Question about Reddy R70ET Utility Heater
Gas wall heater
The heater runs for about 10 minutes and shuts off.
  • Mustafa1958 Dec 04, 2007
    I have a question about a natural gas wall heater, about 65"high and 16"wide, it runs for about 10 minutes and then shuts off??
  • 625 Answers
The R70ET is not a wall heater but a bullet style torpedo heater. it runs for a while then shuts down. first check that the photocell is clean. you'll need to unbolt the top cover. when pointing it make sure it "sees" the flame in its holder. if it still shuts down replace the photocell. the site www [dot] desatech [dot] com is the same place I get parts from for heaters.
Posted on Dec 04, 2007
    THOMAS MIERZWA Dec 05, 2007
    there are a couple of things to check. look at the heat anticipator setting on the thermostat. it must match the gas valve's current rating. .2 or .4 or .6 or something like that. a wrong anticipator setting will extend or short cycle the burner. if your's is a millivolt flame sense cappillary see if the pilot stays lit during the main valve firing.
SOURCE: Natural Gas wall heater
It could be either the thermostat or thermocouple is not getting correct voltage so will intermittent turn on and off.
Posted on Jan 21, 2008
SOURCE: heater keeps shutting off !!
I have model 5532, but I think they all have the same problem. There seems to be a safety device in the ceramic heater that turns off if it gets too hot. It "remembers" when this happens as well and will shut off until it is unplugged for 10-15 minutes.
This happens on even lightly used heaters if used in dusty conditions. Dust builds up behind the ceramic heater and the lack of flow causes it to overheat. The unit must be dismantled and the dust brushed/vacuumed out. The good news is that not only will the heater work again, but it will have better airflow too!
To do this, tech support and other people say to "clean the rear grill", but my rear was not dirty. The front grill had some dust that I vacuumed clean, but did not help. In my unit there are no filters before the air goes through the heater element. The problem is in the center of the heater. Taking out the internal fan (four screws on the sides of the squirrel fan box), I could see that the radiator was over half covered in dust. I cleaned that dust out using a shop vac and the problem went away.
Opening the heater was a little tricky, two of the screws were triangle head screws. Once inside, however, it is a simple proceedure to remove the fan. Of course, you should unplug the heater and wait a while before opening it up to make sure there are no electrical charges stored in the unit.
Posted on Apr 05, 2008
  • 75 Answers
It sounds like the thermocoupler is either not adjusted into the flame properly, or you may have gotten a bad one. The thermocouple is the main thing that makes the pilot work.
Posted on Dec 22, 2008
  • 4 Answers
SOURCE: ive have a william wall heater i replaced the
limit switch is over heating. must have an auto-reset. check to see if theres an obstruction in the chimney or heat exchanger. good luck! rrmechanical 888 411 hvac
Posted on Jan 21, 2010
  • 383 Answers
SOURCE: heater runs for about 10 seconds and shuts down
You say it shuts down-
Does it have to be reset to get it going again?
Does this heater have a pilot?
if so, when was the Thermo Couple last changed?
Tell us more clues, so we can help you get to the next step.
Mack B
Posted on Jan 25, 2011
Pool heater kicks on and off
safety switch is opening and closing, or issue with gas valve coils
Sep 17, 2012 | Teledyne Laars Laars Lite 2 Pool Heater...
I have a glow warm 20000 btu natural gas unvented heater. The unit is wall mounted. It won't stay on for more than 15 minutes, then shuts itself off. Its in a corner if that makes a difference... but has...
well, these heaters are typically thermostat-bound, and I have found that they simply will not burn continuously, like a blue-flame heater. Try turning up the setting--this will make it come on/off more often, effectively heating at least one med-lg room, and partially for adjoining areas. Keep in mind that these only rated for 700-1500 SF--that is NOT the floor measurements, but square feet of airspace; eg., a 10' x 15' room has 10' x 15' x 8' (8 foot ceiling) =1200 sf. That said, My 15k btu wall unit had been the sole heating source for my entire home for 5 years, until last year, when I acquired another smaller unit. However, I typically only use a few rooms, and shut off unused areas (ya, was 'cool' in unused back room areas).
Dec 16, 2010 | Desa International GWP20T GLOWARM Wall...
I have a Teledyne Laars Lite pool heater Model LLD 250N. When I turn the heater on it will run for 10 minutes and turn off. If I turn the power switch off and right back on it will run agin for 10 minutes...
It sounds like your pool heater might have a defective controller (the part, not you). Check the controller and replace if necessary. It could also be that you need to cycle the ignition sequence until the air is out of the gas line. It could also possibly be that your gas valve needs to be replaced.
May 30, 2010 | Teledyne Laars Laars Lite 2 Pool Heater...
Dec 22, 2008 | Dyna-Glo D-E36 Infra-Red Wall Mounted...
Is this a new unit or old? Does it have a fan or not? I need a little more info to walk you through this.
Dec 04, 2007 | Reddy R70ET Utility Heater
Reddy R70ET Utility Heater Logo
113 people viewed this question
Top Reddy Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Mack Baxter
T bone 1963
Are you a Reddy Heating and Cooling Expert? Answer questions, earn points and help others
