-4211
(316) 283-8664
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
