Question about InFocus LP 735 Multimedia Projector
Infocus LP790HB Overhead Projector
After powering up, the unit will run for about 45 seconds and cycle off for about 45 sec, then back on and continues this pattern. When it shuts down, the power led goes from steady green to flashing green and back to steady 45 sec later. The lamp PCB power supply (front right corner) does not loose its input voltage (380 Vdc). There is a spark gap on the board that when voltage across it reaches about 284 Vdc, the system cycles on & off at 45 sec intervals. I thought the spark gap was firing but not sure. I researched the part (EPCOS 800-043) but not able to find the voltage rating. Also, I have disabled the "DPMS".
  • 1 more comment
  • Tom Bumgardner Dec 06, 2007
    Also, I have reset the unit and the lamp......I think.
    The fans and unit are clean, however, if the lamp needed replacing (don't know how many hours,)would that mean software is keeping up with the hours and is programmed to shut down after so many hours have elsaped? Or does the lamp filament pull more or less current as it ages? I don't understand how the lamp could cause this problem. Not saying it wouldn't, just saying I don't understand yet. I work in electronics and can troubleshoot to component level. This thing was given to my son and he wants to use it. To replace the lamp would be very, very expensive unless I knew for sure. Is there a way to determine its definitely the lamp? Thank You for replying.
  • Tom Bumgardner Dec 21, 2007
    If its the lamp, how does the circuit shut down? Does the lamp pull more or less current as it ages? Is there a reference window for monitoring voltage or current? Is there some way to make the circuit think there is a good lamp installed? I'am not sure how the lamp functions sincee there does not appear to be a filament to measure. Thank You.
  • 265 Answers
I've run into the same problem on LCD projectors, and found that simply replacing the lamp does nothing. I believe that it is a software feature, which has to be reset by someone privy to the instructions to do so given only to certified repair facilities by the manufacturer. I also feel that this is something which should be investigated by the US Attorney General, since it violates US law.
Posted on Dec 22, 2007
    Sergeant:
    Champion:
  • 231 Answers
First thing to do is replace lamp .When a lamp has some hours on it .It will act just as you mentioned (cycles) .Also make sure fans are running and not clogged and or crusted with dust.If fans are full of dust ,fan spins slower ,causing a shutdown...
Posted on Dec 06, 2007
  • crispin melchor Dec 06, 2007
    well I work with lots of DLP , LCD, type tvs..I have come to learn that the lamp can act very wierd as you mentioned and Replacing lamps have prove me wrong many times.Yes lamps are expensive but its a strong possiblity it is causing this..Why dont you call that manufacture and try to get infoon it
I have an Infocus 640 that I'm thinking of repairing. It won't power on correctly. If I hook up a regular power cord to the back and bend it slightly and press the power button, the unit will power on...
firstly why not just resolder the main connector on the pcb of the 640 unit. then check if your problems will be solved.
Otherwise look at the part number of both power supplies and see if they are the same.
Mar 25, 2011 | InFocus LP640 Projector Multimedia...
I have now had my second Infocus LP70+ with the same issue. Unit powers up and the moment Infocus screen appears the unit powers down. Any assistance would be appretiated. Both start with serial ANEN.
Normally problems are heat related.Try blowing air to clean dust from the filters,Check fans are moving and also refitting back the lamp. This should solve your problem. Please rate the solution.
Samir
Feb 07, 2011 | InFocus LP70+ Multimedia Projector
Ordered/installed from Infocus a new bulb unit.
the colorwheel needs to be replaced. the projector won't turn on if the colorwheel motor is not up to speed.
Feb 25, 2010 | InFocus ScreenPlay 4805 Multimedia...
SP-LAMP-LP3E powers off in 5-20 secs after inital power on
if the new lamp doesn't have a problem, then it's not the ballast, it's just a bad bulb. especially if you didn't get it from infocus. the cheaper lamps don't last long. you get what you pay for.
Dec 23, 2008 | InFocus Projector Lamp for LP340, LP340B,...
Intermittent Power up / dn
HI-
The projector is overheating, try cleaning the filters for the fan.
Hope this helps
Oct 29, 2008 | InFocus LP 600 Multimedia Projector
Infocus lp600 not working
HI-
MAke sure that cables are properly connected, it might be that it is not getting any signal from the source.
Hope this helps
Oct 28, 2008 | InFocus LP 600 Multimedia Projector
Dell 2200MP Powers off
I have 2200MP projector that when you turn it on,it clicks about 8 to 10 times and then the power seams to turn on, but the lamp light light comes on and nothing lights up. it will shut down after that, with the green light still flashing. What could be the problem? Roger
Jul 28, 2008 | Dell 2200MP Multimedia Projector
INFOCUS Lamp replacement
you tried holding down both of the volume keys for 10 seconds while powering up?
Jan 29, 2008 | InFocus X1 Multimedia Projector
Problem with INfocus LP425z Colorwheel ?????
That unit has a bearing color wheel, if it was not stored proper, it could be sticking. That would explain the power cycling. giving it a bump start if you will. Yes you can open and inspect to see if color wheel "free wheels"
Feb 21, 2007 | InFocus SOFTCASE, LP425Z Multimedia...
InFocus LP 735 Multimedia Projector Logo
99 people viewed this question
Top InFocus Office Equipment & Supplies Experts
neOen
Level 1 Expert
Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
