Question about Vacuums
Bissell Healthy Home Vacuum
My Bissell Healthy Home Vacuum has been having issues. Sometimes it wont turn on. I usally just have to empty the canister and then it will turn on. But this time i empty it and also cleaned the filter. It still wont work. I tried multiple outlets and still will not work.
  • 2 more comments
  • ejbsmum Dec 12, 2007
    Same exact problem here. Same model, Bissell healthy home. When I change the canister, it will turn back on, but as soon as I try to move it, it shuts off and wont start again.
  • Anonymous Jun 17, 2008
    Same issue, just shut down. It is only 4 months old.
  • Anonymous Aug 09, 2008
    SAME PROBLEM **** PURCHASED 3/22/08
    SWITCH DOES NOT WORK
    REMOVE CANISTER--REPLACE CANISTER**** WILL START UP
    SITS FOR AWHILE ---- WILL NOT START BACK UP
  • Anonymous Oct 22, 2008
    Mine is only a year old, same problem. It used to start up after I emptied the canister and now it won't start up at all.
Easy fix- mine did this too for a while bfore I figured out the handle wasn't aligning properly where attached. Give it a smack to realign it and it works again
Posted on Jun 08, 2009
    President:
  • 1,673 Answers
Could be that you have a clog, maybe down by the brush roll or in the hose. If not, then either the cord or a wire internally is loose, you would have to take apart to check the wiring.
Posted on Feb 05, 2008
Bissell 5770 Brush Issues
Hi their... By touching accidently the screw driver ok circuit board that may be caused of a short of any kind fues on the board or small resistant... Please contact to electronic technician to repair it rather than purchasing new board... Thank you
Oct 24, 2017 | Bissell 5770 Healthy Home Bagless Upright...
Bissell healthy home vacuum roller won't spin
Hi Helen. Your Healthy Home vacuum has a lifetime belt. If the belt needs replacing, you should bring it to one of our Authorized Service Centers for repair. Also, here is quick link to troubleshooting steps to assist you:
http://www.bissell.com/FAQDetail.aspx?id=1394&cid=ccsocial
Here's a quick link to assist you in locating one in your area:
http://www.bissell.com/service-centers/?cid=ccsocial
Apr 05, 2013 | Bissell Healthy Home HEPA Bagless Upright...
Bissell healthy home vacuum will not turn on. I have checked everything on the vacuum. All the filters are clean and there are no clogs. I have had it for 10 months with no issues until now.
- The handle may not be installed properly, causing a loss in the power connection. Remove the handle completely. Slide the handle back into place on the lower section of handle and tighten the screw.
Jun 06, 2010 | Bissell Healthy Home HEPA Bagless Upright...
Beater bar is not coming on- belt is on, canister is empty. Vacuum runs but no beater bar
Remove the beater bar and clean the debris from the bar and the end bearings. Remove the belt (remember how it is installed) and check it for any damaged areas. Make sure the bar turns freely before the belt is attached to the motor drive. Hope this helps!
Mar 15, 2010 | Bissell Healthy Home HEPA Bagless Upright...
The motor for brush won't turn on for the bissell healthy home vacum
Is the grey "brush" button on the handle depressed? Brush won't turn unless the button is down
Jan 01, 2010 | Bissell 5770 Healthy Home Bagless Upright...
How do you change the belt on a bissell 5770
The Bissell 5770/Healthy Home vacuum is actually fairly easy to change the belt on. The main thing you will need is a T20 screwdriver with at least a 4 inch shaft and a Phillips-head screwdriver. Four of the six T20 screws on the bottom plate are easy to locate, the last two are set deeper into the vacuum near the wheels. Once you have taken all six T20 screws out you will have to release the lock preventing the vacuum from tilting back so you can easily remove the top plate and gain access to the brush assembly. With the top plate off you will notice four Phillips-head screws holding a cover plate over the brush, simply remove them and you have full access to the belt.
Dec 07, 2009 | Bissell 5770 Healthy Home Bagless Upright...
Brush wont work
You probably need to change the belt. You can get a replacement here:
Bissell Healthy Home Belt
Nov 21, 2009 | Bissell Healthy Home HEPA Bagless Upright...
The brushes on my new healthy home vacuum wont rotate when the machine is turned on how do i access the belt location
If you turn the vacuum over so you can see the brush roll, there is a brush cover that is held on by (4) screws. Remove those screws and the base plate cover will come off. With the base plate cover off you can access the roller brush an belt. If you need a replacement belt you can get it here:
http://www.vacbelts.com/bissell-healthy-home-belt.htm
Oct 23, 2009 | Bissell 5770 Healthy Home Bagless Upright...
Bissell Healthy Home 5770 Fails to Turn On and Has No Suction!
I have the same problem sometimes...I noticed that the main body sometimes comes apart (the two sections under the turbo brush) and you just have to line them up again. If this is what's happening for you, try that. If they are still lined up, I'm not sure what's going on. Recently my brushes stopped spinning and eventually they just came back on...don't know why, but I'm guessing the contacts inside the vacuum are dirty or some things are coming loose.
Feb 01, 2009 | Bissell Healthy Home HEPA Bagless Upright...
Vacuums Logo
446 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
