Question about Actiontec GT701WG Router (actiongt701wg)
Actiontec gt701-wg Installation
I have a actiontec gt701-wg with Qwest DSL, I see a phone jack, the power port, usb port, and the ethernet port. Do all of these connections need to be used. Or should i plug in from the wall the phone jack with the green phone line and then connect the ethernet port to the computer. what is dont understand is what is the usb port for ...............
    Problem Solver:
  • 13 Answers
You can use USB instead of Ethernet port but its not a common practise. Leave it empty then.
Posted on Dec 04, 2007
Do they have any upgrades for a actiontec gt701 wg modems
here's the page, check the firmware in your router and see if it's older than these
http://www.actiontec.com/support/product_details.php?pid=71
Apr 21, 2011 | Actiontec (GT701) Modem
Trying to change from actiontec gt701 to actiontec gt701-wg. after new modem is hooked up, internet light stays red. switched by to old modem and all is fine. anyone know why internet light stayed red?
The reason why your internet light is red for the actiontec gt701-wg is because it is not yet configure. You need to access the gui of this router. enter the username and password for your internet connection. You can contact your ISP provider so they can walk you through for the steps on how to configure your new router.
The old router has green light because it was already configured by your ISP provider.
Apr 08, 2010 | Actiontec GT701WG Router (actiongt701wg)
I have a dsl modem and an actiontec gt701-wg gateway
Yes this is a normal method to setup a wireless network.
To set-up and secure the wireless router from unauthorized access, follow these steps :-
1. Connect the wireless router to your computer with a LAN cable.
2. Start your browser and enter the router's configuration URL IP address.
3. Enter the router setup, login and password
4. Change the admin password
5. Go to the wireless settings and change the default SSID and turn off SSID broadcast.
6. Setup encryption key the strongest is WPA2 (if not then WPA).
7. For further security measures - turn on MAC address filtering and enter the MAC address of the wireless cards on the computer/s you want to connect to this wireless router.
8. Record the settings you have made and keep it in a safe place and Save the settings.
9. Configure the wireless cards on the computer/s with the SSID and encryption settings of the router.
10. Remove the LAN cable between the router and the computer then the computers should be able to connect to the router.
Oct 31, 2009 | Actiontec (GT701) Modem
I have a Qwest Actiontec modem that has worked fine until today. Now the DSL light is blinking and the Internet light does not come on. I have rebooted, but no fix. thanks!
If the DSL light is blinking it means that there is no DSL carrier signal to your modem. Check the phone line and make sure you have no open lines and filters are on all the devices hooked up to your phone system except your modem. You can check for an open line by hooking up a phone to the phone line going into your modem and listen for a dial tone.
May 07, 2009 | Actiontec (GT701) Modem
Use a Qwest Actiontec GT701-WG router with a different ISP?
Yes, if the other isp is also providing dsl services, but you will have to configure the device the other isp will not help you with that.
but its really not that difficult.
Feb 22, 2009 | Actiontec GT701WG Router (actiongt701wg)
Red internet light stays on
the following link provides some very streightforward advise;
http://www.qwest.com/internethelp/modems/gt701/pdf/13566_GT701_ServiceStatus_031906msl.pdf
check the following in order
1 check that all of the cables are securely plugged in, if you find any loose plug them back in, you may need to powercycle the router afterwards though if the router is subsquently plugged into another unit down the chain power off both units turn them back on turning on the actiontec last.
2 if your ISP requires logon details to be included in your router, double check by viewing your router settings renter them if you are unsure.
3 lastly, have you paid your ISP bill?
Nov 05, 2008 | Actiontec GT701WG Router (actiongt701wg)
Actiontec Modem Won't Work!
take a wire and carefully touch it to the two attachment points of the copper ring on the left side while it is plugged in. I first froze my system for 15 min then thawed out and touched the wire as instructed and all works fine.
To open the box remove the clear soft contacts on the bottom, should be four. Using a small philips remove them and pull the box in two. Then fix according.
Hope this helps
Aug 27, 2008 | Actiontec (GT701) Modem
I cant communicate with belkin wireless g router
It sounds like you don't have the units connected properly. Make sure you have a cable(wired) from your ethernet card on your pc connected to a wired port on the router. Then plug your router from its yellow port into the modem. Make sure your modem is connected to its Internet interface. Plug in your modem and wait 60 seconds for it to power up. Then power up the router.
At this point you should be able to access the router with the supplied installation CD. Run the setup assistant and it will define your wireless network. When you are through you should have internet access through the wired network. When you are finished you should be able to use the wireless network assuming you have the card installed correctly and the software for the card correctly installed.
Jul 09, 2008 | Belkin (F5D7230-4) Router (587009)
Actiontec GT701-WG won't operate wirelessly
In looking on the internet the unit is a DSL gateway. Trying to use it on cable internet is not a real good way to set up your network because I believe the router is waiting for a DSL sync before the services turn on. I would spend the money and pick up a Linksys or Netgear G router, there around $50.
Jun 01, 2008 | Actiontec (GT704WG) Router
How to connect to Actiontec GT 701-WG
choose add new connection and choose wireless and follow the direction
Sep 28, 2007 | Sony Playstation 3 (PS3) Console
Actiontec GT701WG Router (actiongt701wg) Logo
311 people viewed this question
Top Actiontec Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you an Actiontec Computer and Internet Expert? Answer questions, earn points and help others
