Question about Avanti ER24AW-1 Electric Kitchen Range
Avanti er24aw1 broiler works fine but oven is inop. Don't see any way to change the lower coil for baking part of oven. Thanks, Frank
  • 1 more comment
  • Anonymous Jun 23, 2008
    Oven does not heat up, all else working fine.
  • Anonymous Dec 24, 2008
    same problem. looking for the element but can't find it. No response from theavanti.com
  • RellyRell Dec 24, 2008
    I have the same model electric range and I've been struck with the same issue. Avanti's part number for the lower heating element is 10110533. Oh and theavanti.com has nothing to do with AVANTI appliances. I guess I will start my search for the element also.
  • 3 Answers
Call avantiproducts.com sales (service didn't work) and get a replacement bake element. It was about $35 including shipping. Download the manual from the site and study the structure. Uncover the back cover using standard phillips screw. TO DO THIS, SHUT DOWN YOUR HOME BREAKER AND MAKE SURE THE OVEN OPERATION LUMP DOES NOT LIGHT. OTHERWISE YOU WILL BE EXPOSED TO HIGH VOLTAGE. Additionaly use multimeter to make sure the voltage is not there. Remove back inner cover. You can't remove this inner cover completely because of the thermostat line but try to make a work space in the lower part of the oven. The bottom element cover can be uncovered readily without any screw or pin. At this point you have access to baking element from the bottom of the oven. Loosen two nuts to remove the bad element. Reverse the procedure to install the new element.
Posted on Jan 25, 2009
These ovens are horrible. I have two of them in my apartments. The hidden bake elements are a pain to replace, and they burn out in less than 12 months of light use. Don't buy Avanti!
Posted on Aug 07, 2012
  • Steve Bachman
    Steve Bachman Feb 22, 2016
    I've now replaced the elements in my 2 Avanti apartment ovens a total or 7 times over a period of 5 years. I rent mostly to graduate students who rarely bake, yet the longest life I've seen before burnout is about 2 years. The shortest is about 6 months. There is nasty fiberglass insulation that you need to work around to replace the elements. WEAR A MASK! If is much more friable (airborne dust) than the type used in building walls. It breaks down over time from the heat, making it even worse. Avanti will not sell replacement insulation, nor will they either provide specifications or suggest any suppliers. This is a very badly designed product, with poor technical support.
You need to replace the bake element. You need to remove the entire back panel to get to that areal
Posted on Jul 13, 2009
Flow plug
even though the ignitor seems to glow bright orange,it still maybe weak,as in not enough current to open the gas valve,an easy test is to just swap out or interchange the broiler ignitor and bake ignitors and see if this takes care of your issue on the lower bake side as most units use the identical ignitor for each upper and lower manifolds and the gas valve supplies both the bake and broiler manifolds depending on which you choose to use bake or broil
May 28, 2012 | Jenn-Air Chef Gas Oven Range Ignitor Flat...
I have a 30 inch Frigidaire self cleaning oven. The oven will no longer heat up in a normal amount of time using the bake function. Sometimes I can smell gas when using bake. It cant reach the desired...
Sorry to read about your problem, I hope this helps you out.
Bad gas control valve or oven temp control
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
Dec 22, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
Have spectra extra large self clleaning oven never had trouble oven does not work i was baking and it worked fine. Then when I went to bake later and turn the oven on it clicked but never got hot. Yhe...
Hello - Most troubles with ranges occur during the "self-clean" cycle. The problem- no lower burner- could be a bad ignitor. Part is 40-75$ Fairly easy to install, or have done for about 75-100$ Let me know if info helps- I have more if you need it - Thanks- ED
Mar 03, 2010 | GE Profile Spectra JGBP90 Gas Kitchen...
GE PROFILE JBP79 OVEN RANGE - OVEN DOESN'T BAKE. CLOCK, BROILER, CLEANING WORK, LIGHTS WORK WHEN CLEANING OVEN. COIL ON BOTTOM DOESN'T GET HOT BUT BROILER COIL DOES.. WHEN CLEANING OVEN LIGHT WORKS WHEN...
Could be the sensor inside the oven.Mine burnt out when using the self clean feature. Two screws un-plug replace with new. Part less than 15 dollars
Jan 08, 2010 | GE Kitchen Ranges
I have a ken more range and the broiler stay on the control for the broiler need to be replace but i don,t want to put lot,s of money in it i disconnect the top element can i use my oven to bake or do i...
NOOOOOOOOO
you may be able to disconnectr the element
after doing so trey heating your oven
some need the broiler to preheat properly some dont
b ut do not connect them together
Sep 18, 2009 | Kenmore Kitchen Ranges
The oven doesn't work ,the ignator doesn't light up. no gas coming oven doesnt work. it wont ignite. i smell no gas coming in. burners work fine
ok try your broiler if it lights change the glow bar in the lower oven the glow bar acts as a safty if it doesnt reach a certain temp the safty valve wont alow gas to enter the broiler and bake are on seperate ignighters if neither work change the safty valve
Feb 11, 2009 | Amana ARGS7650SS Gas Kitchen Range
Oven/Broiler Igniters for KitchenAid range KGST307
Oven bake ignites usually have lifetime 5-7 years. If igniter glows but gas not came in - replace igniter. Same with broil igniter.
I’m happy to help further over the phone at https://www.6ya.com/expert/vitaliy_f406165329c75ede
Dec 09, 2008 | Ovens
The oven broiler work but the baking part doesent.
hi thanks for the question I would replace the bottom igniter it has failed thanks the appliance doc
Sep 30, 2008 | GE JGRP17 Gas Single Oven
Broiler will not light. Oven & top burners work fine
hi thanks for the question check to see if the broiler igniter is broken that could be the problem do you use the broil more than the bake if you do then change the broil igniter thanks the appliance doc
Sep 16, 2008 | GE Spectra JGBP30 Gas Kitchen Range
Oven does not Bake, Heat Up
Replace the oven glow bar igniter. If you post an exact model number (located on sticker behind lower drawer) I can give you a part number.
Sep 02, 2008 | GE JGRP17 Gas Single Oven
Avanti ER24AW-1 Electric Kitchen Range Logo
1,252 people viewed this question
Top Avanti Kitchen Ranges Experts
Craig Butler
Craig Butler
Andrew Taylor
Andrew Taylor
ray gallant
Are you an Avanti Kitchen Range Expert? Answer questions, earn points and help others
