Question about Canon CFX-L4000 Plain Paper Laser Fax
Paper tray pickup failure
When receiving a fax the machine fails to pickup paper from the tray and results in a paper jam warning. This happens 99% of the time. Is there a fix? It seems that the tray lift mechanism isn't working all the time.
  • shumiron Dec 13, 2007
    Is replacing the lift mechanism doable for a fairly experienced do it yourself person, or is this a repair center fix? Are repair instructions available online?
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Canon Master
  • 1,362 Answers
If it's not working all the time then the lifting mechanism is bad.
if it is and jams then the tire is slipping and causing the jam.
clean tire with alcohol and try is it really smooth or does it feel rough? if smooth then replace
Posted on Dec 10, 2007
Paper jam in tray one after receiving every photocopy in kyocera fs6525 wht's a problem ???
First make sure that tray is set up for correct paper size. That would be first thing. Check for paper dust in paper path blow it out. Really sounds like paper tray not set correctly.
Feb 23, 2014 | Kyocera Fs-6525mfp Copier, Printer,...
HP LJ 2420 wont pickup paper from tray 2
Replace try2 paper pick up roller..
Dec 01, 2011 | HP LaserJet 2420 Printer
I AM RECEIVING PAPER JAM AT MY BROTHERS INTELLIFAX-2820 THERE IS NO PAPER JAM AT ALL( I CHECKED IT COMPLETELY). AND FAX MACHINE KEEPS RUNING UNTIL I PUSH THE STOP KEY AND GIVES THE PAPER JAM MESSAGE.
Where is the paper jam?Jou can take the cartridge out and look if the sensor actuator is in it's plase.if you open the back door look for small pease of paper that might stay behind or a paper that did not go through otherwise take the paper tray out and look in the botom of the machine for sensors or peases of paper
Jun 13, 2011 | Brother IntelliFax-2820 Laser Fax
Paper jams at pickup from tray
Hi Make sure the paper tray (cassette) is not missing the small separation pad with the spring. It is part of the paper cassette. the roller may be worn so cleaning it might not help. Lawrence
May 06, 2008 | Brother IntelliFax-2820 Laser Fax
PAPER JAM MESSAGE, BUT CAN'T FIND ANY JAMMED PAPER
look at the paper tray,some of your sensor are jammed,try tyo find out where is the sensor on paper try
Feb 29, 2008 | Panasonic Panafax UF-585 Plain Paper Laser...
Can't print faxes due to error messages
Please check rear door area for paper, can you use manual feed slot? Power off machine with all jams removed and paper loaded, then power on, can you tell us exact error message/lights that are shown in this state?
Oct 15, 2007 | Brother IntelliFax-2820 Laser Fax
Brother fax 2820
Out of the lower paper tray when you go to print? Try this, remove the cassette tray and use a water dampened cloth and clean the gray paper pickup roller off. A lot of times this has paper fiber build up that causes the paper not to feed. The printer has a certain timing pattern for when paper should reach a certain sensor, and if it doesn't, then a jam error will occur.
Jul 18, 2007 | Brother IntelliFax-2820 Laser Fax
Canon CFX-L4000 Plain Paper Laser Fax Logo
140 people viewed this question
old marine
old marine
