Question about Compaq Evo D510 Minitower (Open Box) (OB4700432011) PC Desktop
Compaq Evo memory problem
Hi there, I've just bought a Compaq Evo that won't boot.
It gives me a beep code of 1 short two long, and flashing numlock key, which according to the BIOS manual indicates a memory problem of some kind.
It has two sticks of DDR in it, which I pulled out and replaced with a stick from a working machine - same error. I also put the ones from the Evo into my other, working machine, and they worked fine.
Any ideas how to diagnose and / or fix this problem?
Cheers, and thanks,
Cam
  • plaizls Dec 11, 2008
    evo D510 with beep code problem
    one short two long
    I need to fix this myself. Please help, Thanks
Just thought I would update as I have just had the same problem.
I turned off the computer, disconnected the hard drive and processor and then reset the Cmos. Reconnected everything and started the machine up. Don't know what it did but everything works fine now.
Keep in mind you may not reset while power is connected to the computer, could damage the mobo.
Posted on Dec 12, 2008
  • 38 Answers
> this problems indiate that your mother board ROM problems
get for repair
Posted on Dec 04, 2007
I have the same problem but i need to solve it ma self so can any one explain to me what can i do.
Posted on Sep 23, 2008
Beeping on start up
The following beep codes are common to many HP and Compaq desktop computers. Use these codes before referring to the other codes when they occur.
Beeps Description 1 short beep and 1 long beep Memory problem 2 short beeps and 1 long beep (repeats 5 times) Unable to initialize video or video card required but not installed 3 short beeps and 1 long beep CPU configuration error or CPU type is not compatible The following beep codes are common to many HP and Compaq desktop computers that can occurwhile restoring, flashing or updating the BIOS :
Beeps Description 1 short beep Legacy floppy drive or CD/DVD drive not detected 2 short beeps Floppy diskette or compact disc not detected 3 short beeps Unable to start flashing (such as when missing a utility or BIOS image) 4 short beeps Flashing failed (checksum error, corrupted image, etc.) 5 short beeps BIOS recovery successful
You can refer to the link mentioned below for further troubleshooting:
http://h10025.www1.hp.com/ewfrf/wc/document?cc=us&lc=en&docname=bph07107#N589
GuruAid
Apr 09, 2014 | HP Compaq Presario SR1830NX PC Desktop
Compaq Evo Problem!!
hi
this probleme causing by graphic card put the new one and try
Feb 19, 2012 | Compaq Evo D510 PC Desktop
My hp-compaq dx2300 microtower restarts automatically when working. It is installed on win xp sp3. Please let anyone help if solution is known.
Hi names Rui, i question for you does your PC give a beeping sound when you turn it on? if does can you tell me how many beeps it gives?
if it give a designated number of beeps this might be the problem i will give you a chart so you can differentiate the warning beeps you hear.
warning beeps:
1 Short Beep DRAM refresh failure
2 Short Beep Parity circuit failure
3 Short Beep Base 64k RAM failure
4 Short Beep System time failure
5 Short Beep Process failure
6 Short Beep keyboard control gate A20 failure
7 Short Beep Virtual mode exeption failure
8 Short Beep Display memory read/write test failure
9 Short Beep ROM BIOS checksum failure
10 Short Beep CMOS shutdown read/write error
11 Short Beep Cache memory error
1 long, 3 short Beep Conventional/Extended memory failure
1 long, 8 short beep Display/Retrace test failed
hope this will determine the problem if none of this warning beep is heard try reseting the power botton in you PC cause sometimes the power botton will loosen cause of continuous use of the botton.
hope this will help you.
Jul 20, 2011 | HP Compaq dx2300 Microtower - RT950UTABA...
Five beep in Hp compaq 530
1 short beep and 1 long beep Memory problem 2 short beeps and 1 long beep (repeats 5 times) Unable to initialize video or video card required but not installed 3 short beeps and 1 long beep CPU configuration error or CPU type is not compatible The following beep codes are common to many HP and Compaq desktop computers that can occur while restoring, flashing or updating the BIOS : Beeps Description 1 short beep Legacy floppy drive or CD/DVD drive not detected 2 short beeps Floppy diskette or compact disc not detected 3 short beeps Unable to start flashing (such as when missing a utility or BIOS image) 4 short beeps Flashing failed (checksum error, corrupted image, etc.) 5 short beeps BIOS recovery successful
Apr 21, 2011 | HP Compaq Business d530 Ultra-Slim PC...
Motherboard flashes 8 yellow lights then one green light, what does this mean
8 beeps=Your video card isn't working. Make sure it is seated well in the bus. If it still beeps, either the whole card is bad or the memory on it is. Best bet is to install another video card.
1 Long, 8 Short Beeps=Display / retrace test failed. Reset the video card.
Nov 24, 2009 | Compaq Evo N610C Notebook
I am getting three short beeps while booting
The beep codes below may help you identify the possible computer problems. However,
they are only for reference purposes. The situations might differ from case to case.
gAMI BIOS Beep Codes
*Computer gives 1 short beep when system boots successfully.
*Except for beep code 8, these codes are always fatal.
1 beep Refresh failure
2 beeps Parity error
3 beeps Base 64K memory failure
4 beeps Timer not operational
5 beeps Processor error
6 beeps 8042 - gate A20 failure
7 beeps Processor exception interrupt error
8 beeps Display memory read/write failure
9 beeps ROM checksum error
10 beeps CMOS shutdown register read/write error
11 beeps Cache memory bad
g AWARD BIOS Beep Codes
1 short: System boots successfully
2 short: CMOS setting error
1 long 1 short: DRAM or M/B error
1 long 2 short: Monitor or display card error
1 long 3 short: Keyboard error
1 long 9 short: BIOS ROM error
Continuous long beeps: DRAM error
Continuous short beeps: Power error
Nov 03, 2009 | Gigabyte GA-7VKML Motherboard
Compaq evo d51s beeps on boot
Try to reseat the memory sticks. Sometimes they just need reseated.
Oct 25, 2009 | Compaq Evo D500 PC Desktop
Compaq evo will not boot up
try to go to BIOS
if the pc is not allowing you to go BIOS then get a bootable cd & insert the same & boot the pc to the desktop & also open the chasis & reseat the memory sticks.
Apr 10, 2009 | Compaq Evo D310v PC Desktop
Installed new DIMM memory in Compaq D510 CMT - puff of smoke
Here's a full list of the POST beeps for your computer:
http://bizsupport1.austin.hp.com/bc/docs/support/SupportManual/c00704816/c00704816.pdf
That flashing numlock and beep pattern says there is no system memory. When you let the smoke out before it might have been fatal for something. It could be the memory itself is dead, or something could have been damaged on the system board that is keeping it from detecting memory. The only way to know for sure is to try another stick of known good memory.
There's also the possibility you used the wrong kind of memory when you added the new part. Here's a link to the hardware guide for the computer:
http://bizsupport1.austin.hp.com/bc/docs/support/SupportManual/c00706221/c00706221.pdf
You can use the information to be sure any memory you get is supported.
Hope this helps you. Good luck getting the computer running.
Jul 31, 2008 | Compaq Evo D510 Minitower (Open Box)...
Compaq Evo D510 Minitower (Open Box) (OB4700432011) PC Desktop Logo
822 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
