Model # F32649- TV has static, no picture no sound for broadcast tv... picture and sound will show for sevral hours at times; a few minutes other times. DVD will play.
This problems,could be ur incomming broadcasting signal wire like coaxel wire like connect to tv ANT. hole input. or AV wires connection Y,R,W to ur AV input holes or those HDMI cables connections to it output HDMI ports.Take every connections of wires that are connected to the tv like input/out connections wires out of the tv.Now leave only AC power source turn on the tv and see if u get a tv LCD screen signal statics of snows only and U see no broadcasting tv incomming signal and only statics noises on the tv LCD screen only.Yes,than this problems,than it is not the tv problems,these problems it could well be caused by ur pay cables,satalites or telecomucations compannies signals broadcasting coaxel wire to the those compannies pay recieving boxes.Tries to unplug the pay broadcasting signal box u are using for about an hour.This well reset ur pay box back to the original and factory setting.Now,Ur box the paying incomming broadcasting tv channels signal pictures should return.If not talk to ur paying tv broadcasting signals commpanies for a replacement of the box u are paying for.99% of ur problems,i'm seeing u having is a broadcasting tv pictures signals that imcomming to the paying box u have a problems.This is not a tv set itself problems.
This tv is analog tv,will not get today free air tv broadcasting signal.Today free air tv signal are all digital free air broadcasting tv signal now.Anolog tv must have a pay cables tv or satalites tv signals to get a picture on analog tv set.U want analog tv to get the free air digital tv broscasting signal.The analog tv,must have it broadcasting tv signal must go through a box call a Converter box to able to produced a Digital free air broadcasting signal for analog tv to get a digital broadcasting tv signal.
It could be the start of a high voltage leak. A bad anode cap on the red wire going to the picture tub. try putting a little silicone sealer around it and hope the transformer is not the one leaking.
can you let me know if you got help for this? the gude plus menu is blank and keeps popping up in the middle of a show for no reason. then the picture goes out behind it. the sound works ok though.
Sounds like you have a shorted horizontal out put transistor and bad flyback transformer.
This is a common problem in the newer RCA's.
I've had serveral of them do this.
The noise that you hear is the power supply
telling you that it's overloaded.
Stargazer
This usually a problem on/near the horizontal section of the TV board caused by solder that losses its contact thats why you need to bump it sometimes for the picture to come out. To remedy this just try to resolder any parts that you suspect seems to loose especially in the part where the components tends to get hot when operating, this usually are the horizontal section or the power supply section which is very common.
