Question about Sharp 32F-830 32" TV
NVM FOR TV SHARP 28JW73H
I have a tv set of model 28JW73-H , i want NVM VALUES TO CHANGE its SYS. TO B/G that iam a proffisional in tv repairing .
pls send me this value at essam_albayomy@yahoo.com
thank you
5 Suggested Answers
  • 1694 Answers
SOURCE: 28jw73h
Practice visual acuity technique! Solder any/all bad connects,look for over-heated area, check caps in power supply,horiz.and vertical circuitry.Possible slow charging cap.
Posted on Sep 26, 2007
  • 579 Answers
SOURCE: SHARP TV - MODEL 25j m100
The RF jack is solder directly into the tuner module and as long as it did not break the circuit board inside that it connects to, it can be repaired . Takes a lot of heat though to solder the jack to the frame of the tuner. Sometimes I use 2 irons to get it hot before the plastic guts of the jack melt too bad. Also is sometimes hard to cram the jack back into its mounting hole, may need to file it out some. The makers don't solder these on they are just pressed in and crimped which is why they break off so easily. I recommend using the push on type cables to avoid this problem. Don't forget to solder the center conductor into the tuner board.
Hope Ya Fix It!
Posted on Feb 21, 2008
  • 4234 Answers
SOURCE: missing resistor
1.8 ohms at 2W
Dan
Posted on Sep 23, 2008
SOURCE: my sharp tv valeo have
check your abl
Posted on Dec 11, 2011
Pls help me: xerox workcentre 24 code: 116-372
Ugh.. That is a formatter software issue. Try these resets
arrwup.gif Log Initialization
This step will delete any print or copy job that is in process, and then perform a reboot.
To execute: simultaneously press and hold the 1, the Stop, and the Power Save buttons on the Control Panel while switching on the power. Hold the buttons down until the boot up screen (5 circles) appears and the second circle starts to blink.
arrwup.gif Spool Initialization
This step will delete all pending print or copy jobs in the job queue, and then perform a reboot.
To execute: simultaneously press and hold the 6, the Stop, and the Power Save buttons on the Control Panel while switching on the power. Hold the buttons down until the boot up screen (5 circles) appears and the second circle starts to blink.
arrwup.gif HDD Initialization
This step will delete all pending print or copy jobs in the IOT job queue (DC 3535: does not delete any job data stored in the Network Controller), initializes the IOT HDD (refer to ADJ 9.8 for details), and will and then perform a reboot. All customer data on the HDD will be deleted.
To execute: simultaneously press and hold the 4, the Stop, and the Power Save buttons on the Control Panel while switching on the power. Hold the buttons down until the boot up screen (5 circles) appears and the second circle starts to blink.
arrwup.gif ESS NVM Initialization caution.gif CAUTION
This routine will set all IOT ESS NVM values to default. Do not attempt this procedure unless there is a known-good Machine Settings floppy, an accurate Configuration Report and/or other data that will enable you to reload the correct NVM values for this machine.
This step will initialize the IOT ESS NVM (SYS-System and SYS-User) and then perform a reboot.
To execute: simultaneously press and hold the 3, the Stop, and the Power Save buttons on the Control Panel while switching on the power. Hold the buttons down until the boot up screen (5 circles) appears and the second circle starts to blink.
If these do not work the system software needs reloaded or the ESS network board needs to be replaced.
Mar 12, 2011 | Xerox WorkCentre M-24 Color Copier
Lost sound on my GE (Thomson)46GW947X1
pls. first open your tv menu and select sound & colour -sys see the sound-sys / colour-sys is maching with your country transmitiongh sys {EXP.: PAL-BG / NTSC-DK /NTSC- MN /SCEAM- I ) IF your not set purfictly pls select AUTO colour sys and set automaticly set colour & sound .[see user's menual book and set your tv.]
Oct 06, 2009 | GE 35GT695 TV
I cant make the tv with channels work. dvd is working good.can show tv channels but no sound..
pls check tv colour and sound sys. is maching with your country tv transmiting sys. [PAL-BG /NTSC-DK /NTSC- MN /SCEAM- I ] PLS. FIRST open your tv menu and find the sound-sys option and select your country colour & sound -sys.
Oct 06, 2009 | Disney DTD1363-CAR 13" TV/DVD
Sony trinitron only in blacka nd white. how do I return it to colour?
pls check your tv colour system it is not maching with your country col-sys [PAL /NTSC/SCHAM] so pls open menu and set col-sys select any one or set col-sys is AUTO see the colour pictur.
* NO colour [B&W} pictur
[1] cabel singnel is wek.Pls. check cabel canaction re set pin or cabel canaction.
[2] pls tune ch. set Auto serch or fine tune to set ch.
if not colour pictur then problum is inside of your colour tv set.
Oct 05, 2009 | Sony FD Trinitron WEGA KV-21CL10 21" TV
Tv will not come on , some guy came out and said its the low voltage pwr supply, whats the cost of the supply, what does it look like and is it easy to replace if you know how to handle a soldering gun, tv...
just take your tv to a near w/shop, and ask a tech, to check components, on the power supply.
components like transistors, diodes, ic if any on thepower supply,all eletrolitic capacitors values, and change all changed value capacitors. because if capacitors change values they change oscillation hence increasing current output.
if you do that your set will come back to life again.
Apr 29, 2009 | Sharp 27K-S180 27" TV
No power
Automatic off when turn on sharp model 20v j50m pls. help.
Mar 20, 2008 | Televison & Video
Sharp 28JW73H Green tint with lines across screen
Note: unmatched Make / model info........please clarify...T.
Nov 16, 2007 | Panasonic PT-52LCX66 Projection Television
28jw73h
Sep 25, 2007 | Sharp 32F-830 32" TV
Sharp 28JW73H
Lynda, could be why someone was selling it? It could have a bad connection inside the set somewhere that needs to be addressed asap as it will get worse, or a power regulator is bad. This will oneday make the set not turn on anymore without a repair job. Also make sure the outlet your pluging it into isent loose. Sorry i couldnt assist you more with this. Good Luck
Jul 23, 2006 | Sharp 32F-830 32" TV
Sharp 32F-830 32" TV Logo
64 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
