This can be caused by the drain hole below freezer coil being blocked by ice.
You MUST remove all ice in drain under freezer coil. Use turkey baster
to squirt hot water into hole and use hairdryer to defrost. Possible defrost thermostat is defective. Unit never goes into defrost, ice forms on coil and in floor of freezer.
After
defrosting may work OK for a week or two but gradually gets
warmer because ice is blocking ports where cool air gets to refrig. May
also have water in refrig box. Can also be caused by defective defrost
timer.
Problem for Whirlpool GS5SHAXN Side by Side Refrigerator Light and temp control lite in refrig not...
(More)
Problem for Whirlpool GS5SHAXN Side by Side Refrigerator Light and temp control lite in refrig not working. Was told about a board in lower left hand side of refrig might have a burnt spot on it. Does anyone have the part number of this board?
the temp control and lights are not working fridge is running but making a grinding noise whats...
(More)
the temp control and lights are not working fridge is running but making a grinding noise whats wrong with it
both refrigerator lights will not work. refrigerator made strange noises before the light system...
(More)
both refrigerator lights will not work. refrigerator made strange noises before the light system died.
