Question about SanDisk Sansa e260 MP3 Player
E250R when I tried to run the download ( SanDisk.com/assest/file/download) I get an error "application failed to read version details" on my mp3?? any ideas?
  • 8,596 Answers
Try this: disconnect the player from the computer, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/Retail/DriverDownloads.aspx
or
http://www.sandisk.com/DriverDownload/driverList.asp
-Tha Mp3 Doctor
Posted on May 23, 2008
Refreshing database
User guide for Sansa e200R:
http://mp3support.sandisk.com/downloads/um/e200r_userguide_en.pdf
Check this link for Sansa e200 "freezing in refreshing database",
2 steps to follow up:
http://kb.sandisk.com/app/answers/detail/a_id/34/kw/e200r%20freeze/r_id/101834
1. Reset the device as described on the site of Sandisk.
http://kb.sandisk.com/app/answers/detail/a_id/189
If resetting didn't solve your problem
2. Update the firmware.
http://kb.sandisk.com/app/answers/detail/a_id/306
2.1 Use the Sansa Firmware Updater for a download of your device
with the next link:
http://mp3support.sandisk.com/sansa/Application/SansaUpdaterInstall.exe
2.2 Follow the instructions "update the firmware" for sansa e200 series:
http://kb.sandisk.com/app/answers/detail/a_id/306/kw/e200r%20freeze/r_id/101834
Sep 20, 2009 | SanDisk Sansa e250 MP3 Player
E270r Refresh Database error w/ version details error
Try putting the player into "msc" usb mode. "mtp" usually does that, but i've never hear of it being on the comp.
Good luck
Dec 17, 2007 | SanDisk Sansa e250 MP3 Player
4 GB micro sd and the Sandisk Sansa e250R...
If the 4gb micro SD is a high capacity SD (it will say micro SDHC on it) your player may not be able to read SDHC cards, my sansa can't because it's the 'older version' it will read 2gb and below micro SD cards though (it sucked when I found out because I had just bought a 6gb micro SDHC)
Nov 22, 2007 | SanDisk Sansa e250 MP3 Player
Recovery mode formatting failed
"Application failed..."
Means that this version is not for your player.
You have the Rhapsody version, which is not compatible with this software.
If you call SanDisk Support, they can email you what you need.
SanDisk Technical Support 1-866-726-3475
Best of Luck.
Oct 31, 2007 | SanDisk Sansa e260 MP3 Player
Sansa e200 resetting problem
The error message means that you have a different version.
Your device is annotated with an R or the word Rhapsody on the back. I have contacted FIXYA to add these models, but my words were unheard.
You will need to contact SanDisk for the Rhapsody version of the files to fix your problem.
Best of Luck.
Oct 15, 2007 | SanDisk Sansa e200 MP3 Player
I get - 'Load main image failed. Switch to Recovery mode'
Run the recovery tool from the SanDisk website. Make sure you select "format" when prompted. http://www.sandisk.com/Assets/File/Downloads/firmware/e200fw01.00.12.exe You need to put the device into "recovery mode" before you run the tool. - Turn the device off (hold power for 20 seconds) - Slide the hold switch into "hold" position. - Press and hold the "record" button while connecting it to your computer. Keep holding the "record" button until you see the "new hardware found" on your computer. Then run the recovery tool. Select format when prompted. Best of Luck.
Oct 08, 2007 | SanDisk Sansa e250 MP3 Player
Error with formatting
Its not a firmware update you are running, it is a recovery tool. The "application failed to read version details" error is because it is not meant for your device. You have a Rhapsody version and the firmware is different. You will need to call SanDisk for them to email support documents. SanDisk Technical Support 1-866-726-3475 If you are truly trying to format the device, change the mode on the device Settings>Mode or USB Mode, then try formatting again. Best of Luck.
Oct 04, 2007 | SanDisk Sansa e260 MP3 Player
Downloded recovery from sandisk website now get error msg
That software only works with the non-Rhapsody versions, hence the error message. You can call technical support and they can walk you thru the fix. Its too much to type. SanDisk Technical Support 1-866-726-3475 Best of Luck.
Sep 10, 2007 | SanDisk Sansa e250 MP3 Player
SanDisk Sansa e260 MP3 Player Logo
54 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Mohamed Ismail
Mohamed Ismail
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
