Question about Nintendo DS Lite Console
Nintendo ds hi, is it possible to fix a ninendo ds were the top screen has broken off its hinges and the foil data ribbon is ripped!!! kids!!!!!!!!!!!
    Problem Solver:
  • 15 Answers
This happened to my sister DS and alot of other people. Please do not worry because you are NOT the only one who has experienced this problem. Unfortunatly there is no full way to fix it but you can buy a "ds holder" which will keep the ds together during game play and non use. this has worked for my sister and has had no other probelms since. i hope this works for you. good luck=]
Posted on Mar 16, 2008
Ok but where can you buy a foil data ribbonfor a NDS lite
Posted on Dec 28, 2007
    Novelist:
  • Nintendo Expert
  • 127 Answers
Its possible though sometimes it is expensive so dont worth the work.
-Top screen broken: you can buy a replacement and carefully do the work by yourself with the help of a guide (youtube have many) and some tools (3 winding screwdriver is the less common though not much). The foil data ribbon can be bought separatelly for the original NDS though the new NDS lite have it soldered and very difficult to work.
-Broken plastics: a broken hinge means you need to buy a replacement shell. Anyway buy a complete shell from a DS modding shop or take parts from a non broken plastics DS (water damaged one may be good) in a place like ebay. You would be lucky if you find a non broken screens and good plastics DS for parts.
At the end you may be over your repair budget and not only that, you would be very near to buy a new unit with this money. Each one make its own choice.
Good Luck...
Posted on Dec 16, 2007
Ds lite top screen showing colours and lines but thats all can u help?
If you Feel confident enough to open up the ds check the top screen ribbon cable is as tight as possible, its at the top end of the board near the hinge.
The ribbon cable could be faulty do to rubbing on the inside of the hinge, check if the image on the screen changes when you flip the lid towards you and back, if it does chances are the screen will need to be reworked or changed. hope this helps.
Jan 18, 2010 | Nintendo DS Lite Console
Broken in half got new shell don't know how to put together
much of it is pretty straight forward, the only hard part is putting the ribbon cable thru the hinge for the top screen, without ripping it, best thing to say is put the ribbon cable in first, then the wifi and mic cables (black and white), rest is pretty straightforward.
Apr 17, 2009 | Nintendo DS Lite Console
Broken nintendo ds lite hinge. Do I send it away for repairs or get a new console?
Nintendo will fix the hinges depending on a few things, first thing would be to determine how the hinges were broken. The hinges are tested before they leave the factory, the only way that they actually break would be because of physical damage/impact. Physical damage is not covered under the manufact warranty so you would get a discounted price depending on if your under warranty or not. Regardless giving them a call and having their techs fix them will be the best bet, not only because you know it will be fixed right and your warranty will start over the day it gets repaired.
Dec 15, 2008 | Nintendo DS Lite Console
Broken top screen (original DS)
Replying to the first post:
If you have broken the ribbon cable, which is highly likely if you have broken the hinge, then the DS will not work. It does not turn on unless there is a connection to both screens. You will need to buy a new ribbon cable for it:
A useful site I found is: www.consoleparts4u.co.uk
Once you replace this then it should work for you.
Repling to th second post:
I would recommend buying a new case for it at least because the ribbon cable will break if left broken due to the strain on it.
The more expensive but easier option is to buy a new one.
Hope this helps,
Mowcius
Jun 16, 2008 | Nintendo DS Console
Onceturned on, the green light goes on, the touch screen flashes white, then it all turns off.
You might only have a loosen screen ribbon cable.
If not careful while taking out the top screen ribbon you can damage it causing blank screens and finally the DS wont work.
The solution to a broken top screen ribbon is to replace the whole screen in DS lite or buy the ribbon cable in the DS fat and replace.
If the broken top screen ribbon is caused by broken hinge then you should replace the shell also to avoid other broken screen.
May 22, 2008 | Nintendo DS Lite Console
Ds lite hinge broken right h/s (looking at it)this has affected the top screen any ideas please
Hi, it sounds like when the hinge has got damaged, so has the top screen ribbon on the left as its easily ripped. Would need a replacement case and top screen, can recommend here for both: www.console-spares.co.uk, hope this helps.
Mar 24, 2008 | Nintendo DS Lite Console
Green screen
There is a ribbon that connects the top screen of the ds to the motherboard. It is possible that this ribbon became damaged when the hinge broke. A possible fix would be to replace the upper screen. Hope this helps.
Jan 07, 2008 | Nintendo DS Lite Console
Nintendo ds to screen broken
Hi, replacing the original nds upper screen is a fairly straight forward procedure, you need to remove the 4 x small plastic plugs located in the corners of upper screen, then remove the 4 x phillips screws, the top outer back part of the case will seperate and you can gain access to the screen. Firstly remove the small screw holding down the right hand pcboard to gain access to the ribbon connectors, release the larger flat connector by hinging the clip up, slide the ribbon out, underneath you will see a tiny connector, gently ease the small clip back towards the ribbon, prising a little each side at a time, remove the ribbon and then you can prise the screen from the case.
These guys sell the replacement screens www.ps2laser.co.uk prices are very competitive and offer next day delivery!
Nov 08, 2007 | Nintendo DS Console
Nintendo ds damaged ribbon cable
You can't buy a ribbon for the bottom screen. (You can buy the ribbon that connects the motherboard to the daughter board which connects the top screen.). A new screen is the answer but be very careful when taking off the touch screen. Gently pry the two screens apart or else you will need a new touch screen. Also make a note of how the touch screen is attached to the LCD screen, as the touch screen is not the same size as the LCD screen. How have you damaged the ribbon? Could it be that it may not be pushed tight and straight into the connector? BTW the top and bottom LCD screens are the same. Some unscrupulous dealers have been charging differing amounts for 'Top' or 'Bottom' screens!
Oct 27, 2007 | Nintendo DS Console
Nintendo DS Lite Console Logo
159 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
juanmireles1
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
