Question about Verbatim VER95327 USB Hard Drive
Storage usb verbatim
I have a verbatim storage usb 1gb and now when its connected to my pc it has just 3MB and all data are gone
  • 3 more comments
  • Anonymous Jan 08, 2008
    I have a verbatim storage usb 1gb and now when its connected to my computer it has just 3MB and all data are gone
  • razagold Sep 06, 2008
    my usb size is 1 gb but when iconnect it to my system it shows only 97 MB.
  • rafaela51 Sep 23, 2008
    I have the same problem i lost a lot of files and now I dont know how to ge tthem back...helpp!!!
  • Anonymous Sep 30, 2008
    I have a 2gb usb when i check properties its only got 196MB i have to to format several times still no good what can i do
    i dont no the model of my usb i can only tell you that it is red & has a blue ligh that flashed when reading
  • dragan27 Oct 06, 2008
    i also have the same problem,i had 2gb,now i have 1 gb,please advise what to do,i tried evrithing
  • 72 Answers
Try to reformat it
Posted on Dec 04, 2007
How do i download the privacy zone exe file for my 1GB verbatim 2.0 store 'n' go flash drive
if you are downloading data from the internet
once it starts downloading windows will ask whether you want to run or save it
a browse option will open you can save it into a folder in my documents or another device or a
usb device
if you need more help with this post a reply
hope this helps
Jun 23, 2012 | Computers & Internet
Download execution file for a privacy zone
or if you are downloading data from the internet
usb device
hope this helps
I backed up my system and recently lost the hard drive. A new hard drive was installed, and I connected my Verbatim to my PC, but I have no idea how to put all the backed up data back to my PC. Can you...
All you need to do to backup the files on your old hard drive is by using a Hard Drive Docking Station. you can take your hard drive to a local store and ask for a docking station that would fit on your hard drive, the docking station is like a device the you can connect to your computer using a USB cable.
Once you have it, your old hard drive will just function as an external storage device.
Jun 29, 2011 | Verbatim (96759) 1 TB USB Hard Drive
I've bougth a Verbatim Hard Drive USB 2.0 750GB 2 years ago. I've used it until yesterday. Now my pc can't recognize the device. "unknown device". How can I solve the problem or how can I...
An external storage-device has four major components:
* the USB cable
* the power-adapter
* the disk-drive inside the enclosure
* the USB-to-disk-drive adapter inside the enclosure.
One of these components has failed.
Try a different USB cable.
Try connecting to a different USB port on your computer.
Try connecting to a USB port on a different computer.
Take a "multi-meter" and measure both the voltage and amperage output from the AC adapter, and compare with the specifications on the label on the adapter.
Open the enclosure, and remove the disk-drive, and then connect it as a "slave" disk-drive in a desktop computer, to see if it works at all.
Purchase a new, compatible, disk-drive, and install it in the enclosure, to "revive" your external storage device.
Get the part-number and serial-number from the label on your disk-drive, and access the manufacturer's web-site, and use "check warranty status", to see if they will replace the device, at minimal cost to you.
There exist commercial "data recovery" services that can try to repair your device, just long-enough to rescue and copy your files. For example, see: https://services.seagate.com/index.aspx?lng=en-US for a "no data - no charge guarantee".
Nov 17, 2010 | Verbatim External, USB 2.0, 750GB...
Verbatim 320 gb usb external hard drive stopped working.When the device is connected the blue led light is on.But computer is not recognizing.Help me.
* the USB cable
* the power-adapter
Nov 11, 2010 | Verbatim VER95327 USB Hard Drive
My usb drive has gone read only without apparent cause
Unless youve got very important data on there i'd throw it because you can get another same size on Ebay for under $10 including postage brand new. cheers from Scott P.S. They are not designed as a permanent data storage always back up to DVD and put in a safe place
Oct 17, 2010 | Verbatim CORPORATION 94933 USB 2.1GB...
Verbatim Disc shuts down computer when inserted
it seems some autorun program is causing this.
try disabling the autorun of cd rom drive ....setting is under device manager. then put the disc in the drive... you should be able to copy all the data from it.
Aug 06, 2009 | Verbatim DataLifePlus Ultra Speed CD-RW...
Verbatim 1gb flash drive privacy zone lost space
try this link. http://verbatim.com/support/support-article.cfm?support_id=807E395C-1422-1392-A886DB00B24DFF68&supportType=Download
Aug 13, 2008 | Verbatim CORPORATION 94933 USB 2.1GB...
In order to delete your privacy zone, you have to get the application once more. To get the software click here http://verbatim.com/support/support.cfm?open=Downloads ...ok so you will have to format your flash drive with the application, removing the privacy zone if you want, this will obiously DELETE ALL DATA ON THE DRIVE after the format has completed, you can then remove the application from you flash drive, if you still remember the privacy zone password, then all you have to do is just type it and you have acess to the privacy zone... anyone who needs assistance can contact me to semirandomjr@yahoo.com if you are confused, email me and i can also try to clear it up for you. MAKE SURE THAT YOU CHOOSE THE CORRECT PRIVACY ZONE APPLICATION FOR YOUR FLASHDRIVE
Feb 26, 2008 | Verbatim CORPORATION 94933 USB 2.1GB...
Verbatim usb drive 8 gb help
Microsoft Windows 2000 help Processor:, Intel Pentium 133 MHz or equivalent 8 CPUs Supported. Memory:, 256 MB. Drives:, 1.0 GB Disk space CD-ROM / DVD drive ...
Computer questions and answers listing 200 - 299 CH000273, Not able to see over 8.4GB hard drive. CH000274, Not able to see or boot with hard drive over 33.8GB. CH000275, Unable to see over 8GB with ...
Good Luck, Please dont for get to Vote, Thank You.
Dec 20, 2007 | Verbatim STORE-N-GO (95312) 8 GB Hard...
Verbatim VER95327 USB Hard Drive Logo
186 people viewed this question
Top Verbatim Computers & Internet Experts
Arora Singh
Arora Singh
pankaj rautela
pankaj rautela
Computer Links
Are you a Verbatim Computer and Internet Expert? Answer questions, earn points and help others
