Question about Toshiba SD-V392 DVD Player/VCR
Vcr thinks all tapes are play only
This machine will not record on any tapes, thinking all tapes are read-only, although the same tapes record fine on other machines.
  • 286 Answers
At the back of all tapes, there is a plastic tab. To make the tape read only, you break out the tab.
All VCRs have a sensor (usually a simple switch) that checks to see if the tab is broken. This sensor has gone bad.
Put a tape in. Unplug the unit. Take the top off and look where the tape is. Find the location of the tab. You should see the sensor there. It will be a switch, and may use an actuator to "poke in the tab hole". Make sure the actuator is good (that it doesn't look broken or out of alignment). At the other end of the actuator should be a switch. You can try to spray some cleaner into the switch, and then work it. If this doesn't work, you could replace it but you would need to know soldering. Also, you might be able to get it to work by shorting the switch leads together (50:50), but you also would likely have to use solder. You might be able to twist a piece of bare wire around the switch leads. These solutions would cause the unit to think all tapes are recordable, even if the tab has been broken out.
If the sensor is not a switch, but an IR pair (a U shaped sensor) then there might not be much you can do. Make sure the actuator is working (it will usually have a flat piece on it that will fit into the U shaped sensor to block the infrared light, make sure it moves freely). Again, if you knew which side of the sensor is the transistor (it might be marked on the curcuit board with E and C) you could drop some solder on it to turn it on all the time. Again, this is 50:50.
Posted on Feb 14, 2008
Hi, I have a sony tvr 140E. When I try to play back a tape that was recorded from another digital 8 camcorder I get blue screen. when I play back a tape recorded on my camcorder plays fine. Any...
This smacks of the same problem that the old VCR's used to have. One of you are out of sync. The tape records on a portion of the tape in a sort of straight line track. Think of it as your track is down 1/16" from the top. The other camera tracks it's video down 1/8" instead. That's why in playback it can't read it. The only cure is a realignment. Nimsgame
Feb 19, 2011 | Sony Handycam DCR-TRV460 Digital Camcorder
Dub a tape that is playing through my camcorder on TV
A vcr or dvd-recorder only reads the input signal. It does not care where it is coming from, only that it is there. You would have to run it through the vcr or dvdr for it to read the signal, or copy it to your computer and burn it to dvd.
May 27, 2009 | Sony Handycam DCR-IP7E Micro Digital...
VCR records TV shows, but doesn't play them on other VCR's
The machines playabilty setting has gone off. take to nearest repair shop and they will probably reset or change guide posts.
These components normally will allow a tape recorded in one machine to play on another. Had many of those esp from camcorder to vcr
May 05, 2009 | Panasonic DMR-EZ47V DVD Recorder/VCR
Sony SLV 678HF
This is a VHS VCR and should be like any standard vcr to hookup. Did you obtain this VCR recently; and was it used? What are you calling the 'monitor'? Is it a standard TV. Since you said pre-recorded tapes work OK, I think your cable connections are fine. With that in mind, if this is a used VCR, I think your 'recording/playback' heads need to be cleaned. This is not a big deal to someone who can look inside with some competence if they are careful. But the heads are very delicate and can be damaged quite easily. If you want to give it a try or discuss this in more detail, I can guide you (but no guarantees).
Jul 10, 2017 | Televison & Video
Need to play a T-160 recorded in slp at normal speed to watch
This is automatic, as the record speed can only be manipulated, not playback unless youhave that setting which I have never seen,
May 11, 2008 | Zenith VCS442 VHS VCR
DRC 8335 Playing Back VCR Recordings in a Fast Forward State
I bought mine yesterday and am having the same issues. No solution listed in the user manual to fix this and I have a rather extensive VHS tape library that I was hoping to move to DVD using this unit. Unable to watch any VHS tapes taped on my Panasonic VCR and it seems as if the tape is slipping. Tracking buttons don't fix anything. I found a blank spot at the end of the tape and taped something and it comes out fine. Could this have something to do with it being a 6 head VCR? Tapes are in SLP mode.
Jan 08, 2008 | RCA DRC8335
DMR-EZ47VK Up-Converting 1080p DVD-Recorder/VCR Combo
I think the problem with the tapes stopping is that there is too much tension on the tape. Try another VCR and try to see if you have the same problem playing the tape. Forward and reverse through the part that causes the player to stop. It is also possible that the tape inside the vcr has become twisted or stuck. One can fix this if they are very careful opening the video tape. However, I would not recommend this for most people
Dec 22, 2007 | Lite On LVW-5045 DVD Recorder
VCR thinks ALL tapes are write protected.
the record tab detection switch inside the machine is broken
Dec 12, 2007 | Toshiba SD-V392 DVD Player/VCR
My VCR is playing too fast
try recording on a blank tape and setting the tape speed to SP (standard play). you should also see options for (LP-long play) and SLP (super long play). I think your machine is stuck on SLP option. if no-go, look for a manual on the web.
May 27, 2007 | Daewoo DV-T8DN VHS VCR
Vcr tape problem
It sounds like the tracking information is being lost for brief periods of time. Tracking is recorded at the lower edge of the tape, and if the tape is wrinkled or otherwise damaged in this area, playback will go out to lunch. A visual check of the tape would be in order. Have the heads been cleaned in these machines? This would be another area to check.... Also, there could be small differences in the tape path alignments, perhaps the control/audio head alignment is slightly different between the 2 machines.
Apr 28, 2007 | Panasonic AG-1980 S-VHS VCR
Toshiba SD-V392 DVD Player/VCR Logo
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
