Question about GE GBS22HCP Bottom Freezer Refrigerator
Kenmore side by side not cooling: The compressor seems to be running (it's hot), the compressor cooling fan is running, the freezer circulation fan is running, but not the least bit cool anywhere.
  • 161 Answers
If everything is working, that you can see and hear, then I think you are low on coolant. A set of gauges will show you for sure or if you take the back panel off in the freezer and look at the cooling coils, they should have a light coat of frost all over. If it is low on coolant then they might have some frost on a few coils or none at all.
Posted on Dec 16, 2008
Inside refrigerator strip between the freezer and refrigerator
The condenser fan motor at the back near the compressor is either dirty or not running at proper speeds. Clean the coils for air flow over compressor and if the fan is not running replace the fan.
Jul 05, 2010 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Getting very hot in the middle betweenthe fridge and freezer
The condenser fan located on the bottom near the compressor is not circulating well enough to keep the compressor at a good operating temperature causing the compressor to shut down for longer periods of time until cool enough to run again. Clean the coils good and replace condenser fan and you will be fine. The fan works as a cooler for the compressor. Imagine working in the yard on a hot day wearing a mask over your nose and mouth. Your body shuts down quicker because you have to take more rest due to the restriction of fresh air. Same applies to the compressor. Hope this helps. Rick
Apr 27, 2010 | Samsung RS2630SH Side by Side Refrigerator
Freezer works Refrigerator will not cool down
The compressor should be OK this time because you caught it in time. But if the condenser fan stops you need to consider replacing the fan. I have had refrigerators do fine until the fan motor warms up and you are away, it stops. Don't think you should use the refrigerator until the fan is fixed. Sea Breeze
Apr 22, 2009 | Kenmore Refrigerators
We have a Kenmore 596.50399001 side by side refrigerator. The center divider can get very hot, the refrigerator compressor is running but not the fan. If the refrigerator is moved or shook the fan will...
If you are talking about the freezer fan motor, it should be running if the compressor is running.
if the compressor runs without the fan running the compressor will overheat and become damaged.
The mullion heater in the door divider is not affected by the compressor.
Mar 13, 2009 | Kenmore Refrigerators
Freezer not freezing and fridge not cooling
Check the back wall of the freezer for ice buildup.
If yes, a defrost parts problem.
Check the freezer fan. Is it running?
If no, replace the freezer fan.
Check the condenser fan at the compressor. Is it running?
If no, is compressor hot?
If compressor is hot replace condenser fan motor.
If compressor is not hot.
Replace the compressor start relay.
Feb 27, 2009 | Kenmore 53502 / 53504 Side by Side...
Kenmore refrigerator compressor clicking
Relay on the compressor bad.
Try unpluging for 30 - 45 min until the compressor has cooled down then plug it back in. If it doesn't start replace the relay. Most service techs carry a universal relay and wiil put the relay on, if it starts, your good to go, if not, then the compressor is bad.
Nov 07, 2008 | Jenn-Air JCD2389G Side by Side...
Compressor is extremely hot
Compressor will be hot to the touch. You stated the fan was replaced and then said the fan is not cooling. If you replaced the fan and it is now operating, reinstall the panel you removed to install the fan motor. That panel determines proper air circulation to cool the system.
Jun 14, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Refrigerator/Freezer not cooling
check freezer for frost build up and if fan blowing, check condenser make sure clean, and fan blowing, by compressor Make sure compressor is running and not shutting off on overload.. u said comp. hot.. should be warm... Not hot check vents in refrig. make sure no blockage, freezer control should be in the middle setting, you can try turning that to Warmer freezer allowing MORE air to refrigertor side.
Sep 04, 2007 | Kenmore 50522 / 50524 Side by Side...
Kenmore Refidgerator is not cooling
let fridge cool down it sounds like the relay overload is bad try replacing it with a 3 n 1 start kit directions on the kit real easy to hook up... if the compressor starts then you are ok... hopefully the compressor is not burned out good luck
May 09, 2007 | Kenmore 50522 / 50524 Side by Side...
GE GBS22HCP Bottom Freezer Refrigerator Logo
70 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
