Haier hwr10xc6 Thru-Wall/Window Air Conditioner
Problem for Haier hwr10xc6 Thru-Wall/Window Air Conditioner
Water coming out of my top vents......
By heatherbboo on Aug 23, 2009
water coming out the top vents, what do i do????
Clarification Request
Posted by randazzoheat on Aug 24, 2009
is it coming out like flooding up or is water just forming on the tops of the registers?
Solution #1
posted on Aug 24, 2009
Not Rated)
melee5
Rank: Wiz
Rating: 90%, 28 votes
Go outside and see if you can spot a plug up in the drain tube. Some insects will build nests inside the proper size tube and plug it up so that condensation generated by normal operation is not allowed to drain from the unit. Other times, fungus or algae will cause the plug up.
Your plug up may be internal to the machine as well. This might be relieved by swabing out the plug up from outside by means of a fine flexible cable or weed wacker line - be careful!! Drain lines are often hidden very well requiring great detective skills.
Was this helpful?
Yes
No
Popular Solutions for Haier hwr10xc6
Questions and Unsolved Problems for Haier hwr10xc6
Do you recommend Haier hwr10xc6 Thru-Wall/Window Air Conditioner?
Answer
Answer
When I plug window airconditioner, it shows E 1 on the screen and wont strat up.. What can I do?
Answer
for some reason the unit keeps shutting itself off. i have the "timer" turned to off but... (More)
Answer
Our 12000 btu unit is making a loud noise when it changes temperature like a snapping sound. It can... (More)
Answer
i tried everything! e1 wont come off the screen. The remote doesnt work and the unit itself will... (More)
Answer
I bought a universal remote but can't figure out the program code. The one on the website says 82,83... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Haier hwr10xc6...:
Top Air Conditioner Experts
Rank: Guru Guru
Solutions: 1205
Experience: installed and repaired audio/video equipment for over 23 years at 2 colleges and 3 businesses.
Ask Me
Find more Air Conditioner Experts
Top Air Conditioner Repair
Service and Repair, System Maintenance, Advantage...
Aire Serv Heating & Air Conditioning
ARS
(866) 800-3823
When it comes to air conditioning systems,...
ARS
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
