Question about Proscan 19LA25Q 19 in. LCD Television
Remote control I have a proscan 19LA25Q TV its for a elderly women and the remote that came with it is to small for her to use ...i purchased a RCA universal Remote Contol (RCR4258/RCR43580 but have not been able to locate the code to make a match...can you help with this problem Thank you
  • 1 more comment
  • ccarr Dec 12, 2007
    We have a Proscan 19" tv but the remote will change channels up to 13 but we can't go any higher than that. Is there a code I need to input??
  • jdlcm Dec 29, 2007
    I can not program the cabl remote
  • robahrens Feb 11, 2009
    have a proscan 19la25q need universal remote that will work it.w/code.
    Problem Solver:
  • 7 Answers
Try rca.com/codefinder
Posted on Apr 07, 2008
    Problem Solver:
  • 12 Answers
This might help you.
Proscan 19LA25Q 19" LCD HDTV at Crutchfield.com Proscan 19LA25Q 19' LCD HDTV: Detailed Info, Features and Specs, and Photos. ... Instruction Manual; Product Registration Card; Limited Warranty Card ...
www.crutchfield.com/ISEO-rgbtcspd/App/Product/Item/Main.aspx?i=68319LA25Q - 46k
Posted on Apr 04, 2008
  • jimnichols Apr 04, 2008
    Hope that helped
I bought my 19" Proscan LCD (19LA25Q) used from a
The Proscan 19LA25Q came with a remote originally. Unless the IR receiver has failed, it should work with a universal remote. (Note: if the TV is newer than the remote (or released less than 6 months before the remote was programmed), the remote codes for your TV may not be included.) Since the code lists on universal remotes do vary depending on the age and model, please give more information than just the brand. GE remotes usually have a version code label in the battery compartment. This version code is needed to look up the correct code lists. Some GE universal remote built by Jasco codes are here: https://byjasco.com/support/ge-universal-remote-codes.
The Proscan 19LA25Q was probably built in 2007, since there are reviews from 2007. That was also the year when this size TV had to have an ATSC tuner. So if your remotes were programmed before July 2007, they may not be compatible. Some of the current Proscan TVs probably use the same parts as some Sylvania, RCA and Curtis TVs.The 19LA25Q was warranted by On Corporation which has control of the RCA brand now. However, I don't know when they bought the label.
Amazon lists a few direct replacement remotes for the 19LA25Q. See https://www.amazon.com/Original-Proscan-Control-E20F-19LA25Q/dp/B00KQVDRNK and https://www.amazon.com/PROSCAN-Replacement-Remote-Control-19LA25Q/dp/B009H5QVIO . Remotes.com also has a replacement remote: http://www.remotes.com/SearchResults.asp?Search=19LA25Q .
I hope this helps.
Apr 21, 2017 | Proscan 19LA25Q 19 in. LCD Television
Remote code
These are the Proscan codes I can find: 0047, 0060, 0760, 1060 Let me know if they don't work.
Sep 09, 2007 | Proscan 19LA25Q 19 in. LCD Television
Remote control
These remote codes also depend on what the exact make and model of the remote control is that you are using. These remotes can also use 2,3,4 or even 5 digits. The other factor is that some universal remotes will recognise the code for your proscan TV - but others will not depending on how they are programmed.
I will give you the most common 4 digit codes for Proscan and hopefully these work for you. If not please post up further detail on the remote control - exact make and model no. that you are using in order for us to solve the problem.
Common Proscan TV codes:
0000, 0015, 0031, 0107, 0162, 0163,1000, 1008, 1068, 1108, 2010, 2118, 2144, 2205
If this works for you please do rate my answer using the thumbs. If not please provide more detail and I will be happy to respond.
Thanks for using FixYa.
Jan 08, 2010 | Proscan 19LA25Q 19 in. LCD Television
My daughter has drop the remote control in the garbage. I have purchased 2 universal remote controls. neither one was able to work with this Tv : Proscan 19LA20Q. Where would I be able to find a Proscan...
You will be required to order the original remote for your set. Universal remotes will not work properly with this model.
Start at the link below. You will need the model number. The Panasonic support person will tell you how to order a new remote unit for your set.
http://www2.panasonic.com/consumer-electronics/support/
Jerry G.
Oct 10, 2009 | Proscan 19LA25Q 19 in. LCD Television
Universal remotes for proscan
remotes.com (1-800-remotes) has a remote for this tv. One for all remotes and radio shack remotes do not have a device code for this tv. Proscan is not made by GE, RCA, Thompson any more. They are marketed by oncorpus.com now.
Nov 02, 2008 | Proscan 19LA25Q 19 in. LCD Television
Regarding the one for all remote
Hello mommy,
If you purchased the One-for-All universal remote (model URC4220) the remote code for a Proscan TV is either 0047 or 0747. The instruction booklet also has a section called ''Troubleshooting", which gives specific instructions on how to correct the problems you are having with volume and channel selection.
If you did not purchase the remote control listed above, please tell me the brand name and model number of your remote. I also need to know if it is a universal remote or not.
Hope this info helps you out. Please take a moment, whenever possible, to rate this solution, by using the rating system below.
Thanks.
Aug 20, 2008 | Proscan 19LA25Q 19 in. LCD Television
Universal remote problem
RCA TV remote codes: 0047, 0090, 0679
RCA DVD codes: 0522, 0571, 0717, 0790, 0822, 1022, 1132
or
TV/DVD Combo unit: 1022
Apr 09, 2008 | Proscan 19LA25Q 19 in. LCD Television
Universal remote available?
I can sell u a remote for the Proscan 19LA25Q 19" LCD TV .You can e-mail me at keepin_cool_in_maine@yahoo.com
Aug 18, 2007 | Proscan 19LA25Q 19 in. LCD Television
Proscan 19LA25Q 19 in. LCD Television Logo
280 people viewed this question
Top Proscan Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you a Proscan Televison and Video Expert? Answer questions, earn points and help others
