Gateway power supply
Computer will not start when power button is pressed but if u hold the test button and then press the power on button it will start and stay on.
what the problem?
  • Anonymous Dec 13, 2007
    what is the use of power supply in the operating system and the motherbord
    Scholar:
  • 93 Answers
Switching unit in powersupply sounds shot, if you want to test primary switching, un plug power from back, take main motherboard power socket off the board, take a paper clip and put it in the GREEN wire in the socket, and any BLACK wire, now (without touching the socket or having it touch anything else) plug power into the PSU, if the fans all fire up and spin, then the switching is fine, i would look at a fault on the board
Posted on Dec 07, 2007
Have acer 7540 On restart have error 0211 key
Try this fix:-
This problem was on a Gateway NV52 running Vista Home Premium (64) and this is how it was resolved, with the help of their tech support:
1. Turn off computer and unplug power cord.
2. Disconnect all external devices
3. remove battery
4. press power button and hold for 10-15 seconds
5. plug power cord back into computer and press power button.
6. Check LED's and listen for power supply fan.
7. If LED's are on or power supply fan starts spinning, watch for boot screen
8. If computer begins to turn on, turn it off.
9. Reconnect battery and external devices.
10. Press power button and make sure computer starts.
Sep 22, 2014 | Computers & Internet
Gateway computer power light flashes before booting up.
Hmm. I wouldn't have thought it had anything to do with pressing the button. It sounds more like a failing power supply or lack of current for startup. Did you make sure you plugged the power into the video card power connector (if it has one)? I know it worked ok at first but a heavier load can cause older or under-rated power supplies to fail soon after. Just a thought.
Dec 16, 2013 | Gateway GT5662 Desktop PC
. I WAS LOADING A FRESH LOAD OF WIN-7 AND IT JUST TURNED OFF AND WILL NOT TURN ON AGAIN
I would remove the main battery first and try powering up the computer, next! sub out the ram memory one at a time and test as you go to see if you can restart it, next! disconnect all power including battery, press and hold power for 2 minutes to reset the processor, if none of these work you will need someone to assess the motherboard for repair or possible replacement.
Apr 19, 2012 | Gateway NV59C56u 156Inch Notebook Satin...
I have a Gateway DX-4720-03 when I press the "ON" button it lights up briefly then goes out and computer will not boot. Fans do not come on. nothing happens. (If I press button again immediately nothing...
I would actually lean a little more towards the power supply being the problem. You can either have someone locally test it for you, or you can buy a power supply tester to check it out.
Aug 26, 2010 | Gateway DX4720-03 PC Desktop
What are the symtoms of a failing power supply on Gateway GT4024? Thanks, JEL
Some symptoms of a failing power supply unit on this unit are, computer does not start automatically when power button is press, the place where the power supply is located is getting way to hot unlike before and then computer just shut down itself without any notice. IF you have these symptms you might want to consider already replacing the power supply on this computer.
Aug 12, 2010 | Gateway GT4024 PC Desktop
My Gateway laptop can not turn on at all.Peter
Remove battery, press and hold power button for 5 seconds and then put back in to see if it starts. If not, power supply is most likely faulty
Nov 12, 2009 | Gateway 400SD4 Notebook
I have a Gateway Mx6440 Laptop and et CPU FAN error upon boot. afte w while i try spinning th efan and it starts working, i belive it is the heat sink that is defective but where can i find the proper fan...
"Turn off computer and unplug power cord. <br>Disconnect all external devices. <br>Remove the battery. <br>Press power button and hold for 10 to 15 seconds. <br>Plug power cord back into computer and press power button. <br>Check front panel LEDs (lights) on bezel (front face) or optical drives and listen for power supply fan. <br>If LEDs are on or power supply fan starts spinning, watch for boot screen on monitor. <br>If computer begins to start, turn it off. <br>Reconnect any external devices. <br>Press the power button and make sure the computer starts.
Please save this steps and go through that. If in case you require further help, you need to contact Answers by Gateway department which is a paid support. The phone number for Answers by Gateway is 1.800-237-6483. Or please consider contact with a local technician for a detailed troubleshooting."
worked for mee!! good luck
Feb 22, 2009 | HP (158800-001) for Compaq Presario 1246,...
Gateway e series desktop - power light is on but computer isn't.
i have the same problem i don't think its the power supply... my power see if your power supply has a "test button" on it and see if the fans work when you press that button
Jan 23, 2009 | Gateway CUSTOM E-SERIES MID TOWER 6/7BAY...
Computers & Internet Logo
171 people viewed this question
Alun Cox
David Payne
David Payne
