Question about Brother MFC-5440CN All-In-One InkJet Printer
Black ink is reading empty
I changed my black cartidge and it was full and i went and got a new one, thought it was a defect and the same thing is happening the black is not printing
  • 832 Answers
This might be due to generic ink. The -wrong- ink will clog the micro filter infront of the nozzels. This cant be fixed anymore.
BUT you might try the following:
(the carts should be nearly full because the procedure will consume some ink)
make sure that the cart is placed well and secured.
press menue then start mono (black copy button) then fourtimes arrow-up button (tel.index). machine will be in maintenance mode. press 7 then 6 then 4 then start mono. machine will refresh tubes and ph with fresh ink and do some cleaning procedure. after maintenance is shown again press 7 then 6 then 3 and start mono to run a power purge. Leave maintenance after machine has finished by pressing 9 then 9. Run a quality test print by pressing ink etc.
If you still cant see any BK the ph is definitly clogged and has to be replaced.
Posted on Dec 04, 2007
False ink empty
Are you sure its exclamation mark?..
This warning message related to print head. (warn out). When you are replacing ink tube assembly use dummy print heads to do the priming (new ink tubes are empty & they have to fill with ink)..
Action: Remove all cartridges and print heads, switch on the printer follow the screen message.(Insert cartridges first next dummy print heads).once its recognizes cartridges then it switch over to print heads,insert dummy print heads. Once printer recognized the dummy print heads, printer will perform priming, during priming dummy print heads will filled with respective inks.(follow the display message)Remove dummy print heads & insert normal print heads. Wait till printer recognizes print heads, load the paper & wait till performs the calibration, once calibration is successfully done issue closed.
If calibration not successfully done, check align print out for which print head is not printed properly, replace it..
Pl ensure that minimum 50% ink levels required in cartridges before performing the priming. Best of luck..
Dec 03, 2012 | HP DesignJet 500 InkJet Printer
Hi havent used this printer in a while and set it up to my laptop, i tried to print and it wasnt working so i thought that it was the ink as it hadnt been used for a while so i went and bought all new...
Remove and then replace the black ink. Make sure you remove any sealing tape that may be covering holes in the ink cartidge. While the ink cartidge is removed, you might also want to give it good shake. Finally, the cartrice may juat have been too old - they age even when in the packaging, and most have an expiry date.
Nov 08, 2017 | Epson C64 InkJet Printer
I have replaced the black ink and it still request that I install a new cartridge?
This sounds like a defective cartridge. I would first try changing to another new black ink cartridge (preferably OEM) to eliminate the printhead as the culprit. If this was an aftermarket or reloaded cartridge it is probably defective.
Let me know if we have to troubleshoot further. Thanks.
Jan 09, 2010 | Dell 948 All-In-One InkJet Printer
No printing
hi,
Check your black ink cartidge. it may be empty.change it with new balck cartridge
this problem may also be due to cartidge holder .
clean cartrideg holder with moist cotton with petrol or some other cleaning liquid as nail polish remover. clean properly the cartirdge socket and mainly the contact point of cartridge socket
Aug 20, 2009 | Lexmark X3650 Printer
I only want to use the black ink, not all 4 colors
Color printer have sofware installed which stops all printing inless their is ink in all containers. No, their is no way around it. Someone would be rich making a kit to do so. since I see this question over and over  at least once a week.
Mar 09, 2009 | Brother MFC 420CN All-In-One InkJet...
MP530 Print Cartidge Problems
Hi shortiered,
Sounds like your orginal driver installation has become corrupted. Try this: completely remove unit and its software from your computer, not forgetting to unplug all cables. Go to the folling url(copy and paste in the address bar) for the latest software for your unit. It's easiet if you create a new folder on your desktop and name it mp530 drivers, save down load here. Install software first, reboot and plug your cables in, windows will reconize new hardware and install it for you or it may ask if you have installation disk or installation file, click yes and direct download to the folder you created for your new drivers. I hope this helped a little, if not, hit me back, we have other options.
Thanks for using FixYa.com
Sincerly, cyyyd7
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&fcategoryid=123&modelid=13371#DownloadDetailAct
Oct 09, 2008 | Cannon MULTIPASS C530 Printer
Mfc-240c reading offline and empty black
Regarding your problem: If one of the color ink cartidges is out of ink, the MFC 240C printer will not operate when you only install a black ink cartidge. It requires that all four catridges have ink available in them for it to function. When you examine a cartridge it may appear that it has a little ink in it when you get message that the cartridges needs to be replaced because a little ink remains to prevent the print head from drying out. JLHinton1@bellsouth.net
Sep 24, 2008 | Brother Multi-Function Center MFC-240C...
Ink Cartridge
Some of Epson's cartridges went bad that way. It may be a bad cartridge. Get a new one, pull that one out and see what happens. If it works, call Epson for a refund. They had a class action suit for that type of thing, they lost and paid off. I would think they will help you right away.
C
May 31, 2008 | Epson Stylus CX6400 All-In-One InkJet...
After refilling cartidge it still says it is empty
IB4G2008: Do u actually have a solution or a better driver for this printer OR are u just out to promote your site?
Your solution is not helping & if u think it is, pls oh pls,let me know of a DIRECT link for it, as i havent found anything that makes the problem better, nor a better driver for that particular printer.
Pls advise.
eldiablo2008
Jan 23, 2008 | Lexmark Z1420 Printer
Brother MFC-5440CN All-In-One InkJet Printer Logo
109 people viewed this question
James Cagle
James Cagle
Victorman
Victorman
Norman  J Weimar Jr
Norman J Weimar Jr
