Question about Bosch WFMC 3200 Front Load Washer
Bosch model 3301
Just bought this washer 2 days ago. I love the concept. It worked fine the first wash, now it stopped spinning completely. The water fills, and drains ok, but no spin cycle. I checked to make sure the delivery guys removed the shipping screws and also was able to manually turn the drum. When I put it on "spin only", the machine just sits and does nothing. Any ideas????
    President:
  • 1,294 Answers
Check your exit hose spigot, it may be clogged. This is if your filter is all clean. There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too. The exit hose should be at about 3 feet from ground level; pump pumps out over this height.
Rate me pl.....if helped.
Posted on Jan 02, 2008
Problems with BEKO WMB 751441 7.5 kg washing machine
take it back to the place you bought it from immediately and demand your money back or contact consumer affairs.
Jan 27, 2014 | Washing Machines
Washer will not spin. Cleaned drain/filter. Worked for 2 days. Now won't spin and checked drain, it is clean. The drain pump works fine. What to check next?
i had the same problem a year ago. nothing seemed to work. we even got a new washer, same problem. we ended up putting the washer on its own circuit. works fine now.
Feb 16, 2012 | Bosch Nexxt 100 Series WFMC1001UC Front...
Washer will not complete cycle stops on spin and flashes on spin
no matter which make / model of washer you have you should clear the filter regularly; i do mine every 2 weeks , just in case....i learned this the hard way when the washer wouldnt finish cycle. there may be a bit of water in the system so be prepared for an amount of water
Oct 06, 2011 | Bosch Nexxt 100 Series WFMC1001UC Front...
I have a Kenmore washer model #110.20022011. The other day it did not spin out all the way, now it will not start at all. The fill light and lid lock light comes on, but it does not start. Water and...
A friend of mine bought a Kenmore washer model 110.20022013 a year ago. Now washer stopped in the middle of washing and a clicking sound starts, and not washing or rinse or draining
Aug 22, 2011 | Kenmore Washing Machines
Washing machine does not spin
Nexxt 100 Series WFMC1001UC Front Load Washer This washing machine tutorial will show you what to do if the washing machine does not drain or empty the water out this repair was done on a Bosch, Neff and Siemens type appliance.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Feb 23, 2009 | Bosch Nexxt 100 Series WFMC1001UC Front...
Maytag washer not agitating and not spinning fully
Pr obably a coupling between the motor and gear box, Take motor off and coupling will come out, re place it and it should be fine
Dec 03, 2008 | Maytag MAV4755 Top Load Washer
2007 Bosch Washer WFMC 3301
It may be possible that you are using too much soap. There is a turbidity sensor that checks for soap in the water. It will keep rinsing until it thinks the soap is gone. You did not state if you are ever able to complete an entire cycle or not. If the cycle never completes, it is possibly a problem with the main circuit board. Have you allowed the machine to complete a cycle?
May 18, 2008 | Bosch Nexxt 500 WFMC3301 Front Load Washer
Please help
it is the timer or, it may be a short of some kind
Apr 19, 2008 | GE WDSR2080D Top Load Washer
Washer fills/agitates and stops prior to draining
If pump works fine or still pumps out water, then it is a timer malfunction. Replace the timer and you should be fine. To locate a part number for your timer, refer to www3.sears.com with the model number off your washer.
Mar 14, 2008 | Kenmore 24032\24036 Top Load Washer
Bosch Nexxt 100 Series washer
Look into your manual, clean outlet filter & refit. Machine will not spin out if filter is clogged.
Dec 21, 2007 | Washing Machines
Bosch WFMC 3200 Front Load Washer Logo
70 people viewed this question
Top Bosch Washing Machines Experts
Marvin
Marvin
Craig Butler
Craig Butler
Carmen Mikulic
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
