Question about T-Mobile MDA Pro Smartphone
Mda exec pu10
I have just been given an MDA exec. The mini usb has broken and is loose inside. How do I get into it to make a repair without trashing the case. I have removed the 4 T6 screws in the battery bay but nothing seems to work when I try and prise it apart. Can anybody help?
2 Suggested Answers
  • 50 Answers
SOURCE: MDA is dead slow
u have to take backup of ur all data and reinstall ur OS...from "clear storage" option in ur setting...this is the only solution...use Pimbackup for backup of ur data
Posted on Mar 06, 2009
SOURCE: driver mda pu 10 to connect t computer
hello ... plz if any one can help me to get the software of O2 xda exec to connect to my pc ,, plz
Posted on Jul 25, 2009
0 characters
1 Points
I-mate JASJAR pu10 Smartphone windows mobile 5.0 data mixing, how can I get same windows to install?
...mda pu 10 to connect t computer hi where can i find the driver so can connect my foon"mda pu10" so ican take...
Jun 06, 2012 | i-mate JASJAR Smartphone
Driver mda pu 10 to connect t computer
May 04, 2009 | T-Mobile MDA Pro Smartphone
How do i disassemble a t- mobile mda cell phone?
Hay Saeedm
check out this link
I have the same issue. i just dont know how to get the parts together
Feb 27, 2008 | T-Mobile MDA
MDA 3 dead
If a device fails during a rom upgrade its as good as dead because it doesn't have enough instruction to start the process over.
Jan 17, 2008 | T-Mobile MDA
Broken USB Port on T-Mobile MDA
My daughter's MDA had the same problem. I just opened the phone and soldered the legs on the corners back to the board. You have to bend the pins on the back of the plug down to make contact with the board, before you solder. Place plug back down and line it up with contacts. If done right should work as normal. Hope that helps
Jan 16, 2008 | T-Mobile MDA
Mda not charging
Either your battery is bad or your soldered contacts on the inside to the charger port are broken.
Jan 09, 2008 | T-Mobile MDA
Usb loose
Follow those instructions to take it apart. You will need a #6 sized torq screwdriver.
Nov 12, 2007 | T-Mobile MDA
MDA phone screen is scrambled with Lines
Marc1234: sounds like the backlight is out......possibly a software malfunction.....try goign to to reinstall the software....if that doesnt work, contact htc or your service will need a replacement. if youre out of warrenty, it will be a lost cause....
Guest,: your USB port is broken, if you dont fix it yourself, you will need another phone.
Oct 17, 2007 | T-Mobile MDA
MDA (T-mobile)
Make sure that your mda is being charged with an original charger
Sep 14, 2007 | T-Mobile MDA
Usb sync charger broken on 2nd mda in 6 mos.
I'm dealing with the same problem overher in Holland. I'm looking for someone to "weld" the contacts. But you sould take a look at this website perhaps they can help you.
Dec 28, 2006 | T-Mobile MDA
T-Mobile MDA Pro Smartphone Logo
467 people viewed this question
Top T-Mobile PDAs Experts
Juriy Crook
Juriy Crook
Martin Murray
Are you a T-Mobile PDA Expert? Answer questions, earn points and help others
