We have removed the factory radio. The instructions from the new Pioneer 2-channel amplifier say to locate the turn-on wire (usually BLUE) but there are severed blue wires toing into the back of the radio. None are obviously a turn-on wire. How do I dtermine which one it is? ALSO, in the section "Making the Signal Connections" it says to connect the RCA patch cables to the RCA outputs on the radio- BUT the radio has NO RCA outputs. Help please. Signed, Robin mother of 17yr old son who's trying to install
Comments:
Aug 28, 2009
- Thanks for the tip. Went to Walmart and they don't make a kit for the 1991 Lexus ls400. So, he has everything attached except the signal leads to run the subwoofer.
Ok, Need to figure which wire (color) from the back of stock radio feeds the signal to the amp and subwoofer.
Lexus 1991 ls400
thank you so much.
Robin Tietz
Hi Robin, I think I may be able to help. The instructions are referring to an aftermarket stereo and not the factory one. Most aftermarket stereos have a blue wire that runs either the power antenna or an accessory that turns on with the radio(amp, eq, power crossover,ect.) As far as the RCA cables, once again, most aftermarket stereos have RCA outputs for an amplifier. Factory ones don't.You can go to Wal-Mart or ABC warehouse and buy a wire harness just for this particular application and then all you do is plug the harness into the factory harness, everything is all pre-wired so there is no guesswork involved and no mistakes.
Was this helpful?
Yes
No
1 person thought this was helpful
Asker's Testimonial
Great advise! Went to Walmart, they had harnesses but unfortunately they don't make the harness specific for the 1991 Lexus ls400. Bummer.Thanx again!
" - tietzrwer
i have a dad 1504 and my amp turns on and the green light come on but i dont get any power to my...
(More)
i have a dad 1504 and my amp turns on and the green light come on but i dont get any power to my subs i think my rca are blown on my amp?!
my playstation3 is new, i hooked it up, and it wont go to the menu,it says that the amount of power...
(More)
my playstation3 is new, i hooked it up, and it wont go to the menu,it says that the amount of power to the usb is reached., and that i have to remove a device., could someone tell me what means?
What settings should i have my 760 watt pioneer amp set at for amp gain and bass boost in order to...
(More)
What settings should i have my 760 watt pioneer amp set at for amp gain and bass boost in order to have the best sounding hit from the subs?
Hi there, I have rubicon 204 amp., it starts after 30 min when I turn on him and works erratic (1...
(More)
Hi there, I have rubicon 204 amp., it starts after 30 min when I turn on him and works erratic (1 sec works 2 sec doesn't work, etc...). Power led is on, as have to be. Sometimes works OK. So, where the problem is ?
