Sharp AF-S85FX Thru-Wall/Window Air Conditioner
Problem for Sharp AF-S85FX Thru-Wall/Window Air Conditioner
E1 Flashing on display, air cut off
By topernie on Aug 23, 2009
My window unit A/C is a sharp energy saver, it just now quit working and is flashing E1 on the display, I've cleaned the filter and hit the re-set on the cord, it comes on and cuts back off in about a minute, it is not cooling during the minute it is running.
Solution #1
posted on Aug 25, 2009
Not Rated)
krbjmpr
Rank: Guru
Rating: 90%, 59 votes
There are steps listed in the user manual which can be downloaded from:
http://www.sharpusa.com/...
/air_man_AFS60FX_S80FX_S85FX_R80FX.pdf
You also need to hold the power button when plugged back in. If that doesn't work, there is another step as well.
Was this helpful?
Yes
No
Popular Solutions for Sharp AF-S85FX
Questions and Unsolved Problems for Sharp AF-S85FX
Do you recommend Sharp AF-S85FX Thru-Wall/Window Air Conditioner?
Answer
Answer
The boiler won't ignite, i turn it on the correct lights come on (i can hear noises and click but... (More)
Answer
I've tried the "hold on to power button while resetting" methods (and similar variations).... (More)
Answer
My window unit cuts off and displays E1 flashing. I have unplugged the unit, cleaned the filter and... (More)
Answer
I have a sharp window unit that has worked for the last 4 years or so. I was installing it this... (More)
Describe your Air Conditioners problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Air Conditioner Experts
Top Air Conditioner Repairmen
Service and Repair, System Maintenance, Advantage...
Aire Serv Heating & Air Conditioning
ARS
(866) 800-3823
When it comes to air conditioning systems,...
ARS
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
