Question about HP 1040 Plain Paper Inkjet Fax
Installed a brand new cartridge in hp 1040 fax but prints very poorly(light )
The print quality is not good even after installing a brand bew cartridge in hp fax 1040 fax machine
please advice
  • Anonymous Dec 07, 2007
    PROBLEM: printing produces a 2-inch band of alternating dark and light streaks lenght-wise in the centre of each page.
    CORRECTIVE MEASURES TAKEN:
    1. Putting machine through processes of ALIGNING CARTRIDGE, CLEANING CARTRIDGE,
    2. Manually cleaned all areas listed for cleaning in the user guide.
    William Haerrison
    Genius:
  • 1,003 Answers
Remove the new cartridge
TAKE A MICROFIBER CLOTH MOISTENED WITH RUBBING ALCOHOL AND WIPE THE PRINT HEAD ( THE PART OF THE CARTRIDGE THAT CONTACTS PAPER)
REINSTALL THE CARTRIDGE THEN TEST
ALSO YOU MAY WANT TO WIPE OFF THE CONTACTS ON THE BACK OF THE INK CARTRIDE WITH THE MICROFIBER CLOTH MAKING SURE THERE ARE NO FINGERPRINTS ON THE CONTACTS
Posted on Jan 18, 2008
My hp 1040 fax will not print after replacing ink? yes i removed the tape
Replace right away your fax machine and your telecom line subscription! Time to switch to a cloud-based fax service: no ink, no paper, no cartridge. The internet fax service is always on, always ready - 24 hours a day, 365 days a year.
Jul 25, 2013 | HP New 1040 Inkjet Fax Machine W built in...
After installing an off brand cartridge for a Gestetner copy/fax machine, it only printed half pages and the printing was poor. They said the brand name cartridge was no longer available. please...
There are many different companies that sell compatible toner, and the quality varies greatly. You should try getting your money back from the company you bought that toner from, and find a new supplier if you can't get it from Gestetner. Premier is a company that sells compatible toner for many different machines, and they usually get pretty good reviews.
Aug 05, 2010 | Gestetner DSm620d All-In-One Laser Printer
How do you open for ink replacement?
Removing an empty print cartridges Follow the steps below to remove an empty print cartridge:
  1. Press the Access Cartridge button on the control panel. The cartridge carrier moves to the remove/install position. Figure 1: HP Fax 1040/1050 control panelc00253378.gif 1 - Access Cartridge button
  2. Open the control panel and cartridge compartment cover (it will click and remain open). Figure 2: Opening the control panel and the compartment coverc00253379.gif 1 - Control panel 2 - Cartridge compartment cover
  3. Pull the cartridge toward you until it releases from the print cartridge cradle and then remove it. Figure 3: Removing an empty print cartridgec00253380.gif 1 - Pull cartridge towards you 2 - Remove cartridge from print cartridge cradle
Installing a new print cartridge Follow the steps below to install a print cartridge.
  1. Remove the new print cartridge from its packaging and, being careful to touch only the black plastic, gently remove the plastic tape using the pull tab. CAUTION: Do not touch the copper-colored contacts or ink nozzles. Touching these parts can result in clogs, ink failure, and bad electrical connections. Figure 4: HP 20 print cartridgec00259017.gif
  2. With the cartridge compartment cover open, insert the print cartridge into the print cartridge cradle with the contacts facing into the unit. When the cartridge is seated in the print cartridge cradle, push the top of the cartridge towards the back of the unit until the print cartridge clicks into place. Figure 5: Inserting a new print cartridgec00253382.gif 1 - Insert the print cartridge into the print cartridge cradle 2 - Push the top of the cartridge until it clicks into place NOTE: If the cartridge moves loosely in the carrier, it has not clicked into place. Repeat this step.
  3. Close the cartridge compartment cover and control panel.
  4. Press the Start/Enter button.
  5. On the keypad, press 1 if the replacement print cartridge is new or 2 if the replacement print cartridge is old. NOTE: When you put in a new cartridge, you must choose 1: New .When you put in a used cartridge, choose 2: Used . This helps you to check the correct amount of ink you have left.
for more information follow the link:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00253364&tmp_task=useCategory&lc=en&dlc=en&cc=ca&lang=en&product=425911
Jun 18, 2010 | HP 1040 Plain Paper Inkjet Fax
Poor photo printing quality with new color cartridge
Shaking these cartridges does nothing except give you a little exercise. If this is a brand new HP cartridge you are having problems with I would return it to the store you purchased it from. HP brand cartridges should not give you these problems right out of the box. The print defects you are seeing are due to a dried up or clogged print head. If you like you can try hydrating the print head on a water soaked paper towel until the ink starts flowing, but there's a risk you will cross contaminate the colors.
Oct 08, 2009 | HP PhotoSmart C4480 All-in-One Printer ...
Hp 1040 ran out of paper/after restocking now prints blank pages
Even though the toner was shown at 1/2, I had the fax machine operator install a new cartridge. Problem solved!
Aug 24, 2009 | HP Office Equipment & Supplies
I have a Samsung fax machine, model SF-3100. It is about 9 years old and has always worked very well for me. Now all of a sudden the print quality has got very poor, very quickly. The first I noticed was...
Try cleaning the print heads with rubbing alcohol to remove any dry ink, also clean the rollers too.
If the unit has a reset button or option i suggest you try that.
Good luck.
Aug 06, 2009 | Office Equipment & Supplies
Hp 3015 prints light with new oem cartridge
Machine may be in econo mode. To enable/disable.
Hope this helps
  1. open the Printer Properties (or Printing Preferences in Windows 2000 and Windows XP).
  2. On the Paper/Quality tab or the Finishing tab deselect EconoMode check box.
Apr 01, 2009 | HP LaserJet 3015 All-In-One Printer
Not Printing?
Buy a GENUINE HP ink cartridge. I think your cartridge is dried up.
Dec 19, 2008 | HP 1040 Plain Paper Inkjet Fax
Deteriorating Print Quality
This is Maltesecross. Turns out that the faintness of my printed pages was in fact due to a low ink cartridge, even though some pages printed out fine and others half-good. Eventually, all pages turned faint, and upon re-installing the driver, I got a low-ink warning (the first one ever). Putting in a new ink cartridge solved the problem for me.
Oct 21, 2007 | HP Photosmart C3180 All-In-One InkJet...
HP 1040 Plain Paper Inkjet Fax Logo
243 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
