Question about Nview Z215 10.4" LCD Panel with Video(16.7 Million) Z215 Multimedia Projector
Projector won't turn on after I replaced the lamp
I have a Panasonic PT-LB50U that will not power on after I replaced the lamp. I've check cables and all- If I turn on, it looks like it's going through the cycle but then the my power turns orange and I get a red flashing by the lamp.
  • 3 Answers
Re insert the lamp and check your connection. if that does not work then replace lamp or have lamp checked.
Posted on Jan 13, 2008
How to do lamp reset on panasonic pt-lb50u projector.
To reset the lamp hours, turn on the projector. Then press Menu and use the Up/Down arrows to highlight Options. Press Enter then highlight Lamp Runtime. Press and hold Enter for 3+ seconds until the Lamp Runtime screen is displays. Press the Power button (any other button cancels the reset). When the Power button LED turns red, unplug the power cord to the projector. You can either use the remote or the controls on the projector. Reconnect the power cord after a few minutes.
The reset instructions are on page 62 of the user manual. The manual is available from Panasonic here: https://support.panasonic.co.nz/docstore/PT-LB50U%20Operating%20Instructions.pdf .
I hope this helps.
Jun 18, 2016 | Panasonic PT-LB50U Multimedia Projector
How do I get rid of a password on the projector so I can use the projector (PT-LB50U)
Menu
security
enter
input password on---off
Have a good day!
We supply original projector parts: lamp, bulb, Lcd, Lens, DMD, motherboard, powersupply ... with high quality and competitive price.
Jerry China
Tel: +86 131788 67858
E-mail: lampdeng@hotmail.com
Skype: lampdeng.com
YM: lampdeng@yahoo.com
http://facebook.com/lampdeng
http://www.lampdeng.com
Feb 06, 2014 | Panasonic PT-LB50U Multimedia Projector
Panasonic PT-AE700E projector light does not turn on, instead the fan runs on high for an infinite time until turned off
1,Check the fans ,whether the fan is running,when you turn on the projector
2,if the fans run, then ,check the lamp or lamp ballast
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
any questions, feel free to contact me
have a nice day!
Jerry Lampdeng Limited
May 04, 2013 | Panasonic PT-AE700E Projector Lamp
I've just replaced the lamp on my Panasonic PT-LM2E projector and it will switch on but no light comes out. The previous lamp blew in the projector after around 2000 hrs. The indicators are as...
I'd recommend checking the fans of the projector, and make sure that they're spinning. Since you've mentioned that the lamp blew inside the unit, bits and pieces of the lamp might have lodged itself within the fans. It might also have to do w/ the after-market replacement bulb, which I normally wouldn't recommend.
Aug 08, 2011 | Panasonic PT-AE900U Multimedia Projector
Panasonic PT LB50NTU - LCD projector need to connect to my IMAC - what cord do I need?
The Panasonic projector PT-LB50NTU or E have two type of data inputs.
One is RGB or VGA cable and second is VIDEO cable. If your IMAC have video or vga output than you can connect.
Two type of cables witch are using with projector good_help_0.jpggood_help_1.jpg
Jan 14, 2011 | Panasonic PT-LB50U Multimedia Projector
After changing the bulb image will not come on and solid orange light appears
Other then POWER BUTTON light there are three lights more
1. lamp indicator
2. temperature indicator
3. computer input
witch one light is flashing RED or illuminated RED with POWER BUTTON orange light.
If LAMP INDICATOR light is illuminated RED than lamp runtime has reached 1800 hours. but projector still working.
If LAMP INDICATOR light flashing RED than lamp circuit failure, or abnormal function or lamp unit is damaged. In this case projector doing the same behave just like your projector.
if TEMPERATURE indicator illuminating RED the projector still projecting and if flashing RED than turned of itself
Jan 11, 2011 | Panasonic PT-LB50U Multimedia Projector
The projector lamp does not turn on
I have done this on several of our PT-LB50U's with sucess every time.Remove lamp cover and lamp.Then remove top of case by removing 6 screws on bottom.Remove metal shroud that would cover lamp 2 screws and remove 2 screws that hold lamp plug and move it away.You will see a little blue lever for saftey switch move it back and forth from top and bottom put back together and should turn on.
Jan 03, 2009 | Panasonic PT-LB50U Multimedia Projector
My Panasonic PT-LB50U LCD projector flashes red lamp indicator and will not light up. I replaced the lamp and it still will not light. The old lamp only had 20 or so hours on it and it does the same thing....
this worked for me what i did is: turn on projector then undo the light panel when its on the projector then will cut off, now the light panel pushes down on the hidden safety switch take a screw driver and push down on the switch, the projector will turn on then wait for about 8 sec then release the projector will turn off, repeat step several times until the light flickers, then do a couple more times and the light should come on and should stay steady turn off and let cool for 10 min, this worked for me hope it works for you!
Aug 12, 2008 | Panasonic Televison & Video
Nview Z215 10.4" LCD Panel with Video(16.7 Million) Z215 Multimedia Projector Logo
586 people viewed this question
Top Nview Office Equipment & Supplies Experts
k24674
jasbo
jasbo
Marvin
Marvin
Are you a Nview Office Equipment and Supply Expert? Answer questions, earn points and help others
