Question about HP LaserJet 6p Printer
Windows xp with not recongise HP Laserjet 6p when plugged into a usb port
When printer port connected to window xp media - new hardware is found
  • carlson1973 Dec 18, 2007
    I am having the same problem. I have Windows XP and it will not recongise the hp 6p connect by usb.
  • Anonymous Jan 02, 2008
    I am using Vista and having the same problem. No response what-so-ever from the printer, no matter what I do.
I have a 6P printer. Previously using win 98 no problems. Upgrade to win xp last year cannot pickup from C drive. What is the problem? My win xp is an oem version that came together with my DIY Computer. If not where can I download the xp version? How to analysis the problem n what is the cause that cannot pickup C drive. thanks..pat marfy
Posted on Apr 23, 2008
My 6P can test print. But cannot pickup paper from C drive. Previously I used win 98 no problems. After I upgraded to XP problems arise. Which it does response to xp which my friend said it should. Can u tell me where to download the driver. My win operating for xp is oem. What is the cause that cannot pickup c drive? Any advise? Thanks..pat
  • 589 Answers
To my knowledge, the 6P isn't a USB printer, it's parallel port only. Are you using a USB / parallel port adapter? If so, I believe that's the root of your problems - the adapter.
Try hooking it directly to the parallel port (shut the PC and printer down before doing so).
Upon restart, Windows will detect it, and may or may not "know" the model, so you may have to choose it from the dropdown boxes.
If it works when directly connected, you will need to either locate drivers for the adapter (if any), or manually configure it under the printer port properties.
If you need more help, let me know. These are great little printers - once you get them to work!
Posted on Jan 08, 2008
  • 4 Answers
When it shows the message new hardware found click on "start" then click on "printers and faxes"Select the option on right side 'add printer" or select from file menu "Add printer" click next if insert installing CD Disk which came with Printer written Divers then click next now computer will start looking for Printer's Driver
other Subjection is
when it shows new hardware found message click on that message Insert Divers CD which came with that Printers Select the option to install driver from CD
Another subjection is Install the CD which came with Printer
Actual you don't have to any thing Insert CD It will auto play and
start installing just read the caption and select the alternatives
Best Of luck
Posted on Jun 05, 2008
Paralell print cable to usb adapter
go to your control panel & delete the printer, shut down & restart turn the printer on after restart see if the computer sees the printer if not try reinstalling if this doesn't work possibly the adaptor
Dec 22, 2011 | HEWLETT-PACKARD LaserJet 6P / 6MP (H3966A)...
My Officejet Pro 8500 Wireless will not print in landscape mode no matter what I try. Last time I had this problem, HP had me install a generic printer; but I don't remember what exactly I had to do...
here's how:
  1. Click Start .
  2. Click Printers and Faxes folder.
  3. Click File . Then select Add printer . NOTE: This step launches the Add Printer Wizard .
  4. Click Next .
  5. Uncheck the Automatically detect and install my Plug and Play printer checkbox.
  6. Click Next . The Select a Printer Port window displays.
  7. Click Next . The Install Printer Software window displays.
  8. Select HP from the Manufacturer list .
  9. Select hp deskjet 990C model from the Printers list.
  10. Click Next . The Name Your Printer window displays.
  11. If the printer name is correct, click Next .
  12. Click Next . The Printer Sharing window displays.
  13. Select No when the message Do you want to print a test page displays.
  14. Click Next . The Completing the Add Printer Wizard displays.
  15. Click Finish . NOTE: At this point, the driver installation portion of the process is complete.
  16. Connect the USB cable to the printer and the computer. NOTE: Windows will start to Plug and Play the device.
  17. Click Cancel for each Found New Hardware Wizard window that is prompted. NOTE: The number of Found New Hardware Wizard windows prompted by Windows will vary depending on the device plugged into the computer.
  18. In the Printers and Faxes folder, click the hp deskjet 990c printer icon.
  19. Click File . Then click Properties .
  20. Select the Ports tab.
  21. Scroll to USB00x Port and check the checkbox for the port.
  22. Click Close .
Jun 03, 2011 | HP Officejet Pro 8500 Wireless All-In-One...
I have hp printer laserjet p 2055dn I got this error on printer screen b0605 then I tried the solution from hp website ...
It is posible to have problems with your usb cable. Othert possibilities is that the printer usb port is broken
Mar 24, 2011 | HP P2055DN LaserJet Monochrome Printer
HP 1010 Laserjet drivers in windows 7 support
try going to the hp web site and downloading the correct driver for the printer
when finished , right click on the printer , click on the compatibility tab and tick box , highlight win 7, apply and ok
Apr 04, 2017 | HP Computers & Internet
Windows 7 driver for Laserjet 6P
you will need an actual parallel port to connect that printer. If the new system doesn't have a parallel port, then I'd either:
  1. Install a parallel Port expansion card
  2. Get a USB Printer
Jan 25, 2010 | Computers & Internet
I get a pop-up after I've sent a doc to print on the office-shared LaserJet 6p. Just started after install of new PC (Windows XP Pro).
Go to control panel, printers & faxes.
When you see your list of printers, from the main menu choose File - Server Properties.
A window will pop up. Go to Advanced tab, and uncheck the "Show informational notifications for network printers" and the one above as well should be unchecked.
No more popups :)
Please come back with a testimonial if helped :)
Dec 23, 2009 | HP LaserJet 6p Printer
HP Laser 4L driver for USB port
Not all USB adapters are the same, you need the one that is made for your printer, I would try a different adapter before going too deep, because when you plug it in your computer should see it even without drivers.
Jul 21, 2009 | HP LaserJet 4L Printer
Proper plug for laserjet printer into my HP 761n desktop
unplug all the connection again.
plug in one item at a time, and wait till the computer finished the detection. If the computer can't detect the USB. try another USB port. till all of you devices are connected.
Apr 09, 2009 | HP Computers & Internet
Continuous garbage text when connected to pc
In reading this HP forum I have found many other LaserJet 1100 owners who are trying to do the same thing as you.
Many of them recommend various cable solutions from Sewell. When you contact Sewell, make sure to specify your printer model, and ask what specific cables and/or adapters you need to make it work vis USB. They sound quite knowledgeable, and seem to have dealth with this before.
Mar 06, 2008 | HP LaserJet 1100 Printer
HP LaserJet 6p Printer Logo
862 people viewed this question
Ben Johnson
