Question about Aiptek MPVR Digital Camera
While recording I get blue flashes
When I press record to start recording, I start getting blue flashes on the screen, I can't seem to get rid of the problem no matter what. Anyone help?
Have you tried removing the battery and reinserting it? If that doesn't work, you might try the aiptek support website, although I tried with a problem I had and tech was, shall we say, worthless...my son's friend had a similar problem with the volume ( fading in and out), so he tapped the camera sharply against his hand and it took care of the problem. Good luck..
Posted on Dec 05, 2007
Will not record from EPG settings but will record on 'live' record ie whilst already watching a program. Tried all usual reboot tricks but to no avail. Please note the forward recording schedule list has...
mikelake735
If you have DISH Network equipment, you can try a check switch test on your receiver so the receiver can update its information from the satellite. With the DISH remote press the Menu button which will display Main Menu on the TV screen.
Press 6 (System Setup), 1 (Installation), and 1(Point Dish). Highlight the CHECK SWITCH button on the upper right of the screen and press the Select button on remote. On the Installation Summary screen, highlight the TEST button at the bottom of screen and press the Select button on the remote. This will initiate the test. Allow the test to complete. Once completed, exit out of each screen till you get Acquiring Satellite Signal on TV screen. After acquisition completion, allow it to download the program guide. If this doesn't fix the problem, you may need a new receiver. I hope this helps.
Ray Calo
DISH Network
Feb 21, 2011 | Televison & Video
Lost manual. Cannot get HR A591U JVC VCR program to record a future cable tv program. Seems I have tried everything but it does not record as I set up. It will record an existing show by pressing...
Timer Recording JVC VCR HR A591U
Timer recording can be programmed on-screen with
the remote control. The built-in timer allows automatic
unattended recording of up to 8 programs within 1
month.
EXAMPLE: Program a timer recording for the 26th day,
channel 125 (CATV), 11:00 - 11:30 PM on timer program
number 1 (Tape speed: EP).
When a TV is connected with an audio/video cable, turn the
TV and this VCR on and select the video input mode on the
TV.
• After timer recording is completed, the VCR turns off
automatically.
• You can program the timer recording while a regular
recording is in progress; the menu screens will not be
recorded.
• The timer recording will start at 20 seconds before the time
you predetermined.
Press MENU on the Remote.
Check the “TIMER REC SET”
option is selected, then press
ENTER.
Press SET –/+ to select one of
the program lines, then press
ENTER.
Press SET –/+ to select the
date, then press ENTER.
Set the start time, end time,
channel and tape speed as in
step 3.
NOTE: To record from external
source, press SET –/+
and set the channel to
"L". "L" will appear next
to CH 125 (or 69).
To enter other programs,
repeat step 2 through 4. Or,
press MENU twice to return
to the normal screen.
Press TIMER on the Remote.
The power will go off, the
TIMER REC indicator ( ) will
light and the VCR stands by
for recording.
To cancel a program:
Press the SET –/+ to select the
“TIMER REC SET” option in the
MENU. Then press SET –/+ to
select the unnecessary program,
and press CANCEL to cancel the
program.
Aug 28, 2010 | JVC Televison & Video
How do I cancel program.
britstew2,
It sounds like you have timers setup to record on the 625 receiver. To delete the timers, press the DVR button on your DISH remote 2 times. This brings up the "My Recordings" screen on the TV. On the right side of the screen are several buttons. Move to the "Schedule" button and press select. This takes you to all the timers on the receiver. Go to the first timer you want to delete and then press select on the remote. Now you are on the "Timer Event" screen. Move to the button "Timers" and press select. Now you are at "Timer Schedule". Move to the button "Delete" and press select. This will delete that timer. You need to do these steps for all timers you want to delete. I hope this helps.
Ray Calo
DISH Network
May 27, 2010 | DISH Network DVR-625 DTV Receiver /...
Cant record
Set that switch to Camera to record live view. Press red button to start recording and press again to stop recording.
Apr 17, 2009 | Sony Handycam DCR-PC110E Mini DV Digital...
How do i REALLY erase on my olympus ws-300m?
Suggestion is to format the device to remove all unwanted data permanently.
1 While the recorder is stopped, press the MENU button for 1 second or longer. The menu opens
2 Press the + or – button to chooseSubmenu and then + button to “Format”.
3 Press the OK button. The “Cancel” indicator flashes.
4 Press the + button to choose “Start”.
5 Press the OK button. After the “Data Will Be Cleared” message is on for two seconds, “Cancel” will turn on.
6 Press the + button again to choose “Start”.
7 Press the OK button. Formatting begins and an indicator flashes
on the display.
“Format Done” displays when formatting ends
Dec 20, 2008 | Olympus WS-300M Digital Voice Recorder
Recording
press rec button again,sometimes certain cameras have built in or auto mechanism that keeps the user from leaving camera record on.
May 30, 2008 | Panasonic Palmcorder PV-GS12 Mini DV...
Freezes while recording
I'm been searching for slutions to this as well - It's happened to me numerous times, so much so, I've almost thrown it on the ground to see how many pieces I can break it into...
Apr 11, 2008 | M-Audio MicroTrack 24/96
Will not record or play back.
the head may be dirty, try cleaning the head with a cleaner tape and try recording again.
Oct 23, 2007 | Sony Handycam DCR-TRV340 Digital Camcorder
Aiptek MPVR Digital Camera Logo
27 people viewed this question
Top Aiptek Cameras Experts
ray gallant
John Oughton
John Oughton
Level 1 Expert
Are you an Aiptek Camera Expert? Answer questions, earn points and help others
