Question about Dell Inspiron 2200 Notebook
Microphone are not working
Audio input (microphone) doesn't work, I can hear the speakers but microphone are "off" how fix it??
  • 58 Answers
Hi!
it could be a slot issue. to make sure that its not the slot or port, try a known good microphone from a friend or from the store. then if the known good mic still doesnt work, then its the slot or the settings on you sound and game controllers are not setup for the mic. Check control panel and go to sound and audio devices and check the settings for the mic. If the settings are okay then it could be the slot or the port.
Karlox
Posted on Dec 13, 2007
Stopped working, all i hear is high pitched sound when attempting to record audio
Check the volume levels of your computer's speakers.
• Check if your computer's speakers are muted either in the operating system or on the
speakers themselves.
• Check your operating system's audio input settings.
• Check the microphone's volume and on/off settings.
• Restart computer.
If none of these steps resolve your issue, I would recommend pursuing replacement options
Aug 09, 2013 | Dynex USB Microphone
How to turn speaker on acer d257
Make sure you have installed the Acer's audio driver for your model laptop. Test the audio by playing a music CD.
SKYPE MICROPHONE PROBLEM
If the person cannot hear you then, either your microphone driver not installed or not working OR the microphone is not configured in Skype.
To test your microphone then click on Start - All Programs - Accessories - Entertainment - Sound recorder. Then record your voice and then play it back. If this is OK then the microphone need to be configured in Skype.
To configure the microphone - Open Skype - Tools - Options - Audio Settings for the Microphone THEN click on Save.Also while you are in the Audio Settings select the your Audio card in Speakers.
Nov 10, 2012 | Acer Computers & Internet
I have a acer with the acer crystal eye webcam built in it. do it have a microphone with it. if so how do I get it to work?
The Acer with crystal eye webcam will also have a built-in microphone. The webcam is in the center at the top of the screen. The built-in microphone is typically half-way between the edge of the screen and the webcam. It is a little opening with a microphone logo beside it. You can test both audio input with the built-in microphone and the audio output with the built-in speakers by doing the following....
1. click start > Control Panel > Sounds and Audio Devices
2. in the Sounds and Audio Devices Properties click the Voice tab, then click the Test hardware button
3. in the Sound Hardware Test Wizard window click the Next button, if required, click unblock...
4. speak into microphone to do the Microphone Test. Recording meter will show movement if it works.
5. click Next button to do the Speaker Test. Microphone input is now output on the speakers.
6. click Next button when finished doing the readings and click Finish to close the wizard.
Mar 20, 2011 | Computers & Internet
My built in mic is not working properly,when I call somebody hear me but I don't hear him!
If the other person can hear you then YOUR microphone is working fine.
The reason may be that his microphone is faulty (solution below)
Otherwise:
  1. Make sure the volume is turned up on your speakers (and if using external speakers they are plugged in / turned on) . To increase volume go to Control Panel, Sounds & Audio Devices and adjust the slider on "Device Volume" . Also click on "Loudspeaker Volume" and adjust the sliders there as necessary.
  2. Can you hear other sounds (like playing music or videos)? If yes then you need to adjust the audio settings for your calling program (skype or whatever). Launch the appropriate program Click on Tools and ' test audio properties' on the program tool-bar. Follow the instructions on the screen.
  3. Try plugging in headphones and see if you can hear better on them.
Using a microphone with computer
To use any microphone with your computer you will need to enable it in control panel. The following instructions are for Windows XP but are broadly similar for Vista and Win7
Click START, CONTROL PANEL, SOUNDS & AUDIO DEVICES
Click VOICE
In the Sounds & Audio Devices Properties window locate the SOUND PLAYBACK box and click the VOLUME button. Make sure that there is not a tick (check-mark) in the MUTE box against microphone in the list of devices and that the volume slider is at the top of the scale.
Also make sure that the MUTE ALL box isn't checked before closing the window.
Now click the VOLUME button in the SOUND RECORDING BOX. Here you need to SELECT microphone as an input source for recording (as opposed to un-checking mute in the playback controls).
NOTE if microphone is not listed in the 2 sets of volume controls click OPTIONS, PROPERTIES on the tool-bar and place a check against microphone in the list entitled 'show the following volume controls' and then click OK.
That should be it.
Feb 09, 2011 | Toshiba (P000257700) Microphone
Yahoo voice call not working
Make sure ur mic settings are configured properly.
Open Yahoo Messenger Window, goto Actions > Call Setup as seen below:
Now follow the step by step instructions, and select the input and output source from the drop down menu on the setup screen until the microphone and speakers are working properly with this wizard.
Yahoo Audio Prefernces
Go to yahoo messenger main window , Messenger > Preferences > Calling & Audio
In this setup, select the microphone input from the dropdown, and similarly the speaker settings.
After selecting the proper input and output, the voice char worked just fine with me. Hope it helps you solve your problem.
Aug 26, 2010 | Yahoo Messenger
Using microphone with aux in feature
No. The aux audio level input is much higher than the microphone output (about 100 times). That's why when you connect the microphone at the aux input (assuming that you have the right jack adaptors) your voice can't be heared ty the speakers (in fact if you scream or speak loudly at the microphone it's possible to hear something in very low volume from the speakers). But there is a solution. If you desperetely need that function, you can buy a "microphone preamplifier", that's the way you can ask for, at your local market.
Post for any help.
Feb 24, 2010 | Audio Players & Recorders
Hello, i cant hear the microphone over the speaker
Make sure your microphone is not muted in the control panel, under sounds.
Nov 20, 2009 | Gateway Computers & Internet
I have a Satellite M35X-S114 that has a mic problem. I was using Skype with no problem and then it just stopped working. I hear through the speakers and headset but no mic. I also tried a new headset with...
Sometimes programs like Skype will lose the Mic settings and chose another input channel. Check your operating system's audio settings under something similar to "Recording" and see if microphone is checkboxed and turned up. Also, make sure it is not muted on Skype and/or the operating system.
If you have Windows XP, for example, look for the audio settings icon (little speaker) just left of clock area. Open and go to "options". Choose "properties" then "Recording". Look that your microphone is "Selected" with a checkbox and is turned up. To hear yourself during this, you will need to go back and choose "Playback" instead of "Recording" and de-select "mute" (if checked) for microphone and turn it up to see if you hear yourself talking over the speakers/headphones.
Also, check the Skype settings for microphone and that Skype has the correct sound device selected for input - being your microphone and not another device.
Also make sure that there is not a manual, physical volume adjustment for the microphone on the laptop case itself. Could even be a mute button.
Oct 16, 2009 | Toshiba Computers & Internet
My internel microphone doesn't work with Skype -
You need to check the Microphone setting in Skype.
Open Skype, Click on Tools - Audio Settings, then in Microphone settings click the down arrow and select the built-in microphone then save the settings.
If the microphone you selected doesn't work then select a different one.
Jul 04, 2009 | ASUS W5Ae PC Notebook
Dell Inspiron 2200 Notebook Logo
57 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
