Question about Breville ESP8XL Espresso Machine
The Steam Mechanism Won't Operate
Hi There,
Of recently I have come across an unusual problem where by Expresso Machine won't produce steam.  When I turn the knob to the right the Expresso Function will work but soon after I turn the knob to the left for the Steam Function the Machine will not operate where by it doesn't make that thumping noise before the Machine will produce steam through the valve.
Any ideas?  I had only de-limed it in the last month or so.
  • drdantru Mar 24, 2008
    Same issue, I tried dip-it coffee machine cleaner, and ran Cleancaf thru twice as well, nothing comes out and it get very hot trying. The espresso works just fine, but nothing from the steam. I think it is an internal issue not easily resolved with de-scaling.
  • CoffeeKrazee Jun 25, 2008
    I have the same problem with the steamer - there is no steam or thumping noise. It just started today -- the espresso part works fine.
HI Folks, I had the same problem and I have found a solution that worked for me. I took a look at the circuit board (I am an electrical engineer) and I could see an ever so slight buildup on the circuits behind the chips. It looked like some water or steam dripped back there. Then with some effort I was able to peel the circuit board off the glue and wash the back of the board where the solder is with clean water and a gentle brush (all circuit boards are actuall washed after they are made) then I dried it by placing it in the sun. After and hour, I put the board back in and presto the "thumping" and steam were back !. I hope that helps.
Mike.
Posted on Jul 14, 2008
HI Folks, I had the same problem and I have found a solution that worked for me. I took a look at the circuit board (I am an electrical engineer) and I could see an ever so slight buildup on the circuits behind the chips. It looked like some water or steam dripped back there. Then with some effort I was able to peel the circuit board off the glue and wash the back of the board where the solder is with clean water and a gentle brush (all circuit boards are actually washed after they are made) then I dried it by placing it in the sun. After and hour, I put the board back in and presto the "thumping" and steam were back !. I hope that helps.
Mike.
I contacted Breville and they were very gracious about a return. They took mine even though it was a couple months beyond the warranty and replaced with a new machine. The new machine has some new changes that seem to help prevent the frothing arm from clogging so easily. I do like the improvments.
Posted on Jun 11, 2008
I had the same problem; the solution was to replace the PC board ($40) in the machine.
You should hear the pump “thumping away” when it is producing steam because it uses a thermal block.
Espresso machines which use a boiler to produce steam do not use a pump.
Scott
I too am having a similar problem with my breville espresso machine. Whereby i used to be able to froth the milk with no problems but these past couple of days, the steam button light is illuminated, when i turn the knob to steam the milk, the steam button's light goes off and the hot water gets illumintaed and all i get is hot water. It also does not make that thumping noise it usually does just before the steaming begins. Please help!
I have tried clenaing it, letting the hot water run for a few minutes (not just seconds) but still the issue isn't resolved. I am thinking about taking it back to the manufacturer as it is still under warranty. Only prob is they are on the other side of the state :o(
Many thanks,
Alison
Posted on Dec 11, 2007
The steam wand on a DeLonghi 3400 expresso machine leaks what's the problem
You probably need to replace the valve. Have a look at the video.
Hope this helps.
Jul 23, 2015 | DeLonghi Coffee Makers & Espresso Machines
Lg true steam heats up but won't steam
What is the make and model number of your unit?
Nov 05, 2012 | LG Dryers
Water shoots out of steam valve and can't make espresso
Samantha,
The steam function and the expresso use the same elements to create the steam but the valves will direct the steam to the expresso unit or the steam arm. Most likely you have a faulty valve. In most cases the valve will not open until the pressure gets to the right level. If you are just getting hot water out of the steam arm instead of steam via the expresso unit it most likely means that the valve is faulty. The valves can be replaced but is not easy. You will need to have the unit serviced or you could try to replace the valves. Make sure the flow meter is working before you replace the valves. You can check the operation of the flow meter by running the hot water cycle and making sure that you get the right amount of hot water. Good luck!
Nov 21, 2011 | Krups XP2070 10 cup Coffee Maker/15 bar...
My expresso machine won't steam. Just suddenly stopped. Have tried running vinegar through system, but still won't run through steamer.
Hi, I dont know which brand machine you have, but I should be able to work out what is wrong. If your machine has a press button or turn knob steam tap, then it could be the solenoid which opens the steam flow. The solenoid itself maybe stuck or the coil maybe faulty. You just need to work back from the steam arm to work out which solenoid it is. It should make a clicking sound when activated. Commercial machine solenoids canbe disassembled and cleaned. If its a domestic machine, then just replace the solenoid. Also, some machines have a micro switch that activates the steam valve. If its faulty, then replace it.
If its a domestic machine you have, then another thing that maybe at fault, and that is the thermoblock (small boiler). If it doesn't heat up then no steam canbe made. The thermoblock has an element inside, and they can not be replaced. You have to replace the whole thermoblock. It can be easily checked with a multi meter to see if the circuit is broken. On some thermoblocks, is a thermostat or overload sensor. It is also easily checked with a meter.
So lets break it down a) solenid
b) micro switch
c) Thermoblock
d) thermostat/ thermol overload
Hope this has help you. Id be looking towards the thermoblock. Dazza
Oct 20, 2011 | Krups Gusto 880-42 Espresso Machine
It is getting up to tempeture but it will not produce any steam
Your machine need to reach boiling point to produce stem? Then check if all the sustem is sealed other than the pip outlet gun and it should now operate with the gun trigger ( pull to operate, but only when the water within the vessel is boiling, producing steam)Hope this helps Regards Mike
Jul 08, 2011 | Polti Vaporetto 2400 Canister Steam Vacuum
Cannot produce steam
The machine have a separate heating system for steam than hot water for steam. The steam system it might be full of scale. If you hand are good you can easily remove top panel and side panel. You can follow the teflon pipe from the steam wand and it will lead you to the steam solenoid valve and the small copper steam heating system and desasemble it both the valve and small boiler and remove any scale and dirt from it using a wire brush, shurp screwdriver and similar tool. Then poot them back together. You can try the machine with panel removed so if it needs something more to try once more again. One small tip advice. Use your camera and make pictures of everything before desasemble them, then you are safe if you forget about something. In this way you can clean everything metalic that the water pass though.
May 11, 2010 | Saeco Vienna De Luxe Espresso Machine
My milk steamer is no longer steaming. Some steam comes out but not enough to steam the milk. The expresso part is working fine as I recently used a Krups descaling kit on it.
From your message that it is clear that the steam is coming but it is not sufficient to heat the milk, so kindly call the customer care to sort the problem as you can't do it
Thank you.
May 08, 2010 | Krups XP4030 Espresso Machine
Sylvia still makes great milk for steam but on Saturday it stopped producing hot water for expresso. What do I do? I live in North Tas
Hi
. If the brew thermostat is bad it won’t heat. To test for this, push the steam switch and wait 15 seconds. Then open the steam knob and push the middle button and see if the water is warm. If it is then you need a new brew thermostat. That is the thermostat that has the red dot on the top. It sets on top of the boiler next to the steam thermostat. If you take the top off, make sure that the machine is unplugged.
Nov 15, 2009 | Rancilio Silvia Espresso Machine
I have a expresso machine ESP6. it is not letting out enough steam or frothing milk. what's the problem and how to fix it?
The steaming wand's tip gets gunked up with milk so make sure to clear that with a needle first. Make sure the machine is fully heated before using the stream function (should have an indicator light). Typically this model will expel water first, then a low pressure steam. After about 30 - 40 seconds it should produce meduim pressure steam. Make sure the pump is making the proper clunk, clunk sound or it could be failing. Also, the steam wand arm may be obstructed and descaler solution will have to be used to remove the deposits. Hope this helps.
Sep 15, 2008 | Breville ESP8XL Espresso Machine
No steam!
Ran into the same problem on mine just after using the steam, so it definetely wasn't clogged... hope this helps.
Just try running the expresso maker through a full cycle and then try the steam again. Not sure if the machine air locked or something, but the expresso cycle appeared to get the water flowing again and then it had no trouble producing steam.
Hope it works.
Jan 11, 2008 | Hamilton Beach 40729 Espresso Machine
Breville ESP8XL Espresso Machine Logo
406 people viewed this question
Top Breville Coffee Makers & Espresso Machines Experts
Steve Banks
Tally Girl
Tally Girl
Are you a Breville Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
