455 rancher chainsaw does not oil chain
If you look under the machine by the chain you'll see a flat head screw (next to the sprocket) which controls the bar and chain oil flow . Try to turn the screw and check if there's any oil flow to the chain . If not you will need to replace the oil pump (part # 537 10 55-02 which will cost you about $35.00) Hope this help
Check your operators manual carefully many new Huskys have a 3 position oiler with 1 being the least and 3 the most. It is easy to turn beyond the detents and once done oiler problems abound.
Is this a new saw? Still under warrenty? If yes the dealer where
you purchased should be willing to verify proper oiler operation at no cost. If purchased from a big box store or on line all bets are off.
HTH Lou
