Question about Sharp UX P200 Plain Paper Thermal transfer Fax
Can't receive fax but can send
We recently relocated our fax machine - same line number just different location and since then we can send a fax but unable to receive. Machine is a Panasonic Panafax UF7070 - please help!!
  • Anonymous Mar 18, 2014
    the telephone line is working. the paper does not feed when trying to make a copy or send a fax
  • Anonymous Mar 26, 2014
    unable to receive fax
  • 54 Answers
Call your cell phone from the fax machine and check the caller ID to make sure that it is the correct number for your fax machine. Next, call the fax machine from you cell phone, and make sure the fax machine rings. Problems like these are almost always a phone line issue, not the machine.
Don't forget to rate your solutions please.
Posted on Dec 04, 2007
Check the mode your fax machine is in..some models have a Mode button located on the machine that changes from Fax to Fax/Tel or sometimes both are on the same time. If your line is a dedicated line make sure the mode is on Fax only.
Posted on Jun 25, 2008
Hello, I have a "Sharp" fax machine model UX-P210 and It's been hardly used.
I can receive a fax no problem, but I cannot send one. After trying to send a fax, the message on the screen indicates "Line problem", I have tried everything including verifying the line cord, checked the manual reference guide's solutions, etc.. If I can receive a fax than it isn't the wire line problem for sure.
I can dial out, call out and the line tone is working,the paper goes through and everything....but always get the "Line problem" message display after try to fax out. The other fax "receiving fax" works great by the way).
Is there a set-up I must do in the set-up features on the "Sharp" fax or is it irrelevant
Can you suggest something?
Your help would be greatly appreciated.
Thank you
Posted on Oct 20, 2011
Fghbfhgkdgkbgegbjnjkbgjggdfgrgf fgdfdgwes rgghfdgr MOP YOUR MOUTH
Posted on Jul 25, 2011
    New Friend:
I have Dell1135n fax machine i cant receive fax but i can hear the tone but no print out.
Posted on Jul 19, 2013
My fax machine MX532 won't let me send a fax though the machine
This is probably an issue for the receiving fax. Try this:
1. Find a piece of paper and write fairly large:
Call me if you get this
Your name
Your phone number
2. Send this to a different fax machine at a different company and location. If it works, then attempt to send it to the same fax you initially attempted.
- If it works then your document may be too large and you will have to send it over a couple pages (or less at a time).
- If it doesn't work then there is a compatibility issue with either your or the receiving end fax machine. You will have to find an alternative fax number to a different model fax machine. Don't expect the company on the other end to just change out their fax machine but they may have another model at a different phone number.
Another alternative - you can attempt to scan your documents and send them by email but check with your and the receiving destination security departments.
Best wishes,
Aug 25, 2016 | Canon PIXMA MX532 Wireless All-in-One...
We have the Brother Intellifax 4100E. It was working fine up until last week. Then it started not receiving faxes. We can copy, and send faxes, and receive the confirmation. I have checked the mode button...
Try calling the fax machine from your mobile and see if it picks up or if anything shows up on the screen of the fax machine. Is it possible that you have plugged the fax machine into the wrong telephone line? Try sending a fax to your mobile phone and see that the number is correct.
Mar 07, 2011 | Brother IntelliFax-4100e Fax
Can't get fax machine to work. I need to enter ECM mode on the machine so I can receive faxes but on the report print out it's saying mode G3. I can send faxes but can't receive them. Please...
Doubt if you need to set up the fax with ECM ( error correction mode )...a lot of fax's come with ECM these days set to ON. Don't know why because in the majority of cases the phone lines are of good enough quality that its not necessary. However, that said; I would suggest you pick up your handset and listen to the dial tone on the phone/fax line and listen to see if you are hearing static noises...if you do then its likely you have a bad line and should report it to your phone provider.
If the line is good, then I would ask you to try and make a phone call off your fax machine(assuming it has a handset) and again listen to the sounds off the line. I would then get someone locally with a fax machine to send you a test page to see if the machine works from a different number/location.
Jan 06, 2011 | Office Equipment & Supplies
Able to send faxes but unable to receive.
you need to check how the fax machine is setup for receiving faxes. i recommend you try it first without the answering machine, to see if it works. if it doesnt, then it has to do with the auto answer or the number of rings not set right, if it does work, it could be that you need to set it to check for fax while the answering machine is answering, check the manual under answering faxes.
thanks adi
Dec 10, 2009 | Epson WorkForce 600 All-In-One InkJet...
2 fax machines on 1 line
Once you place your both fax machine on same line you will keep getting this issue. Fax machine is waiting for a fax ring signal that your other machine is sending. Shut down one machine when faxing or connect your alt fax machine to a different number this way you can send faxes when need to.
Jun 09, 2009 | RCA 25201RE1 Corded Phone
I have a hp fax 1010 problems sending receiving
Are you plugging the phone line into the line jack or the phone jack on the fax machine, it should plug in to line. Also try and unplug/replug the units power cord as well as trying a different phone jack location.
Mar 25, 2009 | HP 1010 Plain Paper Inkjet Fax
Cannot recieve or send faxes
Check out the Easy Setup Instructions available here. If you can neither send nor receive faxes, you may not have the phone line connected to the correct port, see page 34 of the guide. Also check what receive mode the machine is set for. Pages 42 and 43 explain the different options and how to change the receive mode.
Mar 16, 2009 | Canon PIXMA MP780 All-In-One InkJet...
Fax will only send and not receive
Call your fax machine from a regular phone and listen for fax tones. Sender may be dialing the wrong number. Is your phone line DSL?
Sep 05, 2008 | Brother IntelliFAX 1270E Plain Paper Fax
344 Error can be caused by a few things. One of the following is occurring:
The sending fax has failed to respond to a fax command from the receiving fax due to poor line quality or fax interruption.
The sender has pressed cancel button while the reception was in progess.
In rare conditions, incompatibility has been encountered by two faxes and causes the sending fax to abandon the fax call.
Fax session was using ECM. Check your fax settings under the fax set-up menu on the printer. Disable the ECM (Error Correction Mode).
Fax at a different time to see if line quality improves.
Try relocating the fax to a differnt phone plug.
Replace the phone cord attached to the fax/printer.
Aug 18, 2008 | HP OfficeJet 6110 All-In-One InkJet...
Cannot send faxex
Did you try to send a fax to a different number? Also are you sending to a local number? Most send problems are poor phone line conditions. If you have tried to send to several different numbers with no success, then you can assume that the LIU board needs to be replaced. It costs about $40.00 from Brother for the part.
Dec 28, 2007 | Brother IntelliFax-2820 Laser Fax
Sharp UX P200 Plain Paper Thermal transfer Fax Logo
7,842 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
