Question about Garmin StreetPilot 2720 GPS Receiver
Touch screen failed after I added external antenna
The unit seems to work but the toucg screen will not respond
    Scholar:
  • 174 Answers
Have you tried resetting it (press and hold find, the press power)
Posted on Jun 16, 2008
When I turn my Garmin Nuvi 680 on, and the first screen appears about not driving while operating the Garmin, I have to hit "agree" button several times before it goes to main menu, and from that...
Try performing a soft reset.
Disconnect the unit from any external power supply.
Depress the reset button behind the flip up antenna.
Reconnect the unit to the power supply and let it should work normally.
If the soft reset does not work, try performing a hard reset.
Caution: Performing a hard reset will erase all user information including favorites and bookmarks and restore the unit back to factory settings. Be sure to save any information before performing the hard reset.
With the unit off, press and hold the lower right hand corner of the screen while turning the power on until a pop-up appears. Press "Yes" to restore the unit back to factory settings.
Sep 21, 2011 | Garmin Nuvi 680 GPS Receiver
My nokia N97 touch not working what should i do?
This means the component responsible for the touch function on the screen is bad. This could be as a result of the phone falling down or something affecting the screen. You can take this to the repair shop and tell them you want the toucg to be fixed this they will do by replacing the top layer of the screen
Hope this solution has been helpful?
Mar 11, 2011 | Cell Phones
I have a ADV3500PC touch screen with built in GPS. I have installed nroute, Gpsgate, mapsource with Gamap SAS Topo NNT 2010.01. Nroute displays searching for Satellites but does not find Satellites. Any...
There is a possibility that the antenna is defective. Sometimes a factory reboot helps or re-burn of the firmware. One way to confirm an antenna problem is to go into the tools menu and select "about". If the screen says "GPS S/W = 0.0 (should be a real number like 2.9 or 3.0) then this indicates that your antenna is not communicating with the main board.In this case, you need to send the unit to the manufacturer.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Sep 15, 2010 | Garmin GPS
How do i reset the 650? The touch screen isn"t responding
First you need to disconnect it from external power, then flip up the antenna to see the reset button. Press the reset button. Then reconnect it to external power, it should turn on automatically and work normally.
Aug 22, 2010 | Garmin Nuvi 660 GPS Receiver
Lowrance 330c gps not responding
do you have both power and ground wires hooked up?
Jul 27, 2010 | Lowrance LMS-330C GPS Receiver
Ique 3600 antenna reception problem
How long does it try to find the satellites? If it trys for a half hour of more with no results, the antenna may be broken. I have read in other forms that people have added an external antenna and their units would then work, evfen with the built in antenna broken.
Feb 25, 2009 | Garmin iQue 3600 GPS Receiver
HTC Touch External Port?
Yes, it is technically possible, however it is completely impractical. You would need to gain access to the circuit board, and 'shunt' a port off of the current antenna. This would take a crazy amount of time, so, a hardware hacker would do this as a hobby, not really for pay.
Jan 26, 2009 | HTC Touch Cell Phone (Unlocked) - Soft...
Messed up with garmin
(1) Disconnect any external GPS antenna. (2) Do not turn on auto engine. (3) Turn off any other peripheral devices. (4) Simultaneusly hold down the PAGE and MENU buttons while turning on the 2620. A prompt box will appear asking if you really want to delete all user data. Touch the NO selection. Then turn off the 2620. (5) Simultaneously hold down MENU & ROUTE buttons while turning on the 2620. (6) A self-running diagnostic program will appear. Allow it to run for a couple of minutes; check to see that all parameters indicate "PASS" or other indication of being OK. If any parameter is not OK, make a note of it for potential communication to Garmin, then proceed with the following steps (7) Turn off the 2620. (8) Simultaneously hold down the PAGE, MENU & ROUTE buttons while turning on the 2620. A SCREEN CALIBRATION adjustment screen will apear. Quickly touch the points indicated as the calibration program runs. At the end of this procedure, the screen will display a window indicating that the calibration either "PASSED" or "FAILED." If it "PASSED," continue to steps (8)-(9). If it "FAILED," turn off the 2620 and repeat this step. If, after three calibrations attempts, each one is "FAILED," then also turn off the 2620 and proceed to steps (8)-(9). (8) Turn on the 2620. Press the "OK" button each time prompted to do so. Wait for maps to load and for the 2620 to initialize, acquire satellites, and display your position. (9) Press FIND button, then touch the right-hand vertical screen position adjustment to scroll screen display down to reveal WAYPOINT selection box. If unable to select WAYPOINT, or if attempting to do so only selects an adjacent box, then repeat step (7), and return to this step. (10) When various waypoint selections appear, attempt to scroll down to a selection not visible when the list of waypoints first appears, and select one of them. If still unable to select WAYPOINT box, unable to scroll screen down (or if trying to do so selects a stored waypoint instead), once again repeat step (7). If successful,then proceed to step (11). Also proceed to step (11) if you have repeat step (7) but then still can't select WAYPOINT, can't scroll down after selecting WAYPOINT, or can't select a particular stored WAYPOINT. (11) Press the upper-right hand "X" to close out the FIND screen or sub-screen within that function. If unable to close the screen, press the PAGE button. (12) Press FIND button, and when selection screen appears, touch ADDRESS. On next screen, touch the STATE line and touch the ENTER A CITY in (name of state). When keyboard appears on screen, use it to enter your city, then touch OK. Continue this procedure to enter your house number and street name, then press "OK." If all screen keyboard keys not responding, repeat step (7), turn the 2620 off and on again, wait for it to initialize, and then attempt this step again. (13) Repeat this procedure several times if not initially successful. By the second or third run-through, the touch screen should respond fully and accurately. If, after many runs through this procedure, the touch screen still will not respond, the screen sensor probably will need to be replaced ($255). The foregoing procedure brought my touch screen back to life last evening, much to my delight. Do not be too concerned if the SCREEN CALIBRATION step does nto produce a "PASS;" on my third calibration attempt it produced a PASS but all of the touch screen points still had not returned to functionality. I was unable to get a PASS during the screen calibration step after that, but the many repetitions apparently nonetheless made the difference, as by patiently following the above prcoess for five cycles, full screen functionality was restored.
Sep 03, 2007 | Garmin StreetPilot 2620 GPS Receiver
Touch Screen Issue
Hi Troy, same problem with my 2610, It seems to be related to a voltage problem in my ford f-150 07. When starting the truck I think it sends current the wrong way because if i start and turn off the truck it goes back to normal, the problem comes back if i start the truck with the 2610 on. If this can help, the garmin tech also told me about the 225$ repair. Try turning the unit on and off and also your vehicule. Once it is ok, dont forget to turn the unit on and off while the car is on. It worked for me. I also know that this is not a definitive solution but it can help. Patrick
May 31, 2007 | Garmin StreetPilot 2620 GPS Receiver
Garmin StreetPilot 2720 GPS Receiver Logo
81 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
