Question about Philips Cineos HTS9800W System
No reception or sound on rear speakers.
I have just purchased the HTS9800W, I can not get the rear speakers to work. The receiver box initially indicated they were working as the blue light was on. Now the blue light does not come on. I have tried repositioning the receiver box as close as one metre away from the CD player but still no luck.
  • 2 more comments
  • dripfeed Dec 21, 2007
    Exactly the same problem here. It worked fine 24 hours ago, now the rear wireless receiver isn't working. No blue light or anything.
  • PVOL Mar 12, 2008
    I have recently purchased the same model and experienced exactly the same. I have no light on the receiver. Having had the receiver replaced today still no sound - have you had any joy fixing the problem?
  • DoHu Jul 28, 2008
    Only the rear left and right speakers have no sound, centre rear is working normal. Speakers were tested and worked OK, I assumed the slots for the rear left and right speakers in the wireless box in not functioning, any thoughts on how to fix this?
  • Anonymous May 05, 2009
    ******* blue light not work
Here's the fix: power off the sub-woofer and wait for 60 secs before powering it on again. My rear receiver works every time now.  I guess the sub-woofer isn't just a dumb speaker; it has some kind of smarts in it too.
Prior to this, I had only tried cycling power to the DVD player itself.  I also re-seated the two, fat cables connected to the junction box. One of them had worked itself slightly loose and the result was completely absent speaker channels.
Posted on Dec 29, 2007
How do i connect my av30 speakers to my Toshiba tv? I have tried everything and am unable to get sound from the speakers. I have 2 sets of these speakers and would love to listen to my tv with them. I also...
Connect left and right audio outputs on rear of TV to corresponding inputs on rear of your Pyle receiver. You may have to go to the initial set up procedure on your Toshiba TV to disable internal speakers and direct audio output to the Pyle receiver.
Dec 04, 2017 | Audio Players & Recorders
HTS9800W/12 and rear speakers
click this site:
http://www.avforums.com/forums/archive/index.php/t-378942.html
Jul 10, 2008 | Philips Cineos HTS9800W System
No sound or power
IF ALL WIRES ARE CORRECTLY BEEN SETUP OR INSTALLED THEN THE NEXT STEP IS TO CONFIGURE THE SYSTEM TO WORK ON ALL SPEAKERS...
Before the setup of the speakers' channels
  • Press the SURR. button on the remote to select multichannel surround mode before adjusting the speaker settings.
  • In case of sound distortion, press and hold the SOUND button to select another transmission channel for the wireless rear speakers.
Setting Speakers' Channels
  1. Press 060227073157_11231.jpg to stop playback, then press SYSTEM MENU.
  2. Press 060227073234_11234.jpg repeatedly to select { Audio Setup Page }.
  3. Press 060227073211_11232.jpg060227073221_11233.jpg to highlight { Speaker Setup Page }, then press 060227073234_11234.jpg.
  4. Enter its submenu by pressing 060227073234_11234.jpg.
  5. Press 060227073211_11232.jpg060227073221_11233.jpg to highlight one of the options below at a time, then press 060227073234_11234.jpg.
    • { Speakers Volume } – Volume level setting for individual speakers (-6dB – +6dB).
    • { Speakers Delay } – Delay times setting in relation to the listening position/ distance for centre and surround speakers.
  6. Press 060227073245_11235.jpg060227073234_11234.jpg to adjust to the setting that best suit your surround sound needs.
  7. Press OK to confirm.
Notes:
  • 1 ms increase/decrease of delay time is equivalent to 30 cm change in distance. Use the longer delay time settings when the rear speakers are closer to the listener than the front speakers.
  • The test tone will automatically be generated to help you judge the sound level of each speaker.
Jan 27, 2008 | Philips Cineos HTS9800W System
Problem with rear speakers
hello
can sell me the junction box?
thanks
contact brilhasman@clix.pt
urgent
Jun 01, 2009 | Philips Cineos HTS9800W System
Hi!i have Philips HTS9800W but wireless rear speakers do not work!
The wireless rear speakers aren't wireless per se. They have to be connected to a receiver box and it's that box that brings in the system's wireless transmissions, eliminating in this way any cable runs from the front of the room to the back.
Nov 28, 2008 | Philips Televison & Video
Radio Problem
There is not an easy answer for this one. Some troubleshooting needs to be done. I have seen the Rockford Fosgate system in many of the newer Sentra's. Try hooking a known working speaker to a nonworking position. This will tell if it is a speaker problem. If the problem persists, this could be stereo or amplifier.
Terrible reception troubleshooting, a bad antenna will give poor FM and no AM. If both have bad reception, this is a stereo problem. You can remove the stereo from the dash, place a small pick tool or screwdriver into the antenna jack and test reception. If the reception problem clears, this is a antenna problem. I have seen car detailers pull the connector from the rear window antenna and forget to plug it back in too.
Nov 10, 2008 | Car Audio & Video
Lip sync playing ordinary tv
you need to have a sound speed equalization higher frequencies travel slow,
if you can buy a AV/RF CONVERTER the problem can finish
AV be connected to devices and RF to tv
this can over come that problem
Oct 07, 2008 | Philips Cineos HTS9800W System
HTS9800 Wireless receiver not working
I have just bought one of these today and have had the exact same problem. No rear sound and no blue light on the receiver box.
Solution:
What philips don't tell you in the manual and on the support site is that the receiver box has a switch hidden under a white sticker; next to the left of the right speaker connection. The switch has 3 positions which can be selected. I had tried each switch position and power cycled the subwoofer each time until eventually i got a blue light on the receiver box.
You may also need to select the correct channel on the control box by pressing the "sound" button for 5 seconds on the remote control.
It took me quite a while to try the different combinations until it finally worked. I can't imagine that Philips would have sent the system out without testing the wireless partnership first, so I am guessing my wireless network could have had something to do with it. (forever the optimist).
I did expect the subwoofer standby light to have gone off or changed colour once operational, but this just seems to stay on no matter what state it is in.
Sep 09, 2008 | Philips Cineos HTS9800W System
Rear speakers not working on STR-K740P
The only way your surround sound will work is if you have either the coaxial or fiber optic digital hookups attached to a PS3/Blueray/DVD/Cable box/Satellite box that have digital sound outputs. If you are just using the 1970's version of the red/white audio cables that is stero only.
Mar 02, 2008 | Sony STR-DE625
Onkyo 875 - No sound
YOU ARE PROBABLY USING 5 SPEAKERS WITH OR WITHOUT A SUB, AND YOU CONNECTED THE REAR SPEAKERS TO THE REAR SPEAKER OUTPUTS. THEY WON'T WORK THIS WAY. RECONNECT THE REARS TO THE SURROUND SOUND SIDE SPEAKERS, AND RERUN THE AUDISY SETUP. THIS SHOULD TAKE CARE OF THE PROBLEM. YOU HAVE TO FOLLOW THE DIRECTIONS AND SET UP THE DVD INPUT, IT WON'T WORK RIGHT OUT OF THE BOX, TOO MANY VARIABLES.
JACK
I CAN'T GET MY 875 TO RECOGNIZE COMPONENT VIDEO SIGNALS, I GUESS I'M STUCK USING HDMI, AND COMPOSIT INPUTS.
Feb 25, 2008 | Audio Players & Recorders
Philips Cineos HTS9800W System Logo
540 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
