Question about Thermador SMW272 Electric Double Oven
Thermador sm272zs microwave/oven combo
After I did went through the sefl cleaning for the oven, there is no power to the microwave but the oven still have power and function normal. I open the front cover and remove the microwave and plug it into a different outlet, and it works fine. I think the problem is in the control panel wher it is distributed 120V to the outlet for the microwave. Tried to open the the control panel but could not do it. Is there a procedure of how to open the control panel?
Please help!
You have to slide the oven partially out of the wall and there is a metal cover panel on top...remove it and you will be able to access the wiring panels, etc.
Posted on May 02, 2008
Oven will not unlock after self cleaning
User manual says that the oven must cool off. I am sure this is not the case. Try starting the oven self clean function, and then clear/off to stop the function. Since the oven is cool, perhaps the oven will unlock.
Finally, you could try turning off the circuit breaker and then back on to see if it unlocks - unfortunately you will have to reprogram everything. All else fails, call a technician.
Mar 04, 2015 | GE Profile JT952 Electric Double Oven
We have a Kitchen Aid KEBC147VBL03 wall oven. When we ran the self clean oven (big mistake), the oven shut off and locked. There is no display/lights on the control panel. And, the door is stuck in lo
Does the control board or anywhere of control panel have a fuse? If not beter have it service. Expect a quotation from the serv. Tech after it found how big or expensive theparts tobe replace to make ur unit operational agian
Sep 22, 2014 | Ovens
Trying to use self clean feature on my 2009 themador wall oven and E106 code appears?
Are you sure of the error code number? A list that I found only goes from E1 to E15 and F0 thru F9 & also a Fd code. Double check the code and respond back to me and I will see if I can help you further.
Aug 01, 2014 | Thermador Masterpiece MEDMCW71JS 27"...
My thermador double oven display is note openly connected. How do I fix it?
This board set can also be rebuilt at Dim display is a common failure that can be repaired reliably at a fraction of the new board cost. Here are the relevant partnumbers :
35-00-760, 12001691, 492071, 14-38-901, 492069, 492067
1065923121 , 1065923160 , 1065923161 , 1065923200 , 1066025120 , 1066025150 , 1066025151 , 1066025160 , 1066025201 , SCD272T , SCD302T , SCE30500W , SCE30600B , SCE70600B , SCE70600W , SC272T , SC301T , SC302T , SMWS72YP AFTER S/N 8204 , SMW272B , SMW272P , SMW272S , SMW272W , SMW272YB AFTER S/N 8204 , SMW272YS AFTER S/N 8204 , SMW272YW AFTER S/N 8204 , SMW272ZS AFTER S/N 8204 , SM272B , SM272S , SM272W , SM272YB AFTER S/N 8204 , SM272YS AFTER S/N 8204 , SM272YW AFTER S/N 8204 , SM272ZS AFTER S/N 8204 , SVD48600B , SVD48600PF , SVD48600PG , SVD48600PK , SVD48600PR , SVD48600PT , S272T , S301T , S302T
Feb 02, 2012 | Thermador SC302T Electric Double Oven
The electric went off, when it came back on it beeped and f3 come on the ovens screen. can't use the oven or cleaning.
ISOLATE the Oven from the mains keep powered down for at least a minuite, the power it up again, see after 40 secs the display goes back to normal . If not then you will have to investigate the cause, always ISOLATE THE MAINS BEFORE OPENING, the displays can go faulty.
let me know how you get on
Hope this is helpful
Jun 06, 2011 | Ovens
Thermador microwave is arcing and sparking
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Microwave Oven Basic Troubleshooting Tips
Sep 08, 2010 | Thermador SEMW302BS Stainles Steel Triple...
Thermador SMW272 Electric Double Oven Logo
348 people viewed this question
Top Thermador Ovens Experts
Dan Webster
Dan Webster
Oloyede Monsuru
Are you a Thermador Oven Expert? Answer questions, earn points and help others
