Depending on the encryption you are using, I.E. WEP 64 Bit, you will be required to enter in 10 Hex Digits, digits can contain numbers and letters with no spaces. If the encryption is WEP 128 your going to need 26 Hex Digits. I use WPA2 myself using AES Algorithms and any Shared Key you want to make up. Hope this helps you out...
Same Problem
Oct 18, 2009
-   I am still trying to get the D-Link DI-624 to work. Can anyone help again. I have also tried to reset still having the problem.
Lekkie-   Lekkiee
I'm trying to set up two computers with DSL,but when we the tech tried to walk me thru it, did not...
(More)
I'm trying to set up two computers with DSL,but when we the tech tried to walk me thru it, did not work. Once the router was hooked up, couldn't get online. The tech is saying the router is faulty, but it worked just fine with Comcast. Switching from Comcast because cost keeps going up and going up again next year. Is D-Link compatible with DSL?
m belkin will not let me play animal crossing (wii) online, but i can play and do anthing else that...
(More)
m belkin will not let me play animal crossing (wii) online, but i can play and do anthing else that is online with the wii without any problems.
