Question about Panasonic Toughbook 51 Notebook
Keyboarb Seems keyboard one element is atuck, since I keep receiving a constant tone noise, and no keys that I press respond. I do connect an external keyboard and it works. I press the START button and something else shows uo.
    Champion:
  • 238 Answers
Hi, its a very common issue, the keyboard itself needs to be taken care off,try removing it and clean the contacts/connectors, check if any key is getting stuck? let me know
Posted on Jan 10, 2008
Cant receive faxes. constant busy signal when dialing in.
Hi Janet
Try using a standard phone to call your Fax Line
Connect a phone to this Line to test for voice
Disconnect Fax Machine from Phone Line
Reset Fax machine
The Fax machine is supposed to respond to the right tones being sent down the voice line
If it is not responding & all else works then check your Fax settings for "Receiving"
Nov 30, 2015 | Panasonic UF-5500 Fax Machine
My neo basic B2165 laptop keeps long constant error tone while turn on and freeze on booting(and error tone doesnt stop), you have to press del or @ keys to stop error tone and continue to boot up and...
Since you have reinstalled the OS and it didn't fix the problem. It most likely your computer having one or more hardware failure. You need to check each of your computer component to find where is the problem.
Feb 28, 2011 | Computers & Internet
Key board will not respond. Mouse works fine.
Normal 0 Make sure the batteries are good then try the following.
Press the Receiver button (and the lights will start flashing.
Then if the Keyboard isn't working, press the small RESET/CONNECT button on the back of the board to connect the keyboard to the receiver.
If the MOUSE isn’t working, push the small RESET/CONNECT button on the back of the mouse to connect to the receiver. Then they should work okay.
Hope this helps. Bud
Dec 07, 2009 | Computers & Internet
Mx3000 stopped working, read forums, reset receiver now dashes only when pressing any key. rebooted computer ... now keyboard not responding agian
I got a used MX3200, got the mouse working right off, but no keyboard. This solved my problem: with the wireless mouse working took out the keyboard batteries, pressed connect button on the receiver, replaced the keyboard batteries, pressed connect button on the keyboard. Voila!
Feb 03, 2009 | Logitech Cordless Desktop MX 3000...
Logitech keyboard F Lock works but nothing else Connectivity?
Reply to this issue from Logitech Tech Support:
Thank you for contacting Logitech Technical Support. My name is Susan and I will be assisting you with Incident # xxxxxx-xxxxxx .
I understand that the keys on your keyboard are not responding except the F lock key and the battery indicator key. Please correct me if I misunderstood you.
It appears that your keyboard might be encrypted during first installation.
To try and resolve this issue, I would like you to try and decrypt your keyboard. You can refer to the steps below on how to do this:
1. Press Ctrl + Alt +F12 key on the keyboard.
2. Press the Connect button on the receiver.
3. Press the Connect button underneath the keyboard.
4. Press the ESC key on the keyboard.
Once you have performed the steps above, test the keyboard in simple text applications such as Notepad or MS words to verify if the problem persists.
Additionally, you can try the following steps should the steps above was unable to resolve this incident:
a. Press the Connect button on the receiver for 10 seconds.
b. Wait for 20 seconds and then press the Connect button on the receiver again. Press the Connect button on the mouse.
c. Insert fresh new batteries back into the keyboard.
d. Press the Connect button on the receiver.
e. Press the Connect button on the keyboard.
This would help to isolate the cause of the incident that you are experiencing.
If this does not address your question, please update this incident, describing the results after following my suggestions. Or, if you prefer, you can contact us directly by the phone numbers listed below.
Thank you for choosing Logitech.
Sincerely,
Susan
Logitech Customer Support
www.Logitech.com/support
Dec 03, 2008 | Logitech Cordless Desktop EX110
Mouse and keyboard not working
  1. Remove the batteries from the keyboard.
  2. Make sure you have the mouse synchronized. To do this, press the connect button on the receiver, then press the connect button on the mouse.
  3. Open the iTouch Configuration Panel by double clicking the iTouch icon in the Systray.
  4. Click the Cordless tab.
  5. Click the Connect button in the Control Panel. A dialog box will appear instructing you to press the connect button. Before you do, you should re-insert the batteries.
  6. After inserting the batteries, press the connect button on the keyboard.
  7. Verify both devices function correctly.
If this does not work, please try the steps below:
  1. Remove the batteries from the keyboard and press keys on the keyboard repeatedly (as if typing) for approximately one minute. This will clear out the capacitors.
  3. Press the Connect button on the mouse. NOTE: You may need a pencil tip or other small tip to press the connect button.
  4. Press the Connect button on the receiver.
  5. Insert the batteries back into the keyboard.
  6. Press the Connect button on the keyboard.
Jan 09, 2008 | Logitech Cordless Desktop EX110
Keyboard not responding
Solution. My wireles keyboard stopped working except for the F-Lock key, the Media key and the sleep key. It wasn't batteries, even though I tried, communication was there because the above keys were working. Remove the batteries from your keyboard and let it sit for about 10 minutes. Press the red connect button a few times and other various keys every few minutes during that time. This may be the whole "capacitor discharge" trick, but I tired that with someone elses instructions and my keyboard did not work after 2 minutes of key pressing. I think it just needed more time to clear out the secure settings. Good luck, I was about to trash this keyboard until I tried again
Nov 26, 2007 | Elite Logitech Media Keyboard(KB9675590403
Keyboard wont respond
Often this is simply because the radio link between the receiver and the mouse/keyboard has been broken. Some possible reasons for this are: flat batteries, insertion of new batteries, connector to the computer removed, etc.
In the first instance, you should restore the Logitech devices to a defined status (reset). To reset the device:
Remove the batteries from the mouse/keyboard for approximately ½ hour.
Press and hold the "Connect" button on the receiver for 15-20 seconds. Make sure that the receiver is connected, the PC is switched on and that there are no batteries in the devices. After resetting, insert new batteries and restore the connection as follows:
  1. Press and hold the "Connect" button on the receiver for 1-2 seconds.
  2. Then immediately press the "Connect" button on the bottom of the mouse (locate this button before you start, all cordless mice have a "Connect" button)
  3. Move the mouse around to check that the connection is working correctly
  4. Press and hold the "Connect" button on the receiver again for 1-2 seconds.
  5. Then immediately press the "Connect" button on the bottom of the keyboard (locate this button before you start, all cordless keyboards have a "Connect" button)
  6. Use the keyboard to check that the connection is working correctly
  7. Both devices should now be working correctly
If one or both of these devices is still not working, try them on another compatible PC system to ensure that the fault does not lie with your PC system.
Nov 09, 2007 | Logitech Cordless Desktop MX 3000...
Panasonic Toughbook 51 Notebook Logo
96 people viewed this question
Top Panasonic Computers & Internet Experts
Oloyede Monsuru
micky dee
Are you a Panasonic Computer and Internet Expert? Answer questions, earn points and help others
