HP LaserJet 1500L
The printer prints all sheets 100% black! Checked for any foreign material on laser path to drum, all ok. No error lights on panel. Can u help.
lat@carefactor.com
tks..
Larry
  • 1 more comment
  • Jettaguy Dec 04, 2007
    The problem is trying to print a configuration-test sheet from the printer without any PC connection by holding the "Green" button down for a couple of seconds. The paper that comes out is 100% black! You may be right about the drum unit. Will replace it next.
    tks...
    Larry.
  • Jettaguy Dec 07, 2007
    The problem is not related to a driver; it is an internal printer problem and the solution provided does not address an internal printer solution.
    But tks. anyway. Any help is much appreciated.
    Lt
  • Anonymous Oct 01, 2008
    My Dell 1500 printer will not print - paper comes out totally black. Thank you for any assistance or suggestions.
    jjroelse@yahoo.com
When trying to print grayscale...I am getting reds and greens.
Posted on May 23, 2008
  • 56 Answers
Hi Larry , Here are a couple of soultions that may correct the problem.
1.Color mode is not selected in your program or printer driver.Select color mode instead of grayscale.
2.The correct printer driver is not slected in the program . slect right printer driver.
3.The printer is not properly configured.Check the configuration page by printing a configuration page.If no color appears on the config page replace the drum unit.
Posted on Dec 04, 2007
  • WILLIAM MONDY
    WILLIAM MONDY Dec 07, 2007
    First of all the steps I provided above where to see or start with a solution. And if you don't think the drum unit is an internal printer problem then maybe you need to buy the book for dummies 101 troubleshooting printers!
Using only HP products color doesn't print
There are two ways to print black (grayscale) only. One is through the printer access provided through HP software. The other is through the Windows printer software. Try accessing through MS, such as printing from office or paint and see what the printer options show. Then try it again through another program, such as PDF Adobe, or another program that brings up the HP printer software. Another option is going through the device/printers option in control panel. Good luck.
Jan 19, 2015 | HP Color LaserJet 2840 All-in-One -...
I have a laser printer 8150n. when i gives 20 print on it. on sheet print after another sheet vacant and third print fourth sheet vacant.. what is the reason
Might be page size mis match> Check paper size in system as well as in printer.> Remove tray &check for paper size.> Clean paper path sensors.
Dec 18, 2011 | HP LaserJet 8150n Printer
Have hp 1500l printer which will only print a full black page from any source. no lights showing. it appears to be a four color black. any help would be appreciated
If it's less than a year old, return it.
The (fuse going to, or) the high voltage power supply board has gone in it.
If it's not under warranty, a brand new 1606 color laser can be had right off HPs website for $149 right now (a little more than you pay for a toner).
If you really love this printer though, I can probably source out a HV controller board.
Feb 24, 2011 | HP LaserJet 1500L Color Printer
Hi everybody, I have got a canon Pixma MP 130 printer and the problem is error 6000. during printing process the printer broke down and did strange nose! Can someone help me? Would be more than happy to...
Hi, I had the same problem and went searching - all the feedback suggested that something may be stuck of blocking the paper path. Took the tray out, checked underneath etc - and yes - the problem was a couple of sheets of paper stuck inside. Was able to retrieve these by accessing them from the rear of the printer - and when plugged back in it started up OK!
I believe the cause here was that a print job was sent to the printer while it was also being used to copy stuff - though i cant be sure of this. Either way, it was a blockage that cased the problem.
Error code [6000] or light blinking 3 times.
1. Smearing or scratches on the LF encoder. Please clean the LF encoder.
2. Foreign material or paper debris in the LF drive. Please remove any foreign materials if encounter.
3. Check cable connection.
4. Replace LF encoder or Logic Board
Thanks for using fixya...
And please don't forget to rate me...thanks.
Oct 25, 2010 | Canon PIXMA MP130 All-In-One InkJet...
C9600 OKI.....On the printed sheet there starts to be a light layer under the text. I goes from side to side on the sheet although the backround ought to be quite white. Any information of the end of the...
Perhaps drum exposed to sunlight too long. It will ruin drum.
Could be foreign material inside drum or printer.
Run heavy stock through printer with nothing on page, to do this-
Open up Word. type a period, or a comma.
Print 10-20 copies.
This may clear it up.
Mar 26, 2010 | OKI C5400 Laser Printer
Blinking Cartridge Light HP Laserjet 1500L
the cartrige has a micro chip on it which resets the toner level.be sure that your non hp toner has this chip on it
Feb 03, 2009 | HP LaserJet 1500L Printer
HP Laserjet 1300 yellow light STILL flashing
Re-installing the print driver will not solve a flashing light. If the printer is functionally ok, it will come to ready simply by plugging into the wall. It sounds to me like a fatal error at this point.....could be a long list of things, but I would lean towards a formatter board. bottom line with this printer at this point in it's life is, if it doesn't work, it's not worth fixing. Replaceable for about $100.
Jan 29, 2009 | HP LaserJet 1300 Printer
HP Laserjet 1500 Color, Print out Blank
Hi devi960:
Pages print, but all
colors do not print or
the pages are
completely blank.
One of the print cartridges might be
low or empty.
Run an engine test and see if all four colors print. If
not all colors print, replace one or more of the print cartridges. If the
engine test is successful, replace the formatter.
If the printed pages are completely
blank, the file might have blank
pages.
Check the file to make sure that it does not contain blank pages.
A print cartridge might be low or
empty.
Check the printer control panel for a Supplies Status message,
print a Supplies Status page, or use the embedded Web server
(HP color LaserJet 2500 series printers only) to see the levels
remaining in the print cartridges. Replace any print cartridges that
are low or empty. Messages are not created for non-HP print
cartridges.
If you are using non-HP print
cartridges, one or more print
cartridges are low or empty. The
control panel lights do not indicate
low or empty for non-HP print
cartridges.
Replace one or more of the print cartridges.
Font DIMM might be selected but the
font DIMM is not physically installed in
the printer. (This issue applies only to
printers using an Asian-language font
DIMM.)
In the settings for this printer, clear the Font DIMM check box on
the Configure tab if no font DIMM is installed in the printer. Select
the Font DIMM check box only if the font DIMM is physically
installed in the printer. If you think that the font DIMM is installed,
make sure that it is installed correctly.
The paper curls when
exiting the top output
bin.
The paper needs to print to the
straight-through paper path.
Open the rear output door to print to the straight-through paper
path. Remove each sheet as it exits the printer.
The stack was slightly curled when it
was placed in the tray.
Turn the stack over in the tray.
The paper does not meet
specifications.
See the user guide for information about print-media specifications.
If you are printing on light media, the
Type setting might not be correct.
Select Light in the Type is field in the printer driver.
Nov 13, 2008 | HP LaserJet 1500L Printer
253 people viewed this question
k24674
jasbo
jasbo
Marvin
Marvin
