I use Musicator for writing music, and have this Edirol pc-50 plugged into my pc by means of an USB-plug. But I am tired of this latency which disturbs me when writing. The latency is about one second.
I am using XP and the pc is rather fresh, strong/rapid and new.
Kind regards,
Carl
Comments:
Dec 04, 2007
- This might be useful to me. You asked what kind of soundcard I have. How can I know that? I copied something I found about the sound, and I will paste it here. Will this mean anything to you, or am I in the wildernes? (Norwegian here and there):
Navn Realtek High Definition Audio Produsent Realtek Status OK Enhets-ID for PNP HDAUDIO\FUNC_01&VEN_10EC&DEV_0883&SUBSYS_1462F603&REV_1000\4&17F31A78&0&0001 Driver c:\windows\system32\drivers\rtkhdaud.sys (5.10.00.5253 built by: WinDDK, 4,07 MB (4 271 616 Byte), 04.10.2006 10:01)
Navn USB-lydenhet Produsent (Generisk USB-lyd) Status OK Enhets-ID for PNP USB\VID_0471&PID_0327&MI_01\6&344143E6&0&0001 Driver c:\windows\system32\drivers\usbaudio.sys (5.1.2600.2180 (xpsp_sp2_rtm.040803-2158), 57,88 kB (59 264 Byte), 02.09.2007 09:52)
Navn Virtual Sound Canvas 3.2 Produsent Roland Status Degradert Enhets-ID for PNP ROOT\MEDIA\0001 Driver c:\windows\system32\drivers\vsc.sys (3.23, 928,99 kB (951 284 Byte), 28.09.2007 00:50)
The main cause of latency is your hardware. What kind of soundcard do you have? If you are using the one that came with your computer then that is your problem, no matter how good or new your PC is, manufacturers like to save costs by using cheap motherboard mounted soundcards, I had exactly the same problem as you when I started using a MIDI keyboard with cubase.
I'd suggest buying a soundcard designed for audio applications, I use the M-Audio Fasttrack which you can pick up very cheaply nowadays. I have my latency down to around 1/20 second and as an added bonus I get a 1/4 input and an XLR input as well for recording.
Comments:
Dec 04, 2007
- yeah you got a realtek soundcard, absolutely useless for any serious audio or MIDI work.
you can improve latency by adjusting the buffer size in your doftware but you are never going to get it low enough to make your keyboard useful. I'm afraid you'll need a new soundcard for that.
Go to the soundonsound forum and post your question up there, there are lots of serious producers and gearheads who can recommend a good soundcard.
tried to install Adobe flash 10 onto my computer and got message that the publisher would not allow...
(More)
tried to install Adobe flash 10 onto my computer and got message that the publisher would not allow installation. What do I do?
I began having this problem after installing Dreamweaver 7.0.1 and Webstyle 4 on a new computer. I...
(More)
I began having this problem after installing Dreamweaver 7.0.1 and Webstyle 4 on a new computer. I can no longer see the navbars in DW, but they upload and appear on the web (see www.deadmikes.com). I can insert it in DW and see it and save it, but when I reopen it, it is not visible. Can anybody help me?
iunable to install serif page plus x3. it says that the patch package does not exist. i know it does...
(More)
IUNABLE TO INSTALL SERIF PAGE PLUS X3. IT SAYS THAT THE PATCH PACKAGE DOES NOT EXIST. I KNOW IT DOES BECAUSE BEFORE I HAD A REPAIR ON MY HARDRIVE THE PROGRAMME INSTALLED OK AND I USED IT ALL THE TIME.
Hi any idea where I can down load a PDF of an owners manual for VSC. There are only German, Spanish...
(More)
Hi any idea where I can down load a PDF of an owners manual for VSC. There are only German, Spanish and Italian on the disc. Many thanks Tony Williams
